Originally posted by Hardway
View Post
Sorry to toot my own horn here but given the circumstances of feeling like hot garbage after plowing her into a light pole I have to point out that on the flight before, I had the lowest pass I think I have ever accomplished on a jet. This is a screen cap of the video in the lowest point of the pass (no this is not takeoff footage)...
Even a broken clock is right twice a day! :Silly:
Originally posted by RRHandy View Post
You need to find you a new field to fly at, You put the spitfire on the roof there also. Sorry for the loss. :Crying:
Originally posted by downwindleg View PostHey Tom, I agree with Steve....great work! Is the hud screen clear or green like Steve's?
Here's a shot with the hood off.
Tom1 Photo
Originally posted by Aros.MotionRC View Post
Tell me about it! Unfortunately I don't have much options around where I live, hence why I fly at a school in the first place. The local AMA club has a short field hosted on an old garbage landfill complete with methane pipes ON the runway. Sigh.
Fortunately there is a club at Beale AFB in CA where I work. The runway is actually a non maintained road in a section of the base that used to be a German POW camp. All the buildings are torn down now and the street is basically roped off. I don’t like flying there because it’s usually really windy, always a crosswind, and there are inch wide cracks in the concrete. It’s still cool to be able to fly in winter time. Whenever I have “appointments” scheduled... that’s where I am :)
The field is actually on the Real Flight simulator V6.
I mounted the gyro under the battery tray and cut a small window in the tray to access the gain pot. Don't worry about the servo frequency. Factory default setting works fine.
I also set my pot to 10:00 as you mentioned. I also have gain on a Tx knob. Do you as well, or just do it through the Rx pot?
If it will make you feel any better, everybody has bad days. Here's my latest collection that includes at least one true crash n burn
Originally posted by Pogo View Post
Thank you guys! Brad, the HUD "glass" is clear plastic I covered with green transparent tape.,, which I also put over the hole that leads down to the cavity the light's in. I think Steve sourced green transparent styrene for his.
Tom
Help from you guys who are using the Spectrum AS3X programming
So if i decide to use the
At Motion RC we carry the largest selection of electric and gas powered radio control (RC) planes, boats, buggies, cars, helicopters, tanks, trucks, and much more. We also offer a huge selection of lipo batteries, chargers, ESCs, gas engines, motors, radios, and servos. Shop our lowest prices with free shipping.
for this jet. Its likely that ill need to get it programmed. I have a DX9. Can someone list all the accessories ill need to get this programmed for any particular plane. I see there are more than a few people going this route and i too like the AS3X performance with the EFLITE BNF models.
Also second question is the AR636 rx has a single satellite port. Do any of you know if the LemonRX/Admiral satellite is compatible with this RX? has anyone tried this and verified the signal integrity?
Originally posted by Pogo View PostIt's white Brad- the old landing light, left over as I went to duals. Why can't you plug in your LED's to test them?
Tom
Originally posted by tengarang View PostHelp from you guys who are using the Spectrum AS3X programming
Yes, the non-Spektrum sat will work.
If you need a .spm file for a similar plane I can send it to you. It’s basically completely setup, you just upload it into your TX via SD card. If you need help, let me know. I have 5 636s in use
- Likes 4
Originally posted by C17loadmaster View Post
All you need is a cable to connect to your phone or computer. There is also a Bluetooth controller you can use. So 3 different cables or options. You have edownload the app on your phone, or off the Spektrum website on a computer.
edit: i found this...for the computer, maybe this is the one ill need? https://www.spektrumrc.com/Products/...rodID=SPMA3065
acknowledged on the no. Spectrum satellite appreciate the confirmation.
Ill pm you in a bit after i get some work done in the office
appreciate all the helpful responses
