  • sunbeam
    • Oct 2022
    • 15
    • near Hamburg, Germany
    Airguardian : Yes, you are right
    The 6S 7000er are from my AF-Models L-39 (12S) and shall also be flown in my yet to build Skymaster A-10 (2x 12S). I did not want to buy new packs
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1676
      • Catalonia
      I mean, the plane will fly with those, you can definitely use them, my comment was maybe too harsh. But I strongly believe you'll have a better experience with this plane running a lighter setup. From two 850g packs to two 600g ones you have half kg of extra thrust margin. And lower wing loading is also very welcome :)
      • sunbeam
        • Oct 2022
        • 15
        Yes, I know what you mean 👍 I will see how I like flying and then think if I buy a Set of 4000er or 4500er
        • sunbeam
          • Oct 2022
          • 15
          I opened the gear and lubricated everything - the whole mechanic moved fine without resistance. But even in that open condition the gear suddenly stoped moving without any reason. There are microswitches for the endpoints inside the gear. So I guess there is an electronical problem which sends a "false stop-signal".
          I will keep it for spareparts and wait for the new one. Hope the screws still hold tight.
          • sadams714441
            • Jan 2022
            • 5
            Just ordered the F4. What receiver is a good choice. Using NX 8
              • 5401
              Why post in this thread?
              Any 6 channel or more DSMX receiver. I like to separate steering from rudder so that’s 7ch. If you want an internal gyro like AS3X that changes what you need. I use Orange receivers and satellites. I don’t use gyros.
              Really if you need to ask there’s a issue.
              • heisteff
                • Jun 2019
                • 16
                • Neuburg Germany
                Hi folks
                roughly one year of work, here is my version of the mig
                greetings stefan Click image for larger version
ID:	360169Click image for larger version
ID:	360170Click image for larger version
ID:	360171Click image for larger version
ID:	360172Click image for larger version
ID:	360173Click image for larger version
ID:	360174Click image for larger version
ID:	360175Click image for larger version
ID:	360176Click image for larger version
ID:	360177Click image for larger version
ID:	360178Click image for larger version
ID:	360179Click image for larger version
ID:	360180Click image for larger version
ID:	360181Click image for larger version
ID:	360182Click image for larger version
ID:	360183Click image for larger version
                • DCORSAIR
                  • 1918
                  • Selma, Ca.
                  Originally posted by heisteff
                  Hi folks
                  Looks awesome...
                    • 2709
                    heisteff INCREDIBLE WORK, love the air brake, cockpit, rivet detail and of course the operable canopy. First Rate!!! :clap:
                    • sunbeam
                      • Oct 2022
                      • 15
                      Brilliant work! It looks excellent! 👍 I just start to setup/rebuild mine, but I think I will not achieve your looks 😄
                      Did you change the servos? What about your power supply? I will use a Powebox Pioneer together with two 12A BEC from two ESCs from YGE.
                      Greetings, Kai
                      • heisteff
                        • Jun 2019
                        • 16
                        • Neuburg Germany
                        Thanks happy you like it,
                        to Kai; the elevons are comlettly rebuild to scale mechanics so the axel is going halfway into the fuse, there are operated by HS 645 MG -Servos, power is supplied by the BEC of the Controllers. but i might give it a external bec since i need a little bit of weight in the nose (due to one 16000 flight battery)
                        Stefan
                        • kallend
                          • 1877
                          I'm not quite sure what you mean by that. Did you change the angle of the taileron rotation axle to be swept back, like the real thing?
                          If so, that should relieve the load on the stab. servos. (See, for example, posts 2712 and 2842 in this thread).
                          I believe Airguardian reached the same conclusion.
                          • heisteff
                            • Jun 2019
                            • 16
                            • Neuburg Germany
                            yes thats what i did, i dont know if it really takes any load of the stab, since the axle is at about 25% MAC and there is quiet some more wingarea in the "wind" then at the stocksetup (axle in the middle). so i thought more powerfull servos wont hurt, just by my feeling. most importend improvement by that mod is the stiffnes of the tail i think
                              • 8814
                              @heisteff​ Can you tell us and show us what you did to get the airbrakes to work?
                              • heisteff
                                • Jun 2019
                                • 16
                                • Neuburg Germany
                                ok for the airbrakes, it´s a little bit like on t33jetmans pictures. i use one 3.5 kg servo instead and a ballink leverage, printed out some servoarms ( bent forward somemore then normal). the "brakepedals" where shaped / cut out inside to fit the parachutetube (3d of thingivers) and after the hinges where done i glassed them with a 23gr fiberglas. the bottompiece (about 15 cm) that was cut out screws back on so you can access it for maintenance and for my elevators i attached some pics too. Click image for larger version
ID:	360264Click image for larger version
ID:	360265Click image for larger version
ID:	360266Click image for larger version
ID:	360267Click image for larger version
ID:	360268Click image for larger version
ID:	360269Click image for larger version
ID:	360270Click image for larger version
ID:	360271Click image for larger version
ID:	360272 the white stick shows just about the correct lenght of the axle. hope it helps
                                greetings stefan
                                  • 8814
                                  Your airbrake set up is very intricate. I don't have the talent to do it. I was hoping that Motion was going to bring out the airbrake kit when they brought out the vector thrust nozzles.
                                  Do you know if the airbrakes actually help reduce the ground roll after landing? Being such a heavy plane, my MiG rolls "forever". Airbrakes or reverse would really be of help.
                                    • 5401
                                    Motion doesn't "bring out" things. Free Wing does.
                                    I'm 100% sure it helps as when I use crow and rudder air brakes on landing it very much shortens out my roll out.
                                      • 8814
                                      You're correct, but the point still remains. That airbrake "kit" was supposed to come about the same time as the VT nozzles. I wonder what happened to the airbrakes.
                                      I may have to do the rudder brakes in lieu of those airbrakes. I use rudder brakes on my Flex Pirana and they work extremely well but that's on a belly lander, so speed decreases long before touchdown.
                                        • 5401
                                        I don’t remember FW or Motion saying an airbrakes was in the works.
                                        the issue with rudder airbrakes is channel count as you need two additional channels just for that, steering and each rudder needs its own channel. Add the additional channels that TV requires and it adds up.
                                          • 8814
                                          Not based on anything "in the works". It's based purely on what Alpha, C. MoMo and wolpertinger posted over 2 years ago.
                                          Originally posted by Alpha
                                          If enough people order the MiG-29 PNP and ARF and we think the model has legs to support more aftermarket upgrades, we might consider producing other things such as an upgrade air brake set, also Sold Separately, shown below. But candidly, we're waiting to see how to model itself takes off before over-committing to more upgrades. We've seen it in the past where most pilots end up flying/loving the stock PNP model (which is great!) and the upgrade market fizzles.
                                          We'll see what the community does.
                                          Click image for larger version Name:	Prototype Air Brake 3DPUP Upgrade Option (not in the PNP).jpg Views:	0 Size:	112.4 KB ID:	267157
                                          Originally posted by Captain MoMo
                                          Amazing model. Look forward to my maiden! Would love to get the upgrades for TV and air brakes. Please let us know when and where to order.
                                          I read earlier that air brakes could be an option upgrade. Is this still being considered?
