    • 8814
    I have searched for years to find a 4-blade prop that would work on the FMS 1700mm P-51 but to no avail. The closest I came was this German company but their props are very expensive and may not be in the size I need.
    Most one-piece 4-bladers don't even come close to the size needed for the Mustang.
      • 4853
      X,
      What would be the ideal size in a 4-blade prop for this model?
      Have you changed out the electric motor for one with more grunt/RPM?
      Back in the 'days or yore' we built larger 4-bladed props from 2 bladed props.
      These were 'Rev-Up" maple props with the wide blades.
      Sometimes by notching one against the other and using epoxy and metal pins to build one prop and sometimes by machining/building a back plate that would allow for using a portion of the prop & hub of four 2-bladed props.
      I never had one come apart, but it certainly could depending on use/abuse.
      Best, LB
        • 8814
        Originally posted by Elbee
        X,
        Best, LB
        Hugh and I were referencing the FMS 1700mm 'Stang. Mine is already modified with the power system from the Flightline 1600mm P-51. As such, I'm using the stock F/L prop (16x12x4) because I worry that the stock FMS prop might come apart given the F/L motor spins ~100kv faster. Ideally, I would have liked to have used the stock sized FMS prop (17x10x4). "Rule of thumb" - the F/L prop would be equivalent to a (17x11x4), so in that sense, the stock FMS prop "might" be able to take it but I didn't want to chance it as I've had a similar prop on the FMS 1700mm Corsair explode on 2 different models. One day, if I find a way to manufacture that metal brace that comes with the stock F/L and make it fit into the stock FMS prop hub, I'll give it a try.
        Hugh is thinking of going with the Eflite Power 60 motor (470kv), 80kv more than the F/L motor. Using the stock FMS prop could be a risky proposition. However, having said that and knowing that RCInformer did try the same V1 FMS P-51 on 7 or 8 cells and it lived to tell the story would make me think that the stock FMS prop might take it. I'm just too chicken to try but with the metal F/L type brace, I would chance it.
        I've read some modellers have considered that the proper "scale" prop for the FMS plane is closer to an 18" 4-blade and for the F/L plane, a 17" 4-blade. IMO, the F/L P-51 would look amazing with a bigger prop but one would have to take extra care so as to not nose over and break all kinds of stuff in the nose. I don't have the calculations to confirm or deny these "claims". The pitch for such props would be dependent on the motor used based upon an E-calc determination, something I'm not well versed in performing.
          • 4853
          xviper..
          Makes sense, it would seem reasonable to think one could build props, even scale sized props, given current technologies.
          As stated, we used to build 'em from maple 2-bladed props.
          I still have a 3-bladed and a few 4-blade props I made from those days.
          Best, LB
ID:	448903 Click image for larger version
            • 8814
            Those home made 4-bladers are spectacular.
            • nuts-n-volts
              Duke City Electric Flyers
              • 262
              • Albuquerque, New Mexico
              Scale Hamilton Standard for this 63" Mustang would be 19"
              Fly low, fly fast, turn left
                • 4853
                Thanks, X.
                I ran those on a OS .40 FSR ABC and a OS .91S 4-Stroke.
                A little much for the .40, though performance was really good and the drag at lower throttle was realistic.
                The 3-blade was never run on an engine, as I didn't finish the model, Pica (Dave Platt design) Spitfire with a OS .61 FSR ABC.
                Still have the partially built kit, wing needs top sheeting and fuselage needs empannage completed.
                Big fun for little money in those days.
                Best, LB
                • Davegeee
                  • May 2026
                  • 90
                  • Cody, WY
                  I just pulled the trigger on a new P-51D 1600mm model. I like the basic 357th FG paint schemes offered with the kit, but I will be changing it to an early D model without the tail fin fairing. I'll probahly use one from Pete Peterson's Hurry Home Honey aircraft paint schemes.Below is the proposed look of Pete Peterson's airplane, or one of several that he flew in combat. The picture below shows the top four aces of the 357th FG. From left to right, Richard " Pete" Peterson, Leonard "Kit" Carson, Johnny England, and Clarence "Bud" Anderson.
                  Davegee
                  Click image for larger version  Name:	HHH-2-1024x741 (1).jpg Views:	0 Size:	96.6 KB ID:	449201 Click image for larger version  Name:	357th-Ftr-Gp-Top-Acesjpg.jpg Views:	0 Size:	159.4 KB ID:	449200
                  • stitch
                    • Dec 2014
                    • 142
                    Yup that's it,I have used gyro,s since 2015 if swings around at all turn gain down just a hair try that!😁
                      • 8814
                      To what is this in reference to? There is no quote.
                      • Davegeee
                        • May 2026
                        • 90
                        • Cody, WY
                        Davegee
                        My new Fligthline 1600mm P-51D arrived in good shape yesterday. I immediately took everything out of the box, and was fairly impressed. A minor annoyance is the thin waterslide decals of the fuselage where the underlying colors of the invasion stripes show through. I'll have to repaint over those in time, but no big deal, for now.
                        I started working on the tail modification to make it an early D bubbletop before they added the vertical fin fairing or strake. They soon found out, as they did on the P-47, that cutting down the spine of the razorback on both airplanes exposed a new problem with longitudinal control of the aircraft. Kits were sent to airplanes in the field to correct this, and North American changed the production lines to include this fin, which solved the problem.
                        I have modified three different E Flite 1.5m P-51 models to this early D "finless" model for scale likeness to the real thing. There was absolutely no negative impact that I could tell in flying them with my mod. So, I'm going to try doing that with this new Flightline model. I started cutting on the leading edge of the vertical stab yesterday. I'll rebuild the scale looking part with balsa or bass wood. If all works out, it will look great, I think. But if it doesn't, I'm only working on the rudder/fin, and if I screw that up, I'm only out $30 as I get a new part from MRC and do a slightly "newer" version of the airplane with the strake on it as the model comes with it. I sorta look at it as the "free return" trajectory that the early Apollo missions did that would return them safely home to Earth if their plans didn't work out. I'm reasonably sure I can pull off this mod without having to do the "free return" mode and buy a new replacement rudder part. We'll see.
                        Cheers
                        Davegee
                        Click image for larger version  Name:	IMG_3734.jpg Views:	0 Size:	57.3 KB ID:	449360
                        • jetfool
                          • Nov 2022
                          • 1333
                          • Crawfordsville, Indiana
                          Great News, Davegee. Looking forward to the mods. As well as the Corsair was constructed is the P-51 light years ahead in improvements?
                          My club mate has been flying the heck out of his FMS P-47 so when the winds calm down I will start flying mine. They can't all be hanger queens. LOL
                          Best Regards, Rex
                          • Davegeee
                            • May 2026
                            • 90
                            • Cody, WY
                            Best Regards, Rex
                            Hi Rex: The Flightline Corsair was and is a great rc model. I have had mine since 2019 and it has been great. I flew it 4 times the other day, just a few minor glitches that were easily corrected, like one of the flap sets on one of the wings did not extend for landing, so it flew a bit goofy until I got it on the ground to find out what the cause was. After playing with it a bit and a few more flap cycling on the ground, it worked again. Go figure...
                            The new P-51D I am still learning about but it does have a lot of improvements like the wing extensions and the push button locks, although I have heard a few complaints about them. When I get to that point, I'll see what is going on with them.
                            Flying wise, you've probably read in HS numerous glowing reoports about it being a stable flyer not subject to some wild takeoff and landing rollouts, like what the EFlite 1.5M plane has, for instance.
                            I'll be sure to post any good or bad points that I see as I put this thing together. I have several mods that I plan to do, including the cockpit area, so it will take awhile. But I'm looking forward to eventually flying it, for sure!
                            Cheers
                            Davegee
                            • jetfool
                              • Nov 2022
                              • 1333
                              Davegee,
                              Take your time. Remember it's about the journey when you modify and create a new masterpiece.
                              Best Regards, Rex
                              • Davegeee
                                • May 2026
                                • 90
                                • Cody, WY
                                Davegee,
                                Best Regards, Rex
                                Wise words, Rex. I'm methodically going over all the changes to make on this airplane. It is complicated, and I have to be very careful in masking to be sure it comes out right. Going to my local Sherwin Williams this morning with the rudder so that they can do a color match for all the OD paints that will remain on the topside of the airplane. Most everything else below that will be NMF. Shouldn't be overly difficult, but definitely time consumng.
                                Hope you get some flights on your Lucky when the weather is appropriate. I heard third-hand that there is talk that we might be able to resurface our runway, which if true, would be a godsend! Have to wait to confirm if that is actually true, or not.
                                I'm making plans to go to Washington, DC for a peek preview on June 28 of most of the new galleries that will be opening on July 1 at the NASM. I can see some of my handiwork and how all that turned out. I especially want to see the new WWII exhibit which has about 15 diecast 1/72 scale B-17s hanging from the ceiling on threaded rods in a "combat box" formation. I shipped them to the museum in the summer of 2023, so it's been a while. Also there are two plastic models of a Mustang III and Me-163 Komet I'm looking forward to seeing. There are still about two or three galleries that will open later this summer, not quite done yet. Will take pics!
                                Cheers
                                Davegee
                                  • 4853
                                  Davegee,
                                  Best Regards, Rex
                                  Rex,
                                  Sage advice, my friend.
                                  I organize all my ideas by how happy I'd be if it worked.
                                  The process then becomes a pleasure to wake up to every day.
                                  Works for me.
                                  Best, Steve
                                  • Davegeee
                                    • May 2026
                                    • 90
                                    • Cody, WY
                                    I made some progress on the P-51D makeover during the weekend. Still working on refinishing the vertical stab (minus the foam fairing that was amputated by razor saw) and will be painting it today, probably.
                                    I'll attach a couple of pics of the fuselage and wing redo, spraying silver paint where the grey parts were. This is a version (paint scheme) that was a little later than the scheme MRC has on their Mustangs, with the exception that the first D bubbletop models that came to the unit did not yet have the fairing installed on the vertical fin. These "finless" models were later field modified with kits that came from NA in California when they discovered the controllability problems cutting down the spine on P-51s and P-47s. The aluminum fairing seemed to fix the problem. The P-47 used a smaller, longer fairing that extended from the vertical fin to near where the bubbletop canopy stops when it is fully open.
                                    Cheers
                                    Davegee
ID:	449441 Click image for larger version
                                    • jetfool
                                      • Nov 2022
                                      • 1333
                                      Davegee,
                                      looking good. I bought some scalpels off Amazon for $12. Best tool for cutting clean lines in foam I have ever made. I handle these with care! Didn't know if you use them.
                                      Best Regards, Rex
                                        • 4853
                                        ...bought some scalpels
                                        The only issue I've ever had with scalpels is the brittleness.
                                        Side loads can break the blade and zing it across the bench.
                                        Less expensive in the long run than #11 X-actos and sorry to say it, but better quality, too.
                                        Great tip, Rex.
                                        Best, LB
                                        • Davegeee
                                          • May 2026
                                          • 90
                                          • Cody, WY
                                          Davegee,
                                          Best Regards, Rex
                                          Hi Rex: what is the official name given to them on the Amazon website? I'll order some and give them a try.
                                          Thanks
                                          Davegee
