How's about you reuse some of that B-24 engineering and make a Dash-7? A bird that can take of in less than 1200ft at and land in as little as 800ft weighing more that 45,000lbs deserves to be made right? A true STOL aircraft, that's not some stripped down over powered Cub! I'm a little biased as I'm one of the lucky few that still gets to fly this tough old bird. Freewing would be the only company I'd trust to get it done right!
I would like to see a Rockwell B-1-B Lancer 4x70-90mm. Would be a great addition to the Super Scale Series and I would be the first to pre-order. I am sure this would be in the $1000 range but it would definitely set itself apart in the EDF market.Comment
Ya know I've refueled many of these. Brings back a lot of memories. I was flying a Pacer when I was servicing these things. There was an Airline called, "Air Pacific" that flew these between Bakersfield and San Francisco. They were brand new at the time. We got stuck with those guys right after the airline deregulation. Basically all the larger jets all pulled out of Bakersfield, IE United, and Hughes Air-west. Nice to see one of those, I later heard they didn't do to good because of the four engines. More fuel and more maintenance. But it was a heck of a plane for sure, and would make a nice model for sure.How's about you reuse some of that B-24 engineering and make a Dash-7? A bird that can take of in less than 1200ft at and land in as little as 800ft weighing more that 45,000lbs deserves to be made right? A true STOL aircraft, that's not some stripped down over powered Cub! I'm a little biased as I'm one of the lucky few that still gets to fly this tough old bird. Freewing would be the only company I'd trust to get it done right!
Best Regards
​​​​​​​WoodyComment
It's not fast, and the Dash 8 with only two engines that are more powerful albeit less maintenance, and with it's redesigned wing making it much faster took over the commuter market. The only saving grace for my bird has been it's STOL, it's off airport operation capabilities, and the fact that it uses the most prolific turboprop engine of all time the PT-6, making parts readily available. But our are scheduled to be retired in a few years, and that will leave only about 7 or 8 birds still operating worldwide with companies such as Air Tindy, Air Greenland, and Canada's Antarctic Survey. Every bird has it's day, end of an age for mine soon...
Best Regards
WoodyComment
PC, It a beauty for sure and would need to be at least 1400mm to do the "parachute modification". Welcome to Hobby Squawk. Best, LB4 Photos"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
I would still like to see Motion and freewing bring a F100 to the table. I know the flex is nearly out but that wouldn't stop other manufactures releasing the same plane in a different size. 80mm for me please.
Re Launch and update the eurofighter please, new style lightweight 80- 90mm class.
More commercial airliners please, prop or jet. There are some real classics that need to be explored in the RC market especially in the foam ready to fly sector.
More Micro foamies too please. Sub 500mm with gyro would be great.Comment
AMA#116446Comment
New to the forums...but have been in RC for a while. Some of you might have listened to me on the allthingsthatfly podcast back in the day. Anyway, I will always above all else wish for a 1700mm Flightline Sea Fury...big and detailed and with a 12S high power option. Also a 1700mm Zero. a 1700mm Dauntless would have to be purchased immediately as well.
However, with the newer stuff....the first company to release a new B-21 would be cool.
Also, how about some 1700mm Reno Racers? Czech Mate? (obviously) :-)
I would also HAVE to buy a 1700mm DH88 Comet. (that goes without saying)
I would love to you to do
Freewing
80mm Blackburn Buccaneer
80mm Sea Harrier FRS1 or FA2 (Doesnt need to hover just fly nice)
80mm Hawker Seahawk
80mm De Havilland Sea Vermont or a conversion kit for the vemon
Flightline
Junkers JU 87 Stuka with releasing bomb and provision for sound unit
Hienkel HE111
Fairey Swordfish 1600mm
Fairey Firefly MK1 and Mk5
Douglas A1 Skyraider
pretty please with cherries on top 😀😀😀Comment
Flight Line Wish List:
2000mm B-17G
1750mm B-25J
1600mm P-51B
1600mm A6M3 Zero (Zeke 32)
Freewing Wish List:
B1B Lancer Twin Whatever it takes
AMA#116446Comment
