New here. I have had plans for about 3 weeks. Waiting for my battery. Also ordered livery from Callie and waiting for them to get here to finish this beast
One of the fans smelled like it was burning when the jet came out of the box. Although it behaved well I ordered another and changed the old one out for thes...Comment
Ricky, that's a super fun livery! I was looking into that one when I first started searching for unique liveries. I'm glad Callie now has it in her arsenal... Minion Airlines, where instead of chips & peanuts they serve Banana & Potato!!! lolComment
Which one did you go withComment
Long time listener, first time caller. Hi all, you've probably seen me spamming content around the traps but thought I'd join the fun on the official forums too.
Have about a dozen flights under my belt on the AL37. Fairly limited access to the flying field, combined with difficult (incredibly hot) weather here and other planes to fly mean she hasnt seen as much action as she would like. Absolutely adore this jet - for the record, seeing the video of james doing grass ops was the instant I clicked buy, so pleased that freewing continues to look after those of us who dont have access to tarmac. Not an everyday flyer for me as it occupies a lot of space in the ute - more a 'special occasions' jet for goldilocks temps and calm winds.
Anyway, here's how she came up in a special 'movember' Qantas livery (reference pic below). Part of the project involved learning the ropes on a vinyl cutter and doing my own decals. Another little twist on the plane was designing and printing some 737-800/NG style winglets.5 PhotosComment
AMA#116446Comment
Hi Guys im from Mexico And Already bought this baby but i want to make this plane from AEROMEXICO airlines ,somebody has the decals designer contact for this plane ?
regards .Comment
Nice! Go to Callie Graphics with images of the Livery you are after, she will sort you out.Comment
Has anyone had motor bearing problems? Estimated number of flights on the bird = 300. My right motor has gradually increased noise output over the last few weeks. It is now so loud, even at 1/3 throttle at high altitudes, it sounds like a screaming banshee. No more flights until the replacement motor arrives! No vibration, no visual defects on the fan blades, not running hot...cool to the touch after a flight. I even set the timing on the ESC to different values to see if that had any effect. It did not. I assume the increasing sound means a total bearing failure is imminent. The only thing I have noticed is that the noisy right engine spins down a tiny bit faster than the still-quiet left engine when I chop the throttle.
By the way...here is the link to the ESC programming manual from the MRC webpage https://www.motionrc.com/products/fr...brushless-escs The manual is here: https://cdn.shopify.com/s/files/1/10...iles/fwesc.pdfComment
Thanks - I checked the fan-on-shaft tightness...all rock solid. My 90 mm F-4 has a ton of flights on it as well, and has had no issues with its motor bearing. Just curious if the 70 mm bearing going bad is atypical from what others have experienced on other planes powered by this motor.
Here are some photos of the RF choke installation on the AL37. So far, no radio glitch issues at all with these installed. Like I said before, it couldn't hurt.
