Originally posted by jdarland
View Post
Before the maiden, complete your typical pre-flight checks like ensuring all screws and metal components are secure, ensure no components are missing from aircraft assembly, ensure hinging is secure, check all linkages for security, check all plastic-to-foam glue mounts/joints, calibrate your throttle, range check and failsafe check, get your nose steering traveling straight, ensure all control surfaces are traveling in the correct direction and moving freely, check CG, ensure all wiring is seated properly, no electronics are loose in the compartment, battery is secured, etc.
In addition to the regular checks above, adding some glue (I prefer hot glue for this in particular) to each mounting tabs and end of the spring on each nose gear door. This locks the spring into its proper place (you would want to have the aircraft on a stand inverted and place the spring in the proper spot prior to gluing). This prevents the spring from rotating around out of its ideal position, and when in the proper place the nose doors close and open more reliably and more evenly. The picture below shows it best.
I didn’t like the positioning and space to place my receiver and any telemetry equipment, gyro, etc., so I made a simple RX/Gyro tray for the Avanti that can be 3D printed, and is available on Thingiverse in the link below.
After many flights on the Freewing Avanti S 80mm EDF jet, the following below are the throws, expo, and CG I settled on.
CG: 115mm measured inverted with gear extended. My elevators are level for cruise flight at this CG, so no noticeable up or down trim was required.
Throws & Expo:
Aileron (measured inboard) - 14mm Low, 18mm Mid, 22mm High. 20% Expo on each
Elevator (measured inboard) - 14mm Low, 18mm Mid, 22mm High. 20% Expo on each
Rudder (measured at the bottom) - 25mm Low, 30mm Mid, 35mm High. 20% Expo on each
Flaps (measured inboard) - 10 degrees Takeoff, 45 degrees Landing
