  • avanti127
    • Apr 2018
    • 96
    Originally posted by jrfjrf
    The various transformations here are incredible! I could never compete. But I bought the decorated version, then decided that I wanted something more scale looking. JetBlue has all different vertical tail decorations, but most of them are blue, so I thought that would be the easiest to do. I converted the white triple bar Motion logo on the tail to the corporate colors and then to make the darker blue stand out, I pin striped it in gold. Just though you guys might enjoy seeing it.
    I also eliminated the lower wing tip extensions because of ground clearance issues. And I thought they looked a little Star Warsy. ☺
    Great job man. You did well! I actually like the Vortex Wing extensions.
    • avanti127
      • Apr 2018
      • 96
      Originally posted by killickb
      Be interested in your set up Avanti127. Using two transducers? I have a system in my Corsair that is coming out, you might convince me to install in my 737 if she sounds better than stock, which isn't bad at all.
      I installed the sound system tonight. There is plenty of room for everything and as soon as I can get the photos uploaded U will do a review. Going to fly it on Sunday and let you all know how it sounds in the air.
      Very impressed with the quality of this system.
        • 8228
        avanti127 Love the Boeing livery! Was wondering when somebody was going to do that. Great job!
        • MikeT
          Here......Hold my beer.
          • 1060
          Originally posted by avanti127
          Just take your time. I had a lot of taping off and I used the 3m blue tape and no issues.
          Nice.
          Mike
          • avanti127
            • Apr 2018
            • 96
            Finally got some pics from the field.
            • MikeT
              • 1060
              Sweet.
              Mike
              • avanti127
                • Apr 2018
                • 96
                Here is the install photo of the SoundWave 3 installation. For the review: The sound quality is excellent. Under cruise it sounds awesome. However under full power the is a mix sound between the real fans and the sound wave generated jet motors. The FW fan are louder than I had expected they would be. Maybe I can build a box around the sound generators that may help increase the volume which I had turned up fully. It does sound awesome though and the startup/shutdown is really good. Maybe if generators were mounted in the wing they would provide a higher lever under power. All in all I would give it 4.5 stars. Quality is really good. If anyone has any suggestions I would be all ears.
                  If you could mount them directly to a thinner wall of the fuse it may help considerably. On my A-10 I mounted two 4 Ohm exciters in series to the foam in the belly of the fuse under the wing. Foam is about 3/8" thick and they were very loud.
                  • avanti127
                    • Apr 2018
                    • 96
                    The fuse is too round to mount them directly to the fuse sides that's why I mounted them to the sides and kept the foam to the minimum thickness.
                      • 8228
                      avanti127 are you sure that first pic isn't the full scale on final?
                      • avanti127
                        • Apr 2018
                        • 96
                        LOL, no it's our home field.
                        • Model Sounds Inc.
                          • 13
                          • Ottawa, Ontario, Canada
                          The exciters work by vibrating the surface to which they are attached which in turn vibrates the air. So if the material is too thick it won't flex enough to make the sound extremely loud. A foam thickness of between 3-5mm is ideal. Is it possible to mount one in each wing?
                          • Model Sounds Inc.
                            • 13
                            Here is the install photo of the ShockWave 3 installation. For the review: The sound quality is excellent. Under cruise it sounds awesome. However under full power the is a mix sound between the real fans and the sound wave generated jet motors. The FW fan are louder than I had expected they would be. Maybe I can build a box around the sound generators that may help increase the volume which I had turned up fully. It does sound awesome though and the startup/shutdown is really good. Maybe if generators were mounted in the wing they would provide a higher lever under power. All in all I would give it 4.5 stars. Quality is really good. If anyone has any suggestions I would be all ears.
                            Actually, the board is called ShockWave 3, not SoundWave 3. Thanks.
                            • avanti127
                              • Apr 2018
                              • 96
                              David, my foam is 3mm or less in places but there is an air gap to between it and the fuselage foam so I think this is the issue. I am going to remove that section of foam and contour it as thin as I can to radius the fuse then glue that in to the inside of the fuse. Hoping that will do the trick and I am sure it will improve everything.
                              • ridgerunner
                                • Nov 2017
                                • 275
                                • Central Utah, USA
                                Will the AL-37 fit the (large and heavy - i.e. 866 gm) HK Panther Graphene 5000 mAH 6S battery? (I'm guessing that it might since it can handle the 6000 mAH Admiral pro @ 844 gm).
                                If not, is there another aircraft you might recommend that would handle them? (These are shorter, fatter and heavier than my other 5AHh 6S batteries)
                                I bought two of these thinking they would fit in my new Venom 2, but alas, they don't fit! D'oh!
                                  • 8814
                                  I'm going to be using the Revolectrix 5000mah, 6s battery weighing in at 886g. That's what I used to balance it. Mid-800g batteries in the 5000mah size is not unusual. It's been said that with a little battery bay modification, this plane could take 2 x 5000mah batteries.
                                  • tp777fo
                                    • Apr 2018
                                    • 16
                                    Ready for test flight. May the force be with you!
                                      • 8228
                                      And with you! Looks great!
                                      • vduniec
                                        Hobby Squawk Pilot
                                        • 314
                                        Great job! Good luck on the maiden.
                                        • urrl
                                          • Oct 2013
                                          • 505
