    • 8223
    Two left feet? Like me on the dance floor! LOL
    • t01ga
      " T "
      • 197
      • UK
ID:	193776Click image for larger version
ID:	193775Click image for larger version
ID:	193774Click image for larger version
ID:	193773Click image for larger version
ID:	193772Click image for larger version
ID:	193771Click image for larger version
ID:	193770Click image for larger version
ID:	193769 Onto the weathering. I haven’t maiden this bird yet cause I can’t stop adding details. It is the queen of my hangar.
      Tolga
      Instagram: @_t01ga_
      YouTube: t01ga
        • 4848
        T, She is a thing of beauty. :) Onward, sir. Best, LB
        • t01ga
          " T "
          • 197
          • UK
          Thanks LB. I am halfway through, loving every minute. I envy you pilots who have been flying her so far. But I will get there.
          Tolga
          Instagram: @_t01ga_
          YouTube: t01ga
            • 8223
            Wow, love it!!
            What are you using for the raised rivets on the canopy? Just fantastic!
            • t01ga
              " T "
              • 197
              • UK
              Wow, love it!!
              Thanks bud. On the canopy just marker pen. On the light covers I have used sewing pins; cut short and slotted into pre-drilled holes. I have contemplated using them for the canopy but I thought the look might have been a little over the top.
              Tolga
              Instagram: @_t01ga_
              YouTube: t01ga
                • 4848
                Thanks LB. I envy you pilots who have been flying her so far.
                T, you are further along than I, sir. Mine is NIB downstairs, though waiting patiently. Best, LB
                • t01ga
                  " T "
                  • 197
                  • UK
                  Mine stayed in box for two months whilst I was finishing off the winter project. What is holding you up LB?
                  Tolga
                  Instagram: @_t01ga_
                  YouTube: t01ga
                    • 4848
                    Well now that you mention it...not much. Just need to add the matte coat to my F-Phour, though too wet/cold here today to spray, though I did get the AB's working, "so I've got that goin' for me." Best, LB
                    • sethscorsair
                      • Jan 2019
                      • 63
                      • Georgia
                      What is the best way to add rudder authority i need a little more on landing and taxi.
                        • 8795
                        Increase servo travel on the rudder channel. With Spektrum, you can go as high as 150%. Keep the high rate on rudder at 100%, 0 expo. Also, give it full UP elevator (on high rate) to plant the tail wheel while taxiing.
                        • sethscorsair
                          • Jan 2019
                          • 63
                          • Georgia
                          To increase to 150 in the reciever?
                          • thisguy65
                            • 509
                            T01ga,
                            Great job! You got pure talent!
                            I had a brown out on mine today, sadly. 3rd touch and go. Got attluide and make a turn running parrallel to the runway. Started a barrel roll and right when started to come down, lost control and down she went.
                            Planes
                            • t01ga
                              " T "
                              • 197
                              • UK
                              T01ga,
                              Sorry to hear that man. I hope it is fixable. Thanks for the compliment
                              Tolga
                              Instagram: @_t01ga_
                              YouTube: t01ga
                              • thisguy65
                                • 509
                                She’s toast
                                Planes
                                  • 4848
                                  She’s toast
                                  TG65, My condolences. :( Suxbigtym...Best, LB
                                  • t01ga
                                    " T "
                                    • 197
                                    • UK
                                    She’s toast
                                    Ouch man. Are you gonna replace her?
                                    Tolga
                                    Instagram: @_t01ga_
                                    YouTube: t01ga
                                    • thisguy65
                                      • 509
                                      Not sure. No cause to why it happen battery was 3,94. Running admiral battery, admiral rx.
                                      Planes
                                      • fhhuber
                                        • Aug 2015
                                        • 1476
                                        Its in the TX servo settings.
                                        You can go to a longer servo arm and use a hole further from the center of rotation, making the servo move the push-rod more per degree of rotation.
                                        Anything beyond 40 deg of rudder deflection is not as effective for increasing steering (per degree) turn as for increasing drag. So if you are already getting that much rudder you may not gain much from increasing the rudder deflection.
                                        Adding rudder area of course helps, but that isn't practical here, since it would mess up the scale appearance.
                                        Since you'll usually have more issues trying to turn right than left, you could try shimming the motor mount to have a little more right-thrust.
                                        If its from trying to taxi in a crosswind, you might just have to pick up the airplane. there is some maximum crosswind where you just can't keep the wind from turning the airplane to turn into the wind.
                                          • 8795
                                          Yes, in the TX. Go to Servo, travel, rudder and crank the wheel. I would try it at 125% first and see how you like it. The key is to have the rudder on 100% high rate in the DR/expo menu and then use full UP elevator while rolling on the ground. DO NOT keep it full UP when the plane is near flying speed.
                                          PS. I maidened mine today and with servo travel at 100% and high rudder rate at 100% and full UP, ground handling was more than adequate. This plane is very light on its tail as compared to my much heavier FMS 1700mm Corsair, so it does require UP on the elevator or the tail wheel won't track well.
