  • themudduck
    -TMD- Foaming at the Mouth!
    • 1041
    • Burton OH (near Cleveland)
    Originally posted by I-fly-rc-aircraft
    Thanks man. Lost mine at Fall Nall in the grass but didn't notice it until I was back home.
    How did you make out with the scissor links?
    Tom
    Hey Tom,
    I started with the links - and I did print the parts and so far it seems OK. During setup I enlarged the one part like you mentioned to make it the same size as the other, I think it was set at 109% or 110% on my slicer (so 9 or 10% larger) and it seems ok. I've cleaned up the parts and everything looks good, I just need to take off a gear leg from my plane and play around with it to see how it goes together. Perhaps this weekend!
    If you make a 3D part to replace that antenna that will be very handy! I've lost mine once (and replaced it).
    -Marc
    • I-fly-rc-aircraft
      Always learning
      • Jan 2019
      • 269
      • North Augusta, SC
      Fortunately I had a spare strut assembly so I didn't have to take apart the gear leg on my plane for the trial fittings.
      I had also printed the links at 22 mm vs 25 mm and liked the 22s better.
      Here is the .stl for the front antenna. I printed it at .2 resolution with 5 bottom and five top layers.
      Tom
        • 4820
        Tom
        IF, Thank you for this. Always great when the community steps up like this. Bravo Zulu, Sir. Best, LB
        • themudduck
          • 1041
          Tom
          Super! You're amazing.
          Tom, here's a few pics. This took me only 12 minutes to print just now. Your mast is the correct length and width and the taper looks good. It fits!
          But you notched the base, and I think you should just delete the notches. (the bottom section should be rectangular, no taper) --Marc
          Click image for larger version  Name:	Mast v1.jpg Views:	0 Size:	39.1 KB ID:	227326Click image for larger version  Name:	Mast v1-b.jpg Views:	0 Size:	37.7 KB ID:	227327
          • I-fly-rc-aircraft
            Always learning
            • Jan 2019
            • 269
            • North Augusta, SC
            Thanks Marc.
            I didn't have the old antenna to copy. I'll redesign the next one if the need arises. Great job on the print.
            Tom
            • I-fly-rc-aircraft
              Always learning
              • Jan 2019
              • 269
              • North Augusta, SC
              I did redesign the Front mast but have yet to print it. This should work.
              • themudduck
                • 1041
                Brilliant! Well I just printed it and its perfect. Here is a picture showing the original, the most recent version, and version 1 with the cutouts.
                All I need to do is paint it... thank you!
Name:	2020-01-12 11.48.02.jpg
                • I-fly-rc-aircraft
                  Always learning
                  • Jan 2019
                  • 269
                  • North Augusta, SC
                  Designed these today. Any idea why?
                  Tom
                    • 2693
                    Tom
                    Maybe cause it's more fun than watching "My 600 pound Life"
                      • 4820
                      Well for some, maybe...
                      I-fly-rc-aircraft, Canopy Latch, I'm thinkin'. Best, LB
                      • I-fly-rc-aircraft
                        Always learning
                        • Jan 2019
                        • 269
                        • North Augusta, SC
                        And the winner is....LB
                        • f4u ausie
                          • 1230
                          • Melbourne
                          hey guys hope ur all well,,,, im not in4 sooky la la stuff...just noticed couple other complaints ... luv flying it just put my first 6000 pack in the air 6 or 8 minutts awsome .. i think about 8th flight alltogrther.... first landings to a crawl,,, all good . bu next couple just tad faster on grass t b fair ,,but first landing ,, arealighn and fiberglass sheet req one of the retracts ... happy as a pig in ..well u no...... but next land same the . other side land gear .. the floating end of jack screw punched thru the plastic body ,,,, is it me landing too fast// or u guys having same troublE ???? THOUGHT I HAD IT FIGURED OUT JUST IN CASE IT IS 1600 F4U FLINE THANX
                          • themudduck
                            • 1041
                            Tom
                            Heh - the name of the file is "Hatch remover.png" - hmm..that could be a clue.
                            LB figured it out and he didn't look at the file name, I guess!
                            • themudduck
                              • 1041
                              Hey mate, the big F4U really requires a fine touch on landing. Come in with flaps down and some power on (like 15-20%) and fly it in, land on two wheels...don't cut the power all the way. The gear on this bird isn't strong enough to take a hit, it will be fine on grass but you need to land it like a feather. If you bang it down or bounce hard, you will crack or break the plastic case of the retract.
                              • f4u ausie
                                • 1230
                                • Melbourne
                                thanks i thought that ,, a little Tlc a screwdriver and epoxy ....all retracts fixed just gear doorset req wil order set of gear ,,,,just incase // no wind igota fly thanx again...
                                • e4dragongunner
                                  Living the dream!
                                  • 876
                                  • Arlington Heights Il.
                                  Tom
                                  Are these .stl's available? I checked the 3D forum... didn't seen them.
                                  • I-fly-rc-aircraft
                                    Always learning
                                    • Jan 2019
                                    • 269
                                    • North Augusta, SC
                                    I will post the .stl files here this evening.
                                    Tom
                                      • 2693
                                      I guess everyone has their somewhat unique preferred 2 point landing technique, but for me, what works best is to come in at just under 40% throttle and slowly bring it down the last foot or so on the mains, then cutting the throttle. This allows me to have a smooth touchdown at my discretion, while anything slower and it will touchdown no matter what I do, or end up as a three pointer. My bird is considerably heavier than the stock, with the robart wheels, Mr. RC sound card and transducers, my full body warbirds pilot and 4 coats of spar urethane and I love maximum flap extension ala Aros, so no doubt more throttle is required to keep it from dropping like a "wounded duck" than the stock Corsair. I have some of the same extra weight in my Spitfire and it comes in at only 25% throttle, so "to each his own" for every plane and pilot.
                                      • I-fly-rc-aircraft
                                        Always learning
                                        • Jan 2019
                                        • 269
                                        • North Augusta, SC
                                        Here are the .stl files for the hatch release.
                                        Tom
                                          Elbee commented
                                          Editing a comment
                                          IFRCA, I thank you, Sir. Best, LB
                                      • I-fly-rc-aircraft
                                        Always learning
                                        • Jan 2019
                                        • 269
                                        • North Augusta, SC
                                        My next endeavor is to design cowl flaps.
                                        Tom
