    Roger that!!!!! If the cowl flaps work out, I will pay for your fuselage Tom!!!!
    • RichJ53
      • Nov 2018
      • 342
      • Southern Oregon
      Originally posted by Elbee
      Tom, I have not started my Corsair, but I dinked around with a 3DP design for a functional assembly. I didn't have the correct cowl radius so I used 8" just for giggles. And dimensional, it all basically a SWAG from pictures. If these ideas and STLs work, feel free to redesign or adjust to your liking. Once I start the model, I will continue with the design if you haven't already done it. I just couldn't get the idea out of head this morning. Also, if I am just way off the mark, let me know. Best, Steve
      Flightline Corsair Cowling Flap Hinge Base.stl
      Flightline Corsair Cowling Flaps Assembly.stl
      LB
      Just awesome work. I wish I had your skill for these details. If you make a complete extra set of cowl flaps ....I know someone that just might like to have it :)
      Keep up the good work
      All the best
      Rich
      • ncflyer79
        Jarrod “P-47 Thunderbolt and Luftwaffe fanatic”
        • 42
        • Marion, NC
        Joined Hobbysquawk a few years ago but never been really active. Looking forward to being more active here! Here’s my Corsair
          • 8223
          Steppin' outta the shadows! Love it! Great job on the Corsair!
          • I-fly-rc-aircraft
            Always learning
            • Jan 2019
            • 269
            • North Augusta, SC
            Hey Elbee, you and I are famous. Go to the 12:45 mark in this video.
            Tom
              • 4848
              NCF, Welcome back, some more. Love your livery, like who wouldn't. Bravo Zulu, Sir. Best, LB
                • 4848
                Originally posted by I-fly-rc-aircraft
                Hey Elbee, you and I are famous. Go to the 12:45 mark in this video.Tom
                IFRC, Yeah, I caught the 'shout out'...very cool. You are famous, but I showed the excerpt to 'she whose authority exceeds my rank' and was then asked to carry out the garbage. Celebrity is fleeting, my friend. Best, LB
                • ncflyer79
                  • 42
                  • Marion, NC
                  Thanks!! I’m looking forward to being more active here
                    • 4848
                    So Gang, On the 1:1 version there are 15 total cowl flaps, 8 larger, 7 smaller with the cowling attached at the top dead center roughly 3 spans of the larger flap and a smaller flap at bottom dead center. Also, what would become the transition from the fuselage top to the firewall is radius-ed similarly to the cowl front. Am I seeing this in my references correctly? Best, LB
                    • I-fly-rc-aircraft
                      Always learning
                      • Jan 2019
                      • 269
                      • North Augusta, SC
                      LB, my guess would be that the cowl was built to fit the R2800 Radial. Thus it be a circle. A true circle? perhaps not. The cowl flaps directly forward of the cockpit were welded closed so should have the same radius.
                      Tom
                      • Beeg
                        • 1335
                        • Texas
                        If I understand you correctly. Yes.
                          Elbee commented
                          Editing a comment
                          Thanks Beeg.
                      • f4u ausie
                        • 1240
                        • Melbourne
                        hi just thinking out aloud again..the grass i fly my f4u 1600 off is longer than i would like... question being woul a larger diametre wheel help with ground handling ,, over the bumps better,, it looks like a small increase would fit in the wheel well.. u guys have talked of dave brown a good amount .. also the euro motian rc guy, stewart i think ,, cut the springs a little on the f 35 for improved ground handling anything in that ?? lastly i watched the latest motian stream,, cool to c the paint process ... im an auto painter;; forget home depo, i think thats a hardware store . find a local auto paint store ,, the colors will be way closer with there electronic eye match process happy flying
                          • 4848
                          FA, Many of the Corsair owners have added larger (3-3/4 inch) diameter wheels by Robart. I have not yet built mine, but I did buy the larger wheels. Anytime you can add diameter without too much added weight, your grass-field ops should improve. Best, LB
                            • 2696
                            I fly my F4U 1600mm off of grass as well, although our field is cut fairly short. Question is how long is longer than you would like. In the summer when our grass grows the most, I've flown it the day before it is mowed and still not much of a problem. I use the 3 1/2 inch Robart treaded (or diamond) and it works just fine. The 3 3/4 size Elbee mentions is better and closer to the correct scale size, but you may have to do a little "trimming" in the wheel well to get it to fit smoothly.
                            • f4u ausie
                              • 1240
                              • Melbourne
                              It is a football field and yes is it much better when the grass is mowed. I'm happy to trim minimal. Thanks for your input, are the robarts expensive?
                              • f4u ausie
                                • 1240
                                • Melbourne
                                is there a part no 4 the 3 3/4 robarts thanx again
                                • Beeg
                                  • 1335
                                  • Texas
                                  Robart 3.50" Straight tread #116
                                  Robart 3.75" Straight tread #117
                                  Robart 3.50" Diamond tread #135
                                  Robart 3.75" Diamond tread #136
                                  Here's the post of the way I modded mine to accept the 3.75" wheels. I've since changed the #136 wheels to straight tread #117's as the diamond tread set had a warped tire that wouldn't fit properly on the hub. If you go with the 3.5" it's a lot less trouble.
                                  Post number 934:
                                  https://www.hobbysquawk.com/forum/rc...026#post175026
                                  • f4u ausie
                                    • 1240
                                    • Melbourne
                                    must say the big wheels look cool.. mods like this r easy compared to a ground up build,,,, / not to take away from ya work beeg awsome stuff .. u guys r the best thanx 4 the great info.. will do that /// still wana birdgage... i was torn
                                    • I-fly-rc-aircraft
                                      Always learning
                                      • Jan 2019
                                      • 269
                                      • North Augusta, SC
                                      So, been working on the cowl flaps. Printed the ring with a channel for music wire to open and close them. pic shows my design.Tom
                                        • 4848
                                        Tom, I'm liking it. So the design you have in mind will use a cable and attach to the flaps per the original? Best, Steve
