    • 5401
    Memory jogged…
      • 8814
      At least yours can be jogged. Mine is often times in a state of permanent hibernation. :sleeping:
      • heisteff
        • Jun 2019
        • 16
        • Neuburg Germany
        Your airbrake set up is very intricate. I don't have the talent to do it. I was hoping that Motion was going to bring out the airbrake kit when they brought out the vector thrust nozzles.
        Do you know if the airbrakes actually help reduce the ground roll after landing? Being such a heavy plane, my MiG rolls "forever". Airbrakes or reverse would really be of help.
        Hi I don't really know yet if they do slow down the plane, but I would think down to a certain speed they would. She hasn't flown yet, that day was for pics and runway tests. My intensions are more for inflight use of the brakes (we'll see). It has nothing to do with talent it is just about patients making mods like that (about two weeks from the idea to finish, same with the cockpit ore the elevators)
        stefan
        • pullupnow
          Pilot
          • 70
          • Long Island NY
          [QUOTE=heisteff;n360168]Hi folks
          roughly one year of work, here is my version of the mig
          Wow!!
          Masterful work!
          enjoy flying her.
          Thanks for sharing
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1676
            • Catalonia
            Originally posted by heisteff
            the white stick shows just about the correct lenght of the axle. hope it helps
            Outstanding work!
            Now the stabs deflect in a proper scale fashion!
            Could you please send some pics of the model with the stabs deflected pitch up and pitch down? :D
            That configuration should indeed reduce the stress translated to the airframe, the stress seen by the own stab and the torque around the shaft that a servo would have to overcome. But since you didn't change the servo angle and it still actuates parallel to the airplane's longitudinal axis, that kinda spoils the mechanical advantage of having the correct scale axis.
            Ideally the servo linkage should act perpendicularly to the shaft. That said, the whole thing at least should translate to a more robust construction, more scale looking and more accurate flight dynamics to the full scale jet :)
            • heisteff
              • Jun 2019
              • 16
              • Neuburg Germany
              Hi
              here are some pics of the stabs (maximum deflection/way to high for in flight of course). yes the servo is not positioned optimal, but the problem is the space in the tailsection, the two balllinks help a lot to keep the "pushforce" straight (see pics). For the maingeardoors i have not had a idea to make it work without "wheelscratching" them, but who knows.
              Stefan
ID:	360843Click image for larger version
ID:	360844Click image for larger version
ID:	360845Click image for larger version
ID:	360846Click image for larger version
ID:	360847Click image for larger version
ID:	360848Click image for larger version
              • fredmdbud
                • 451
                Outstanding work!
                Almost - there's some anhedral to the stabilators, too.
                There's a "stump" portion towards the front to provide clearance due to this angle.
                • fredmdbud
                  • 451
                  But would he be willing to do the powered-descent-with-flaps scenario?​
                  • Wild Man
                    • 526
                    • Rapid City, S.D.
                    Well I finally decided to go ahead and get one. After getting it out of the Box and Inspection done. All I have to say is What did I wait so long ?? Plan on painting this one RED' WHITE & BLUE. I have already started sanding the horizontal stabs
                    • Wild Man
                      • 526
                      • Rapid City, S.D.
                      I knew if I started, I would be up all night. I started with the tail, ( Horizontal stabilizer's ) So far, so good. I was up all night.
                      Click image for larger version  Name:	D2C1B007-752F-48E9-BF8D-0ADA54607F9C.jpg Views:	0 Size:	102.6 KB ID:	361603Click image for larger version  Name:	1A45CA37-9735-4533-B484-36FFBA7B983C.jpg Views:	0 Size:	104.5 KB ID:	361604Click image for larger version  Name:	4B03AD20-4FB0-4969-BE60-20EFC641EB5E.jpg Views:	0 Size:	88.1 KB ID:	361605
                      • ElCid
                        • Oct 2017
                        • 114
                        Rumor has it Santa is bringing me one to add to the hanger. It appears that between MotionRC and most of the mods seen on this forum, it's become a very nice airplane. My question is can you just cruse around with it like i do with my F22?
                          • 5401
                          Yes but if you get the TVs you won't.
                          • GliderGuy
                            • 1412
                            And if you don’t get the TV, it may not last you long.
                              • 8814
                              These are the greatest "one-two punch" replies I've ever seen here. :zap:​
                              • GliderGuy
                                • 1412
                                We’re being forthcoming!
                                • kallend
                                  • 1877
                                  Couldn't want a better image than that to see why the elevator servo loads are high on this model.
                                  • ElCid
                                    • Oct 2017
                                    • 114
                                    Well it's coming from Santa but the TVs I ordered myself.
                                    • Wild Man
                                      • 526
                                      • Rapid City, S.D.
                                      Kallend So you tell me?How does .008 kg. going to raise the load substantially on the new heavier servo's for the horizontal stabilizers? Stock stabilizer .058 kg. Sealed sanded and painted stab. .066 kg. That is only an added weight of the finished stab just a tad over 1/4 oz. by .003 kg.
                                      • HangarQueen
                                        • Feb 2019
                                        • 142
                                        I think (I'm sure) he's referring to the position of the axis of rotation, so far forward, i.e. there's a LOT of surface behind the rotation point, requiring very high torque from the servo to move this surface.
                                          • 5401
                                          Exactly. He's not talking your paint, he's talking the pivot point. And use grams instead of minute kg.... 0.003kg is 3g.
