    Hello FIB,
    If it is just foam fuzz, a little elbow grease with a 200-400 grit foam sanding block.
    If it is very light scratches, go with Foam-Tac Foam Finish. If slightly deeper try some Ultra-Lite Spackle by DAP or equiv. That's all I use on foam for my smoothing compounds. If you got some minor gatoring going on, rub over it with one of those plastic freezer packs.
      • 7438
      Hey, thats a good thought, CB, what would I do without you!!
      • flyingiceberg
        • 58
        • Austin Texas
        I can't believe how many of you have replied. Thanks for all the suggestions! What a great community!
        It is a little fuzz and some uneven spots from the tape pulling a little foam too. I circled an example of the fuzz and you can see the rest of the foam. I have watched Chris's videos. I guess I rubbed a little to hard with the paper towel and acetone.
        • Aspirin
          Banned
          • 67
          You are more than welcomed.
          Through the community we'’ve learned that there is more that one way to skin a cat. (and yes that is a bad pun)
          Even with 50 years experience I too gleaned a new idea. The use of ice bags sounds intriguing to address the bane of EPO foam.
          I will work on this idea and hopefully report my findings here on Hobby Squawk.
          I for one am learning from your experience.
          Please keep asking questions.
          All the best,
          Konrad
            Krylon makes a primer that works really good to bond the fuzz, I've used it several times and love it.
            • Aspirin
              Banned
              • 67
              In the FAQs Krylon said they hadn't tried that product on EPO foam. Did you have to use and "special" process?
              All the best,
              Konrad
                All the best,
                Konrad
                Works fine on EPO...
                  • 2818
                  • Arlington, TX
                  I have used it on both EPO and EPS, and it works great. As a general rule, if something works on EPS it won't harm EPO. EPS is much more sensitive and reactive then most types of EPO.
                  • Aspirin
                    Banned
                    • 67
                    How is the bond? Can you mask over it without lifting up the primer? The issue with EOP is that the wax surface makes it very difficult for any paint of dies to adhere.
                    BTW; I often use "Frog tape for delicate surface" as my mask. I then use the hair dryer to warn up the mask's adhesive prior to unmasking. This makes it much less likely for the mask to pull the paint off the EPO.
                    Please note the term "warm". One does not want to expand the EPO beads!
                    All the best,
                    Konrad
                      • 2818
                      • Arlington, TX
                      It has held up to masking with delicate surface tape alright, but pretty much the same as family's primer has. A few small flakes will come up during masking seemingly no matter what you try. That is why for simple markings like camo lines, I use either slightly wet newspaper or paper towel to mask things. Simple, and leaves no opportunities to peel paint. Obviously, this is not practical for detailed subjects, like numbers, insignias, or shark mouths, but it helps to reduce the touch up work.
                        • 2818
                        • Arlington, TX
                        Also, if anyone is interested in the scale diameter prop mod I did a while back, the prop I used is finally back in stock: http://www.bananahobby.com/4-bladed-...ueryId=1880602. I have no idea how many are left in stock though, now that the HSD Skyraider is discontinued though.
                          Also, if anyone is interested in the scale diameter prop mod I did a while back, the prop I used is finally back in stock:http://www.bananahobby.com/4-bladed-...InStockEvent=1. I have no idea how many are left in stock though, now that the HSD Skyraider is discontinued though.
                          I put a few of these away this morning myself.
                          • borntoolate
                            Bomber Bob
                            • Mar 2013
                            • 424
                            • California
                            Just curious as to why some people have bought 2 of these?
                            I am building my second Bearcat today. I am not sure about others, but I like multiple copies of planes that I truly like. I have 2 FL P-38s, 4 FMS B-25s, 2 FMS 1400mm Zeros and about 8 of the 1875mm "Sonic" B-17s! I love to fly my favorite planes.
                            Bob
                            ps MotionRC, I am patiently waiting for more multi-motored WWII bombers!
                              Bob
                              Same here Bob, I want to be flying some of these as long as I'm able then I'll just sit and look at them.
                              • borntoolate
                                Bomber Bob
                                • Mar 2013
                                • 424
                                • California
                                An excellent plan! I enjoy building, modding and flying these!
                                Bob
                                  • 7438
                                  Good thing huh!
                                  If all we liked was flying, we'd soon have nothing to fly!!
                                  • flyingiceberg
                                    • 58
                                    • Austin Texas
                                    Are you able to sand the fuzz or does the primer help flatten it out? I have the fuzz and a few rough spots from the Gorilla Tape pulling a little more than just paint!
                                      Yes on both, it makes the smaller stuff lay down and hardens the larger fuzz so you can lightly sand it.
                                        • 7438
                                        I looked for this at Ace here in Cody, but, as usual, nothing, have to wait to hit Hobby Lobby in Billings, right now we're in high wind/lots of snow drifts conditions so not going anywhere for a while.
                                          • 7438
                                          She's an awesome bird Nick, especially with the 4000s
