Sorry to toot my own horn here but given the circumstances of feeling like hot garbage after plowing her into a light pole I have to point out that on the flight before, I had the lowest pass I think I have ever accomplished on a jet. This is a screen cap of the video in the lowest point of the pass (no this is not takeoff footage)...
Even a broken clock is right twice a day! :Silly:
Tell me about it! Unfortunately I don't have much options around where I live, hence why I fly at a school in the first place. The local AMA club has a short field hosted on an old garbage landfill complete with methane pipes ON the runway. Sigh.
Thank you guys! Brad, the HUD "glass" is clear plastic I covered with green transparent tape.,, which I also put over the hole that leads down to the cavity the light's in. I think Steve sourced green transparent styrene for his.
Here's a shot with the hood off.
Tom1 PhotoComment
I’m in the same boat. I fly off a golf course surrounded by trees and sand traps. I stopped flying at the school when I got into jets.
Fortunately there is a club at Beale AFB in CA where I work. The runway is actually a non maintained road in a section of the base that used to be a German POW camp. All the buildings are torn down now and the street is basically roped off. I don’t like flying there because it’s usually really windy, always a crosswind, and there are inch wide cracks in the concrete. It’s still cool to be able to fly in winter time. Whenever I have “appointments” scheduled... that’s where I am :)
The field is actually on the Real Flight simulator V6.
Thanks again for the info RCjetdude-- I also ended up mounting under the battery tray as far back as possible -- but did not think about having access to the first pot. Took the tray back out and made that change!I mounted the gyro under the battery tray and cut a small window in the tray to access the gain pot. Don't worry about the servo frequency. Factory default setting works fine.
I also set my pot to 10:00 as you mentioned. I also have gain on a Tx knob. Do you as well, or just do it through the Rx pot?Comment
If it will make you feel any better, everybody has bad days. Here's my latest collection that includes at least one true crash n burn
My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8wComment
Help from you guys who are using the Spectrum AS3X programming
So if i decide to use the
for this jet. Its likely that ill need to get it programmed. I have a DX9. Can someone list all the accessories ill need to get this programmed for any particular plane. I see there are more than a few people going this route and i too like the AS3X performance with the EFLITE BNF models.
Also second question is the AR636 rx has a single satellite port. Do any of you know if the LemonRX/Admiral satellite is compatible with this RX? has anyone tried this and verified the signal integrity?
All you need is a cable to connect to your phone or computer. There is also a Bluetooth controller you can use. So 3 different cables or options. You have edownload the app on your phone, or off the Spektrum website on a computer.Help from you guys who are using the Spectrum AS3X programming
Yes, the non-Spektrum sat will work.
If you need a .spm file for a similar plane I can send it to you. It’s basically completely setup, you just upload it into your TX via SD card. If you need help, let me know. I have 5 636s in useComment
Whistle ground and flight testToo windy for me to do slow flaps down flybys like I wanted, maybe next time. I'm pretty happy with the sound. Link: https://www.amazon.com/gp/product/B079HG...Comment
Thank you, is it possible to share the link to this cable i see a few of them and just want to be sure i get the correct one.
edit: i found this...for the computer, maybe this is the one ill need? https://www.spektrumrc.com/Products/...rodID=SPMA3065
acknowledged on the no. Spectrum satellite appreciate the confirmation.
Ill pm you in a bit after i get some work done in the office
appreciate all the helpful responsesComment
I wish that Freewing would do away with gluing in servos and go back to installing servo trays with covers like on the F-15. F-22 Raptor a new model with old gluing methods.Comment
As was stated in reply on RCG, F-22 servos all have pockets and covers except for the rudders which are glued (this was necessary as there is not enough foam to have the pockets), and the elevator servos which are screwed in and not glued.PatComment
Does anyone know how to change the timing of the stock 130A ESC from the 6S version F-22? I couldn't find the ESC manual on Motion's website. I'm switching the EDF to a Wemotec Midi Evo and the inrunner motor requires low timing.Comment
