  • Thomas W
    • 54
    • Indianapolis, In.
    Originally posted by gravity tester
    Hi Thomas-
    Best of luck with the maiden. I am sure you will do just fine, especially with flaps. 400 feet should plenty of room for this bird. What field do you fly from in the Indy area?
    Dan
    Am a member of Indy South RC Club. I thought about taking the A-10 out to the Morristown club, but am not a member there and will be nervous enough flying it on my home field let alone a new field, new plane, and new guys around me.
    • Nucastle
      • 17
      Originally posted by MikeT
Name:
ID:	91210Click image for larger version
Name:
ID:	91211Click image for larger version
Name:
      Is that the Euro 2 scheme basically?
      • MikeT
        Here......Hold my beer.
        • 1060
        Yes it is but I used 4 colors rather than 3 and changed it a bit
        Mike
        • Shirty
          Hobby Squawk Water Boy
          • 1067
          • Perth, Australia
          Plus 1. That looks awesome mike, great job mate.
          I was was worried about the sharksmouth too xtraflyer, but follow the steps outlined in the thread and she'll be right. My decal setting solution starting eating the paint, so I just used water, but was able to move it around no worries till I was happy with it. Good luck.
          • bcrc
            Pilot
            • Jun 2017
            • 33
            Here's pics of the reversed struts (bounce fix)...
            Hi TiredIron:
            Isn't reversing the gear essentially just locking them down, as it is unlikely that they will spring forward on a landing. I have had several airplanes over the years that landed best with no shock absorbing/etc except the rubber in the tires. My question is this: on your landings, are the main gear units really collapsing forward if the landing isn't greased - or is there just no give and they are essentially locked down?
              Originally posted by Xtraflyr
              Also if someone can throw up pics of all the missles and what graphics go where,would be appreciated!
              I think this should be put into the manual. 3views helped a bunch though.
              This should help.
              • sam51401
                • 368
                • Sellersburg IN
                Hey Pat, Do you still have a couple sets of the ALQ pod decals you made available?
                  Originally posted by bcrc
                  Hi TiredIron:
                  If you come in with plenty of alpha it does compress on initial touch down but once it's rolling it's locked...I've got over a dozen flights on the A-10 since reversing the mains with zero bouncing.
                  • Xtraflyr
                    • 96
                    • Morris County NJ
                    Can we use CA on this foam? I know it comes with a rubber cement type of glue.
                    • Thomas W
                      • 54
                      • Indianapolis, In.
                      Anyone have a set of the blacksnake nose decals theyre not using? Just fubared my 1st attempt at application on mine and their out of stock at MRC. PM me if you have a set for a few bucks and Ill give you my mailing address.
                      Thanks
                      • TomPatton
                        XNitroJunkie
                        • 279
                        • Elida Ohio
                        Thanks
                        Did you get a set yet? If not you can have mine. I don't need any money for them, you are welcome to them...
                        • bill34207
                          Jet Junkie
                          • 455
                          • Bradenton, Florida
                          Managed to get in a couple of early morning flights on mine this morning. Mostly testing the Runcam II that I bought from Amazon. (Of course it showed up on Motion's website about the time mine was delivered from Amazon)
                          Using the "G Sensor" setting is not such a great idea as it got a little confused on which way was up a couple of times. I think the video quality is better than the Mobius and with it set to narrow FOV it doesn't bend the horizon like the GoPro and Mobius.
                          It's a little long since it was two flights put together but gives a good idea of what the facility looks like at the SRQ Squadron where I fly.
                          • Thomas W
                            • 54
                            • Indianapolis, In.
                            You are too kind. PM on the way with details. Thank you very much.
                            • TomPatton
                              XNitroJunkie
                              • 279
                              • Elida Ohio
                              Hey Thomas,
                              I sent you a PM I think. I could not figure out how to reply from your message. Anyway the decals are in the mailbox, and will go out tomorrow.
                              From Elida Ohio to Indianapolis should only be a couple days, by Wednesday for sure I would think...
                              No payment necessary, just one RC pilot helping out another.
                              Enjoy your A-10...
                              Tom
                              • skippykix
                                US Navy retired
                                • 31
                                • United States
                                Hey Thomas,
                                Enjoy your A-10...
                                Tom
                                Now that is awesome! This is why I love this hobby!
                                • Pete Lane
                                  Turbine lover
                                  • 290
                                  • Los Gatos Cally
                                  Yes. Foam is safe for CA
                                  • Pete Lane
                                    Turbine lover
                                    • 290
                                    • Los Gatos Cally
                                    I used a damp cotton sock over my hand to mold it over the nose.
                                    • Xtraflyr
                                      • 96
                                      • Morris County NJ
                                      Looks great! Thanks for the idea.
                                        • 2137
                                        • On planet earth....right
                                        On a side note, I've been noticing different pictures of the snake nose art where the center split decal isn't used, but I'm thinking it's likely because it's so amazingly easy to overlook it. I did myself after installing it, and as I was installing other decals, I noticed the decal sheet has a left over piece of the same color, but just a line. That's what it's likely for, so just wanted to give a heads up in case anyone wants to add that :Cool:. After adding the split, it does look more complete. However, this is STILL an assumption that it's used for that purpose, as I don't actually see any instructions saying to do so, but it's the same gray color and can't see anywhere else it would go. See if you think the same or can find another spot. The line on the decal sheet is placed next a completely different nose art piece, so there's a chance it could go to that, but doesn't seem like it would in any way I can think of.
                                        Here is a picture of the piece on the decal sheet that is installed vertically on the Blacksnakes nose art in the center connecting both the horizontal pieces.
                                        • Xtraflyr
                                          • 96
                                          • Morris County NJ
                                          Snuck my maiden flight in today. I don't think I had the elevator in the right spot since it needed what seemed as a ton of up trim. I have my 5200mah set back but not all the way on the battery trays. I may also add a little Expo to the ailerons as they were a bit twitchy for my liking. It could've also been my nerves during the maiden.
                                          I should've gone around during my landing,cuz it rolled into the rougher grass area on roll out.
                                          It looks totally bad ass in the air though,very scale looking!
                                          Now just to get my nerves up to add the nose art!;-)
