  • nuts-n-volts
    Duke City Electric Flyers
    • 262
    • Albuquerque, New Mexico
    I guess my question would be to anyone and to the R/C manufacturers... is any thrust line other than actual full size really needed? My apologies as this is off topic, so back to the airplane. Elbee you do magnificent work! And because of the mount, I'll probably fly that way with mine too.
    Fly low, fly fast, turn left
      Elbee commented
      Editing a comment
      Thanks NV. Much appreciated.
    • 8223
    Originally posted by Elbee
    ...The laugh to me anyway, is the original OEM cowling weight was 5.61 ounces which included all 4 nose weights. Now with 2 weights removed the all up weight is 5.75 ounces. So my thought is the dummy P&W definitely looks better than 2 steel weights.
    I think we would all heartily agree my friend.
    • f4u ausie
      • 1239
      • Melbourne
      Been of the squark 4 a bit new tx here... so flew my baby thismorn,, was nervous,, or pucker factor.... new set up all went wel, .. was going to get spectrum, but got new dynam detrum blitz... 4 years was good run 4 my previous detrum.. elbee and shark ... good job to u both.. very cool..... lastly more great recent stuff on u tube about the english involvement getting the f4u carrier capable it took some taming what a plane
        • 4848
        f4u ausie, I thank you, Sir. Yes, it would appear that the Brits had more patience with the carrier concept. Flightline nailed this, much like the Spittie. I'm enjoying the build. Best, LB
          • Nov 2013
          • 2748
          • Cody, WY
          Another huge development in the success of the Corsair to landing safely on carriers was the advent of the 6 inch stall strip on the leading edge of the right wing, which would (hopefully) cause the right wing to stall at the same time as the left wing on carrier landings. This stall would hopefully be performed at a few inches above the deck! I think Chance Vought and his team of engineers came up with the idea through wind tunnel testing to try to solve the problem of the left wing stalling and then rolling left on landing approaches to the carrier. An amazing plane!
          • RodgerC
            • Nov 2018
            • 25
            Corsair Colleagues, Quick update on the P&W 3DP mod. Dry fit to cowl ring of the painted bits. Not too bad, some assembly required, needs weathering. Offset thrust angles for the motor is included. Would like the P&W assembly to be 'proud' of the cowl ring slightly, but shimming the motor forward could be troublesome, we'll see. Best, LB
            Hi Elbee, Your 3DP motor looks great. Where did you get the STL file from? Rodger C
              • 4848
              Are you a designer of great functional models? Become a member of the worlds best designers GANG now! Contact: gang@3dlabprint.com NOTE: 3DLabGANG section contains independent creators products. 3DLabPrint takes no responsibility for the contents.
              RC, Thank you. The STL files are from 3DLabsGang, about $10 USD. The P&W R-2800 Wasp file is for their 3DP Corsair. The files are very scalable. I used 77% for my Prusa Mk3 set up using Prusa Slicer. Best, LB
              • EA-6B Geek
                EW Misfit
                • 485
                • South Central Ohio
                Beautiful day here in Ohio to maiden the Corsair. Light breeze, but right down the runway. Two flights with zero problems. I did flaps up takeoffs and landings on both flights, as per some of the sage advice in this thread. Seems happy flying that way. I did extend the flaps during the second flight, and they do not seem to cause any kind of pitching moment. I’ll try landing with them on the next outing. Kept the power on lightly until touchdown both landings, no bouncing! I think this will be an enjoyable airplane.
ID:	304557Click image for larger version
                  • 8223
                  Congrats on the successful maiden, she's a beaut!
                    • 4848
                    Beautiful day here in Ohio to maiden the Corsair. ! I think this will be an enjoyable airplane.
                    E6, Again, she's a looker and very nicely done, Sir. Best, LB
                    • e4dragongunner
                      Living the dream!
                      • 876
                      • Arlington Heights Il.
                      Nicely Done Brother!
                        • 2696
                        Beautiful looking Corsair (but then all of them are to me) and your field and runway look great. Glad you got out and had a successful maiden; sounds like you got this baby in the zone. Believe it or not, with each flight you'll love it even more. Can't give FW enough kudos on this model. :trophy:
                        • EA-6B Geek
                          EW Misfit
                          • 485
                          Thanks gentlemen! Definitely a winner for MRC.
                          • e4dragongunner
                            Living the dream!
                            • 876
                            Hey Marine.... Some questions....
                            Robart Wheels yes?
                            What Battery?
                            Where is your CG?
                            How much nose weight did you add?
                            Thanks man!
                            • EA-6B Geek
                              EW Misfit
                              • 485
                              Robart Wheels yes?
                              What Battery?
                              Where is your CG?
                              Thanks man!
                              Jay,
                              Robart 3.5” wheels,
                              HRB 6s 5000 50C battery,
                              CG per the manual,
                              did not have to use any of the nose weights.
                              S.F.
                                • 4848
                                Whistlers, (as in 'whistling death')... okay so it's our, she whose authority exceeds my rank and my "First Day We Met" anniversary next week and since I am a 3DP kinda guy, I thought I would print her something. Plastic is the 8th right? Ask your significant other for me.
                                Anyway, pictured below is what I giving her.
                                She is the "Lucky Girl" (LG). More when there is more. Best, LB
                                  • 2696
                                  Click image for larger version  Name:	IMG_0616.JPG Views:	0 Size:	104.5 KB ID:	304718
                                  OMG, I just knew this was coming. This is the "Modification of the Century"!! :trophy: I suppose you're also going to figure out how to program them to automatically open wide during take-off and climb, then close during cruising and landing. Possibly tied into your on board computer system? Although after seeing your anniversary present, I have a sneaky suspicion Tams may shut this down immediately for an extended period ! Maybe March Mayhem 2023. BTW, asked Ana what is supposed to be given on each specific anniversary and she told me every one of them needs to be something with diamonds. I don't know, but somehow that just doesn't sound right, but I don't think I'm going to argue.
                                    Elbee commented
                                    Editing a comment
                                    Dude, what do you possibly mean, it's a necklace, yeah, it's plastic, but it's cute, right. Ask Ana. LOL
                                  • 8223
                                  Right Hugh Wiedman? How could we not see this coming from the Scale Maestro himself. You son of a gun Elbee I'm going to be refreshing this thread now far more than one man ever should just to see your progress. Cannot. Wait.
                                    • 4848
                                    Hugh Wiedman & Aros Guys it's jewelry for the "the patient one". What are you thinking? Best, LB
                                    • Wild Man
                                      • 526
                                      • Rapid City, S.D.
                                      Your work is Amazing Elbee. I have always thought it would be awesome to have these on a Corsair even if they were open all the time Scale Maestro Designer and 3DP genius OH I have a question can I have it LOL!!!!!! just kidding Sir
