Looking good, Rex. Regarding the lens, I would probably start by using my dremel tool with a cloth polishing wheel that I have for it. If you have a dremel and that polishing head, that would probably be a safe place to start, being very careful, of course. Others might have other ideas, too.
As far as compressor output pressure, I would experiment on a piece of cardboard or something, first. I'd probably start at around 25-30 psi, maybe go up to 40 psi if it doesn't start to drip. For smaller areas, I use a much lower pressure out of my airbrush, around 15-20 psi. I'm assuming you're using maybe a bigger gun than an airbrush for the whole plane? You could probably use an airbrush, but that is a lot of territory to cover and not get inconsistent with thickness of the minwax application. Again, I would start with a test strip of foam, old wing or something, and see what works best for coverage. Just my take on it, anyway.
davegee
davegee
Best, LB
