Nice Steve!! What happened to the gear?
Originally posted by RCjetdude View PostAfter two years of on and off tinkering here is a short video taken today at TiredIron Aviation of my A-10I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by Aros.MotionRC View PostGood luck on your maiden! I just put mine together this evening. It's been a couple years since I had mine so I too wouldn't mind a confirmation on CG. As for me I am using an Admiral rx with satellite. I mount it along the starboard side of the inside fuse, 90 degrees, yes.
I plan on maidening this weekend, hopefully on grass as I don't want any Bucking Bronco landings on a maiden! :Scared:
Originally posted by bbolz View PostBeautiful Mike T. Thanks for the tip. If I buy shelf paper my wife may have other ideas for me! Guess I better buy enough! I know the Flipper scheme was just an Arctic camo experiment but I think it's so cool, no pun intended.
MIke\"When Inverted Down Is Up And Up Is Expensive\"
Stock gear for now but depending on how my first dozen or so landings go will determine if and when I upgrade. I recall I never had any issue on grass. It was pavement that could bite. I am going to maiden this evening or tomorrow at the school track where I can land on grass.
- move the CG back from the stock setting (the stock setting is nose heavy). You've done that!
- use full flaps before touchdown (I mean ALL the way down) and let the plane slow down. It will slow WAY down if you raise the nose right before it touches down.
- land without cramming the nose gear into the ground first.
Easier said than done - if you're nose heavy. Once I moved the battery back a bit, my landings improved a LOT.
I'm looking forward to your flight report!!
Good advice! So where do you have your CG currently and what batteries do you use? I will be maidening with RT 5500 6S 70Cs....My YouTube RC videos:
Originally posted by themudduck View Post
For what its worth (probably not much) my experience is that "bucking bronco syndrome" is mainly due to factors other than the landing gear. Not saying that the mods won't help, but I don't think that's the cause. To avoid the problem you need to:
x2! you using the 86mm back?
Hey guys, sorry my bird is laid up until warmer weather gets here and I can't tell you exactly where the CG is. But I can tell you as far as where I put the batteries, the one in the lower tray is all the way back and the upper one is to the very back edge of the top shelf. I'm using 6S Admiral 5000's and also RT 6350's. (I have the 80mm edf model)My YouTube RC videos:
Yeah that's where I have mine both from 2 years ago (6S Admiral 5000s) and prepping for the maiden (6S RT 5500s). I think I should be okay...
Also, remove the junction board and reinstall with the front holes of the board in the rear holes of the ply mount. That way you can move the rear battery back a little further. I use RoaringTop 5800s and 6250s, and the front edge of the batteries are at the battery straps. This will help you get back to 86mm CG.Pat
Originally posted by crxmanpat View PostAlso, remove the junction board and reinstall with the front holes of the board in the rear holes of the ply mount. That way you can move the rear battery back a little further. I use RoaringTop 5800s and 6250s, and the front edge of the batteries are at the battery straps. This will help you get back to 86mm CG.My YouTube RC videos:
- Likes 2
Maiden success!
Man, I forgot how easy and smooth this bird is to fly. Such a *****cat with HUGE PRESENCE! Not much of a thrill ride, I just wanted to get her trimmed out (just needed a couple clicks of left), cycle the gear, check the flaps (too much down elevator mix, may remove altogether) and land without any Bucking Broncos in the vicinity, lol. Now I can paint her up in Arctic Camo! Callie decals already on the way. Not selling this one!
UPDATE: Just bought the upgrade main oleo struts. I am not going to take my chances since many times I will have to fly off pavement.
- Likes 3
After spending last year reading these wonderful posts and seeing these amazing models, I thought I better join and get involved. I have to say all these posts have spurred me on. I am from the uk. So I will upload my efforts which is still in the process of finishing.
My first time on these forums.
Great Video.18 Photos
- Likes 3
Welcome to Hobby Squawk from across the pond NJP! WHOA LOVE YOUR ARCTIC CAMO!! :Drooling:
Please share your weathering technique...Wow that looks GREAT!!My YouTube RC videos:
