zygmunt, Welcome to H'Squawk and presumably the Corsair Owners Club. This prop is pretty well balanced but in my book all props especially three blade need putting on the balance machine. Three bladers have a specific process in order to balance -- maybe a search will find it for you if not pm me and I will describe.
I put my blades on my Du-Bro balancer as I do with all my props and I didn't have anything to do as there was no obvious weighted differential. It was a pleasant surprise. But by no means does that mean everyone's is the same. I would still check before flying.My YouTube RC videos:
JIMMY, THATS PRETTY common response for a servo tester. I use a old rx and a 4.8 or 6v battery pack, then they work fine.
as for balancing props from flite line, as long as they come out of the same package I just put them on and run it up. if its out of balance I can hear it w electric. my son broke one blade on his fms me109 and pulled one out of a package to replace it and the prop was way out of balance. replaced the other two props and it was fine, that means they do not keep the molding pressure stable between operators.
JoePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9Comment
This looks like pretty cool stuff. I guess after you apply it, and it dries and you paint you just peal it off?Woods, this is the product https://www.amazon.com/Grafix-2-Ounc...gateway&sr=8-5 Best, LBComment
I think you use a soft gum eraser to start the peel. I watched a lady using it on watercolor art on youtube and that's what she did. If this stuff works as advertised, could really be something. Someone in the HS community has also mentioned this product before and likes it. Don't recall where I saw the post as I have slept since then. A bit pricey but if it works...Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
BRK, Ah, thank you, sir. What is the brand name you use? Canopies are my Achille's Heel. LOL Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
In all the years I’ve been building models, I never totally replaced good old Scotch tape to mask my canopies with. Just be sure it’s a roll dedicated to masking canopies and is not lint laden around the edges. Guess I’m a dinosaur of sorts but it just never fails me. Blue painters works second best for me on canopies and yet it’s indispensable in masking these birds for airbrushing markings.
Tamiya makes a great masking tape and I use it on my 1/48 models and it works well.
For “our” RC applications, use the Tamiya for the precise lines and the fill in with good old blue masking tape.
I’ve used the liquid mask, but you apply it with a brus. So unless y’all can paint a straight line (& I can’t for sure), you still have to mask the straight lines with tape to get the sharp lines you want.
Just my two cents...
I'd have to say for masking a canopy for repaint, forget the frisket and so on. Just get yourself a roll of yellow frog tape from any hardware store or Lowes etc. It will give you a nice sharp straight line that the paint wont run under. The green would work too but for masking in other areas over the foam, the yellow wont lift the paint.(if you pull it off carefully) Yeah, thought Elbee was building up to........well you know. Good luck, BradComment
I agree with Alfer...I've been using liquid mask for years on smaller, static models but I would not recommend it for our larger RC planes. It takes too much mask and it can scratch the plastic when you trim away the excess...our softer RC canopies would be too risky IMHO. I would recommend Tamiya 5mm compound masking tape. It bends, and once you trim the edges, just use frog tape to fill in. Much easier to bend with curves than trying to cut custom pieces of regular masking tape! Rob2 PhotosComment
I think you are asking if the battery tray is parallel with the fuselage datum? If so, then yes they are parallel as far as I can tell without putting an incidence meter to the model... Hope that helps. Can I ask why you were wondering? Just curious.... ;):Confused:Comment
Correct. Dark Blue for Bubbletop and Light Blue for Birdcage.
Picked up some Tamiya masking tape for curves. That could be a game-changer! All these years of using painters tape to carefully mask and trim with a hobby knife for canopies. Always worked great but very time consuming.
