Man, this thing flat humbled me. Got my first three flights on it, must say it flies great. It is stock and I was surprised how well it preformed. I just have to learn how to land it. Three flights, three arrivals. 15mph wind with gusts might have been some of the problem. I have a lot of flights on the 70mm version with no landing issues.Comment
So where you running your CG? That plays a big part on landing this jet properly. I have over a hundred flights on mine and nose heavy is the way to go, if to far aft it becomes hard to land.
:Cool:What Corsair said!
My first 2 flights the thing catapulted straight up off the runway on takeoff and floated way long on both landings. I had it at the “book CG” and it was way off. I moved the battery way forward and it performed great. I don’t have the CG listed, but here’s a picture of where you should place your battery. I found it best to keep the size between 4000-5000 mah. Any heavier and it’s too high of a wing load, you get the same flight time, and it flys very heavy. Just my experience...
First flight cg was 118mm then 115mm for the last two. I'm flying with 5000mah. By your pic my batt is 1/2" to3/4" aft.Comment
Does anyone have the Eflite F-16? Curious how it flies compare to the 90mm. I have a F-22 that I'm still getting use to, love the F-22. Grass ok?Planes
-FMS: Bae Hawk Motion: 1.6m Corsair, 850mm Mustang, 1.6m Spitfire Freewing: 1.7m A-10, F-22,Comment
Yeah, it’s fine. I fly off a golf course though.... I haven’t read about anyone having issues with it. The lighter you get the weight the better!Comment
Flaperons? Elevons? Could you all please comment on best way to setup the F-16 if you want to use flaps? I currently have it setup with Flaperons only and at full flap deflection I loose most roll control which makes it harder during strong wind landings. Should I go with Elevons only instead?...or does Elevon + Flaperon work well on this model? Thanks!Comment
Yes, I noticed the same that it slows down and lands well with half flaps. I may just reduce the flap deflection and use full ailieron rates during landing to solve to roll rate issue.Comment
Flaperons with tailerons mixed. Tailerons come off with flaps up. My flaperons are max deflection and it flies like a champ.Comment
I considered cropping them out but didn’t want to be accused of photoshopping the results.
Come join us some time! We have a great facility with a paved runway, a large covered area and a solar powered charging station provided by the county park system.Comment
