I'm using a Talon HV in my 8S. I put a meter on it and its 5.8V. I haven't had any odd issues but only use the BB for retracts and lights.
Originally posted by Aros.MotionRC View Post
Can't wait to see all your mods! I too am waiting on Chris' centerburner. He must be backlogged pretty good. Hopefully #2 won't meet an early demise like the #1 so I can actually put it IN the jet by the time it arrives!
I did get the ARF +. Just added the power system from #1 into it and she's good to go. Guess who will be avoiding light poles like the plague on her maiden!
LOL
Originally posted by Evan D View PostI'm using a Talon HV in my 8S. I put a meter on it and its 5.8V. I haven't had any odd issues but only use the BB for retracts and lights.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
The only weird thing I found was when I first wired it I put a anti spark in with a resistor. When I used it the three flash light I added wouldn't flash and the ESC didn't do the 8 cell count beeps. The solid tip lights and the landing light worked and the ESC/ BEC did work as it was supposed to. I didn't like it and removed the anti spark. No issues since...
Originally posted by Drifty View PostPainted the rudder servos right from the start. also just installed the center burner afterburner. I think I`ll need it -17degrees with 25mph winds today. Great for flying!Freewing A10, F4, F22, Sebart Avanti S mini
I have a question for all Freewing F-22 8s version pilots, will this be
a good replacement for the stock 12 blade fan?...https://www.rc-castle.com/index.php?...+90MM+12+BLADE
Originally posted by john2kx View PostAny tips or tricks to the center burner install?
Any tips or tricks to the center burner install? Should have mine Thursday.
I also use a separate UBEC so I don’t have to deal with a 2S battery. I’ve done both... they all run 7.4v UBECs now. Don’t use anything with higher than 7.4v , ever. I also program mine to light at 80% throttle.
This is a 5mm collet mount so it will mount to the motor. But until you try it you won't know if it will fit in the shroud or haw many amps and watts it pulls. If you do try it please let us know.
Originally posted by AVIATOR DOM View PostI have a question for all Freewing F-22 8s version pilots, will this be
Originally posted by downwindleg View PostHey Todd, got Chris' centerburner in the mail today. Will do that and the airflow parts at the same time while I've got that bay open. Pulled the fan unit out and have to figure out how to remove the tail cone and replace with centerburner. Then wiring with the 2s admiral battery.:Cool:
Cool! Still waiting on mine. Check out the video I linked to a few posts back. Pretty easy install it looks like. I think I am going to go the 2S route as well versus UBEC. What size Admiral did you go with?
Originally posted by downwindleg View Post...
Working on Radarguy's streamlining pieces while everything is out. Could use a tutorial on that too.:Thinking: Got the spar teardrop in but having trouble fitting the other piece.:Confused:
Did you install the nose gear brace?
Frank :Goodbye:5 Photos
- Likes 3
