    Originally posted by Delizar
    Yup, it is tough living here in Cali. Only 350 good flying days per year.
    Now you're just being cruel. LOL
    • Dewey H Lee
      WARBIRD JUNKIE
      • Apr 2015
      • 919
      • Fayetteville NC. US
      Some folks just want to be mean.LOL
      Dewey l
      • Beeg
        • 1335
        • Texas
        Getting closer! My Spitfires made it to Fort Worth last night. Only 250miles to go! Still showing Wednesday by end of day!
        • dkalwishky
          Warbird Lover
          • Sep 2015
          • 1382
          • Des Moines, IA
          I started putting the decals on last night and ran into a problem with the black stripe decals that go on the wings.
          I thought they were vinyl stick on decals like the insignia decals but I was unable to separate them from the paper so I thought they were water slide (like the nomenclature decals) but after soaking one I couldn't get it to budge. I messed with these for 30 minutes trying to figure out how to separate them and finally gave up and moved on.
          Hangar 9 has pin stripping tape in the 1/8" size that is needed so I'm going to pick some up at lunch from my local hobby shop.
          I have one of the decals at work and messed with it again this morning and finally got it to peel off the paper. Part of the decal has the sticky back and part of it still has a thin layer of paper attached to it where the paper split, it's unusable.
          It turns out that it does not have a clear piece on top like the insignia decals do which is why I was confused. The striping decals are literally a black stripe on paper. To get it off the paper you'll need to dig a little at the edge of the stripe and lift it. Think of it as pinstripe tape on paper.
          So this plane comes with three different types of decals. The stripe decals are not numbered so it took some trial and error to figure out which ones went where and one of them needs to be cut to and then used in two other areas to make the long ones long enough. Of course figuring that out was a waste of time since I couldn't figure out how to separate them from the paper.
          Two things that I think needs to be dealt with ASAP, posting a picture of the stripe decals with thier numbers so people don't waste a bunch of time (like I did) trying to figure out which ones goes where AND providing the decal placement sheet as a download like was done with the A-10. It would have been very helpful to have had this in electronic format so I could zoom in to better see placement.
          Overall my first impressions of this plane are good despite this decal problem.
          • ryramZ
            Pilot Ryan
            • Dec 2012
            • 814
            Todd, can we add to the pdf online a sticker placement diagram?
            Three different kinds of decals. Water slide, transfer/like Callie and let's say regular sticker type.
            It can be confusing. Sorry you had a time with it. I screwed mine up a little as well. I ran the pinstripe first on one wing so the roundel covers it anyway and now it's visible as a raised line under one wing insignia.
            Its best to plot out the course so to speak sometimes. I measured what I had and what I needed according to the diagram and went for it.
            Beautiful plane!
            • franky
              • 56
              Please let one of the early pilots give info about the 3 different decal sheet eg how to use them and which one, Before i (especially) screw it up :Confused: Thank you
              • downwindleg
                • 1279
                • Friday Harbor, Washington
                Yeah, mine's due the same day. Hope to have it ready to fly this Saturday. Brad
                  Got these from Alpha...Decal placement sheets...
Name:	Spitfire Decal placement.jpg
Name:	Spitfire --Wing Bottom.jpg
                    Haha, simul-post.
                    Here are additional close ups showing the wing text in greater detail.
Name:	Screenshot (312).png
Name:	Screenshot (313).png
                    • Beeg
                      • 1335
                      • Texas
                      So the nomenclature are waterslide, stripes are dry transfer and markings vinyl?
                      • dkalwishky
                        Warbird Lover
                        • Sep 2015
                        • 1382
                        • Des Moines, IA
                        Beautiful plane!
                        I messaged Aros (that might be Todd) and asked if this could be done. He was going to e-mail Alpha to see if he can get the files and then post them.
                        • dkalwishky
                          Warbird Lover
                          • Sep 2015
                          • 1382
                          • Des Moines, IA
                          I saw Ryan's post and then saw the later posts where the decal placement sheets have been posted. That'll teach me to not read all new posts before posting. :)
                          • ryramZ
                            Pilot Ryan
                            • Dec 2012
                            • 814
                            The water slides are thin and mostly stencils. Transfers are shiny that peels off Callie style and the regular vinyl simply peel off the backing and appear dull or matte from the start.
                            • franky
                              • 56
                              Whats the difference of dry transfer and vinyl? (its my first time with decals, my other planes were decals ready)
                              • ryramZ
                                Pilot Ryan
                                • Dec 2012
                                • 814
                                Regular vinyl you peel off the bottom and stick it on. Dry transfer you peel off the bottom stick it on and then roll off the clear gloss top layer and the desired decal remains.
                                • ryramZ
                                  Pilot Ryan
                                  • Dec 2012
                                  • 814
                                  Check this out around 13 minutes. The red triangle at the cowl is a good example of the dry transfer where the bottom comes off then the sticker gets placed and then the top clear layer is removed.
                                  • ryramZ
                                    Pilot Ryan
                                    • Dec 2012
                                    • 814
                                    Click image for larger version  Name:	 Views:	1 Size:	154.8 KB ID:	89265
                                    Battery 5000 6s Admiral all the way forward Click image for larger version  Name:	 Views:	1 Size:	53.3 KB ID:	89256
                                    Click image for larger version  Name:	 Views:	2 Size:	109.1 KB ID:	89261
                                    Click image for larger version  Name:	 Views:	1 Size:	79.6 KB ID:	89258
                                    Click image for larger version  Name:	 Views:	1 Size:	106.5 KB ID:	89262
                                    Click image for larger version  Name:	 Views:	1 Size:	55.8 KB ID:	89255
                                    • ryramZ
                                      Pilot Ryan
                                      • Dec 2012
                                      • 814
                                      Hey guys click the small pics for captions.
                                      • Beeg
                                        • 1335
                                        • Texas
                                        hehe...I'm giddy with excitement! Only one more day!
                                          • 7418
                                          LOLLOL;)
