  • Felixs10
    Felix S.
    • 113
    • Bergen county, NJ
    Originally posted by Beeg
    I concur with how everything went together so quick and easy. Most paint lines are great except for the forward crossover of the canopy had some seppage from the paint mask. All in all an excellent model! Using a Lemon 7channel. Hope to fly it soon.
    I used a 7 channel Lemon as well . I turned the board around in the front of the battery bay so that the wires leading to the rx faced the back of the airplane and mounted the receiver underneath the battery. Great flying plane you're going to love it. Havent needed to turn on the Gyro once yet.
    • cableguy351
      weather finaly was decent today to fly mine
      • Bcool831
        Don't Tell My Wife How Many I Have.
        • 19
        I'm hesitant to cut into top of foam wingbto add winglets. Any guidance to do so?
        • Ron lake
          Hobby Squawk Intermediate Pilot
          • 68
          • North East Kansas
          Use a piece of wood like this to make a perfectly straight line. Follow the instructions 3mm deep 2mm wide for the groove then keep scoring the groove with a pop cycle stick until the fence seats properly. When your happy with the fit glue it on.
          • TomPatton
            XNitroJunkie
            • 279
            • Elida Ohio
            Yeah, don't add them !!!
            • Ron lake
              • 68
              • North East Kansas
              To each his own. I think it looks great with them!
              • Bcool831
                • 19
                Thanks for the input guys. I need to work on my settings and channel assignments. I'm using a dx9 and ar636. When i activate gear my flaps go down at same time.
                  • 8748
                  Did the AR636 come out of another plane? If so, the flap channel or gear channel may have been programmed to do something else.
                  • Garyss
                    • 29
                    Observations from a fellow club member's Avanti maiden:
                    Flight time - appx. 3 minutes 45 seconds
                    Battery - 4000mah 40C HK Turnigy
                    Battery temp - very slightly warm
                    Battery reading post flight - 22.1 volts
                    Flight was at moderate speed with minimal aerobatics and one high speed pass. Overall very solid.
                    • Bcool831
                      • 19
                      Xviper, yes it was probably programmed already. I do have the cable to go in a look at the settings. Thanks I didn't think of that for some reason. Palm to head.
                        • 8748
                        Ahh, very good. Also know that depending on which plane it came out of, there may be features that are "locked" and can't be changed. For example, the AR636A out of their Opterra, has a "launch" mode where the program is buried deep in the software and the end user will have a very difficult time accessing it and changing it. The 636 from their Radian XL, I've simply gone in there and changed the parameters as I see fit for another plane. Other planes, Horizon states that the 636 can only be used for a specific plane and the programming can't be accessed or changed. The stand alone ones that you buy from the store are fully programmable.
                        • Bcool831
                          • 19
                          Awesome info. Thank you. Anyone know the db of the df on this jet?
                          • Rcflyguy
                            • 14
                            Mine is at the house, unfortunately I am not.
                            • Kferros
                              edf jockey
                              • 40
                              • Eustis Fl
                              Hey Avanti owners. Putting mine together and problems with flaps. They go 45 and 90. Tried to adjust with trim and no luck. Haven't had this problem before. Really don't want to cut servos out unless I have to. Any ideas. Thanks.
                              • Bcool831
                                • 19
                                Mine too so i adjusted travel limits. I reduced mine so i now have 1/4 flaps and thats all.
                                • Beeg
                                  • 1335
                                  • Texas
                                  What radio are you using?
                                    • 8203
                                    Depending on radio you should be able to control your flap percentages in the flap settings...
                                    • Kferros
                                      edf jockey
                                      • 40
                                      • Eustis Fl
                                      You are right will check that out. I was using sub trim only. Thanks.
                                      • Kferros
                                        edf jockey
                                        • 40
                                        • Eustis Fl
                                        Thought I could with DX8 but could not find flap settings. Am I missing something.
                                        • Kferros
                                          edf jockey
                                          • 40
                                          • Eustis Fl
                                          Dh112 has split flaps and don't have the problem I'm having. T45 can use 2 settings and not be at 90 on last. I usaull use 25-30 degree for takeoff and 45 for landings.
