use a spare channel and split the nose wheel steering off on its own ( I unplugged from the rudder board and plugged into channel 7 on my receiver). then the standard rudder trim tab only affects the drag rudders.
On my Jeti DS-12, I use the trim knob 8 to control nose steering trim. I have the rudder stick control the nose channel. On Jeti, setup a logical switch for landing gear switch and nose steering channel, so the nose steering is deactivated when gear is stowed. I use the dual rate and expo setup on channel 7 to independently set the nose wheel values, and not impact rudders. Have done this on almost all my aircraft.
***** update - i found the video that will help - better way to setup the nose wheel to not move when stowed with rudder stick *****
Set dual rate switch for steering on your retract switch. When gear is down, steering will be set to 100% rate, and 100% expo. When landing gear switch is in gear stowed position, set Steering rate to 0% and dual rate 0%. Then steering will not move when gear is stowed.
