  • rc_heli_flier
    • Oct 2019
    • 19
    Hi guy, I just joined here last week and got my A-10 then as well. One thing I noticed with mine is that it has all water slide decals now instead of what is shown in the motionrc video where some are dry transfer. That means my cockpit window decal with the yellow stripe is also water transfer. Problem is once its applied the center portion covers the window and makes it opaque. Perhaps I'm just not understanding how to properly apply that decal, but is that how its supposed to look now? Seems weird to me to cover the window like that. The only solution I see is to remove the part over the window by scoring around it now that the thin yellow line is affixed to the window. The older dry transfer would have worked great since you would just peel the middle section off after the thin yellow line is affixed. Am I missing something or has Freewing made an error with this decal now by going to all water slides?
      • 4819
      RHF, Firstly, "Welcome to Hobby Squawk", and secondly, no, you're not missing anything. As for the waterslide decal, I cut out the center area, before I applied the decal and used decal set to place it. One solution might be to cut it out in the center, though I would use 'yellow pin stripe' after removing all of it. Just a thought. As I remember, weren't there 2 different 'window decals'? Anyway, I have not really solved your issue, but glad you are here. Best, LB
      • rc_heli_flier
        • Oct 2019
        • 19
        There was only one window decal I saw, Think I'm just going to go ahead and remove. Too much work to cut it out now, I'd probably just mess up the canopy anyway. lol
        • Wobisch
          • 83
          • Merenschwand, Switzerland
          Hi Pilots,
          Since I distroyed the black plastic part of many gear mechanics I'll exchange the metal plate by a thicker one. The new ones are made of steel. Wonder how that works… Of course I could also improve my landing skills...That would't be a bad idea either.
          • thisguy65
            • 509
            Does a magnet stick to it?
            Planes
            • Wobisch
              • 83
              probably yes. would that be a problem for the gear mechanics?
              • t33jetman
                • 515
                  I don't foresee a problem with the steel plates impeding the retract motor's operation, or the other ferrous elements of the retract.
                  • Wobisch
                    • 83
                    Thx. I'll gonna test it then.
                    • tjkav8tor
                      • Oct 2019
                      • 5
                      • Dawsonville, Georgia
                      Good morning Folks,
                      I'm new to the forum and have a A10 90mm setup question that's been daunting for me to solve, any of your expert guidance is much appreciated.
                      I'm relatively new to EDF's, my Freewing A10 is my first EDF jet, and the aircraft is just great. I've been flying her on the stock 80mm setup with great success. Recently I've converted to the 90mm setup and having problems with the left hand motor.
                      My setup follows; Efflux fan units, custom 1450kv motors, Castle Edge 100amp ESC's with default setup (both with red internal BEC power lead disabled), external 20amp Castle BEC with default setup, batteries are Admiral 5000 mah, 50c 6S.
                      This setup bench ran just fine and had the default ESC calibration performed without incident. First flight was at reduced power getting a feel for weight & balance, flap deployment and landing approaches. All went according to plan. Second flight on takeoff I'm accelerating up to full throttle, break ground and encounter a sudden yaw indicating a loss of power, performance was dramatically affected but with the application of opposite rudder I'm able to limp it around the pattern and after 4 approaches decide it's time to commit. Landing was not the best and snapped the nose gear pin in the process. Once I'm back in the pits I perform individual run ups on the motors and note the left hand motor is cutting out at full power settings, right hand motor operates fine. Further inspection shows there is nothing obviously wrong with wiring or the ESC itself, motor visually appears fine. The one difference between the left and right power setups is the external Castle BEC is attached to the left hand motor and power setup. I can't imagine there is a significant battery load being placed on the battery from normal flight to disrupt normal full power motor operations, but who knows, perhaps this is the case. Any thoughts on how to troubleshoot this problem further? Am I making a mistake by running default setups on both the motor and external ESC's? Any other ideas?
                      Any and all help is much appreciated, thanks all!
                      TJ
                        Originally posted by tjkav8tor
                        Good morning Folks,
                        TJ
                        tjkav8tor Hi TJ, welcome home to Hobby Squawk! I'm impressed that our big A-10 is your first EDF! You sound like you have much more experience than that statement would seem to imply. You mentioned that you're running "Efflux fan units"... I assume you mean fan units you bought from Gary at EffluxRC? He's a friend of mine, good guy. Gary sells various fan units, but by your description I am assuming you have either the Jetfan (carbon) EDFs or the Wemo (FRP) EDFs. I'm unclear as to what the "custom" means for your 1450kv motors. He usually uses good motors like HET.
                        Regardless of your actual setup, by the description of your issue, I would begin troubleshooting by first putting a wattmeter on your two setups and comparing them.
                        I'm also unclear as to what you mean in the statement "running default setups on both the motor and external ESCs?". You're running anything but what I'd consider "default". Default would be the factory recommended Freewing 80mm setup, or in your case, the Freewing 90mm setup, with Hobbywing ESCs to match. But you're running a Jetfan or Wemo EDF, a "custom" motor, and Castle ESCs. If by "default setup" you mean disconnecting the red wire and instead running a single 20A Castle UBEC with its stock settings, then I would say the disconnected red wires are correct protocol, but the UBEC's "stock" settings may be something you look into further. Not knowing exactly what motor you have, it's impossible to give concrete advise on the UBEC's settings, but I would say look into your motor timing advance and use settings that match your motor's type. Assuming you purchased from Gary at EffluxRC, he'd be the best resource to advise what settings work best with the power system he sold you. And tell him Alpha said hi!
                        By the way, I was project leader for this A-10, so between myself and the many experience A-10 drivers here on Hobby Squawk, I'm sure we'll be able to help you get to the bottom of this, so you can get back to the business of enjoying flying your Freewing A-10!
                        • tjkav8tor
                          • Oct 2019
                          • 5
                          Thanks for the warm greeting and such a quick reply Alpha, I appreciate your help! As you guessed I'm a 50 year RC guy with lots of experience in flying/building/racing/IMAC...just not much with EDF jets or electric power setups. So I'm a 'getting older dog' acquiring new skills. :-) I can tell you that you and the team did a great job with the A10, it never fails to impress me and the crowd who always stops to watch a flight or three!
                          So to the details, and to clarify further, I'm running the Jetfan units and my mistake, an 1865KV motor which I believe Gary speced the HET units. By "default setups" I am referring to the Castle ESC's and the Castle Pro 20amp UBEC settings. As I look into the Castle Pro UBEC further I don't really see anything that would affect the Castle Edge ESC performance. My method for attaching the UBEC to the receiver follows their recommendations. And after further evaluation on the bench this morning the left motor runs well when cold, but after running on the bench for a minute or so and then retesting the high throttle setting 'cut outs' begin. Given that I don't have a wattmeter (yet...) further troubleshooting may have to wait a bit to get those readings. I'll also reach out to Gary to see if he has any ideas. Any other thoughts while I'm troubleshooting?
                          Many thanks again for your insights, I think I'm going to like it here!
                          TJ
                            • 4819
                            Thanks for the warm greeting...and I think I'm going to like it here! TJ
                            TJ, Welcome to "The Squawk" and I believe you will, Sir. Oh, and the Freewing A-10 was my first EDF as well after 20+ years out of the hobby. I love it. Best, LB
                            • didier n
                              • Oct 2019
                              • 109
                              • leopoldsburg Belgium
                              Hi all,
                              I'd like to share some photo's of my A 10 in the JAWS sceme, it kind'a special...you like it or hate it...
                              it took a serious amount of airbrush time...
ID:	217792Click image for larger version
ID:	217793Click image for larger version
                              Enjoy!
                              Didier
                                • 4819
                                Originally posted by didier n
                                Hi all, I'd like to share some photo's of my A 10 in the JAWS sceme, it kind'a special...you like it or hate it...Didier
                                D, Bravo Zulu, Sir. Just outstanding work. Best, LB
                                  TJ
                                  Hi TJ, your left motor running well when cold but cutting out when on high throttle isn't a good sign. Keep in mind, I would encourage not running an EDF on the ground at maximum throttle for longer than 20 seconds, maximum. The fan can't unload fully and that may skew your numbers for heat exchange and efficiency, and obscure (or exacerbate) whatever root cause is affecting your motor. Certainly follow Gary's guidance on this one, he's the expert.
                                  My recommendation remains to get a wattmeter --it will give you actual data from which you can then troubleshoot more effectively and be able to eventually verify your results' consistency.
                                  Hi all,
                                  Enjoy!
                                  Didier
                                  I LOVE IT
                                    Second that!!! Awesome stuff!!!
                                    • didier n
                                      • Oct 2019
                                      • 109
                                      Thank you all for the nice comments! The A 10 is a great jet and a joy to fly...
                                      Therefore i made a second one.... this time the grey flipper sceme...
                                      Click image for larger version  Name:	74209775_446796169526983_6008226791141933056_n.jpg Views:	0 Size:	165.3 KB ID:	217904
                                      Click image for larger version  Name:	71638548_525202724719524_7678991072403390464_n.jpg Views:	0 Size:	218.1 KB ID:	217900
                                      Click image for larger version  Name:	75262296_800880313678459_8787823260248047616_n.jpg Views:	0 Size:	243.1 KB ID:	217901
                                      enough A 10's for now... still got a freewing F 18 to finish
                                      Regards,
                                      Didier
                                      • rc_heli_flier
                                        • Oct 2019
                                        • 19
                                        Hi guys.
                                        One odd thing I found - When I cycle the gear with a servo tester (without the wings on), with the rx lead plugged into the tester, the landing light on the nose gear comes on like it should when the nose wheel comes down. When I have the rx lead plugged into the gear channel on the rx and use the transmitter to cycle the gear the landing light does not come on when the nose gear comes down. Why? I cannot figure out why it would work that way.
                                        • ChiefGeorge
                                          • Oct 2019
                                          • 6
                                          I'm gonna order a decal set from Callie graphics but don't know the scale of the 80mm A-10, ...can anybody help with that??
