  • I havent added any myself...have about 12 flights on it now. all of those being touch n go flights ,with a couple of dribbles and I havent had any problems.
    www.TSHobbies.com
    • Originally posted by MikeT View Post
      I'm adding the CF just a precaution. The weight of 2- 6S batteries might put extra stress on that area.
      Easy enough to do with minimal weight addition.
      Mike
      Did on mine... just in case...even it seems that fuse side inner walls were designed with a channel for that purpouse..this ship have lots of carbon rods on wing, tail, rear side of fuse but surprising why not on the front... anyway is not dificult to add.. just sand a little the square carbon tubes and a well vented area, used 30 min. epoxy and goes on...
        As snug as two peas in a pod...
        I'm gonna need to rent a wider Uhaul trailer but at least they won't get damaged transporting them.
        Any chance we could get a pic of your cradles without the planes and foam spacers? I need to create one and yours looks awesome.
        Thanks,
        Bill D.
          Sorry, I couldn't help myself... :Silly:
          I want the belly bomb racks ;)
          • Does anyone have a drop tank from the 90mm F-16 they would be willing to part company with?
              I like what you've done, can you post a few pics without the plane to better help me understand the construction?
              • Bill and Dave, I will get some pics of a rack empty on my lunch break and get them posted up. Not a problem.
                  Just love it, goes without saying.:)
                  • I am going to try and make the bottom of my gray one look like that...
                    • Originally posted by ULTIMATETWO View Post
                      Did the same on mine using Foam-Tac. Had to replace my horizontal stab after the nappy velcro grass @ NEFI tore up my elevator and discovered that the horizontal stab had 2 - 6mm square CF rods in them and were a perfect fit in the fuselage channels after cutting off 2 inches of the length for a total of 22" length. It really does shore up the sidewalls of that fuselage.
                      FW really should do this.;)
                      • I also added carbon fiber to the side walls of the fuselage. If it makes me feel better, the small cost and minimal effort is completely worth it. I cut one long 6mm diameter (with 4mm inner diameter) tube to two 15 inch long pieces, one for each side and used the white expanding Gorilla glue to secure them.
                          Simple fix my friend, these are the exact same hardware used on the A-10;)
                            Wish I could help whereas I "HAD" (the operative word here) 2 extra drops from my Seagull Skyraider and one was put on the HSD Skyraider you saw # NEFI and now I've taken artistic latitude in putting the other as a centerline "bunkerbuster" on the Artic Thunder.
ID:	87301Click image for larger version
                            • Originally posted by Pete Lane View Post
                              Yes. Dessert plate is 7.5 inches across and near perfect arc wise.
                              Thanks Pete. That will work..
                              I picked up the extra weapons set for a several reasons, but mainly for the Mavericks and the extra hardware. That was before I knew the hardware was available on the F-16 parts page.
                              Since I have the set, I decided to cut down three of the extra hard points to use on the fuselage.
                              I've ordered some smart bombs from Parkflyer Plastics. Depending on how they come out, they may go on the three fuse racks.
                              • Your very welcome. Glad to help !
                                Plane
                                • Ok. Here's some pics without the plane and pool noodles at least on the verticals. It's all 3/4" PVC.
                                  Click image for larger version  Name:	20170714_123813.jpg Views:	1 Size:	56.7 KB ID:	87319
                                  Click image for larger version  Name:	20170714_123821.jpg Views:	1 Size:	53.8 KB ID:	87320
                                  Click image for larger version  Name:	20170714_123828.jpg Views:	1 Size:	57.8 KB ID:	87321
                                  Click image for larger version  Name:	20170714_123844.jpg Views:	1 Size:	57.3 KB ID:	87322
                                  Click image for larger version  Name:	20170714_123852.jpg Views:	1 Size:	55.6 KB ID:	87323
                                  Clip on PVC fittings...
                                  Click image for larger version  Name:	20170714_123856.jpg Views:	1 Size:	55.2 KB ID:	87324
                                  Click image for larger version  Name:	20170714_123901.jpg Views:	1 Size:	56.8 KB ID:	87325
                                  The wing spars go in here.
                                  Click image for larger version  Name:	20170714_123917.jpg Views:	1 Size:	51.3 KB ID:	87326
                                  One more clip on holds this nipple..
                                  Click image for larger version  Name:	20170714_123929.jpg Views:	1 Size:	53.7 KB ID:	87327
                                  I have to remove 1 Maverick and this is where I put it.
                                  Click image for larger version  Name:	20170714_123949.jpg Views:	1 Size:	55.1 KB ID:	87328
                                  • I have spare FW F-14 ordinance to use as well. See where I can put those.
                                      https://www.motionrc.com/products/fr...hment-hardware
                                      Thanks, just ordered me a couple of sets ($1.99 each).
                                      Bill D.
                                      • Originally posted by Bill-D View Post
                                        Bill D.
                                        So did I. :) Using for the multiple bomb rack. 2 sets of 3.
                                        • Originally posted by ColtPilot View Post
                                          Thanks Pat for the decals. For the rest of you guy's, they are worth it. Click image for larger version
                                          Hey Pat, are you still selling those cool ordinance decals? If so I'd be very interested. Also ColtPilot, is all your ordinance white for a different livery or what? I think the white ordinance would really help with plane orientation in the air. Not to mention the fact that the decals stand out much better. Brad
