Thanks alpha, that was perfect. For me the 6s then, it won’t be “underpowered” and I fly my foamies nice and tight. I have several turbine jets and I have tried flying my foam jets in their big patterns so I know what you mean. Big Air is cool but for me the beauty of the foam Jets is their simplicity, scale appearance, and ease of operation out of smaller fields.Comment
No issue with receiver shelf and canopy. If your receiver is taller than mine you can just cut a small amount off the underside rib. Really not a issue as there is plenty of foam under canopy. I added some mixes on switch to allow stock control surface movement along with adding in elevons.Testing some mixes for taileron/elevon use.Comment
Are there any graphics on the bottom as well? Looks great!Comment
No , none on bottom , tnx for the compliments,
Gonna maiden Sunday last coat of polyurethane
going on today...Comment
Guy's please help :-) ..... Maiden tomorrow.... Still fuzzy on the elevator reference line.... is it from the bottom of the fuse? or is it from the like where the top an bottom half of the fuse come together?Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
1 PhotoCurrent Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
