    • 5416
    I've flow three different packs in my 6S. RT 5800 35C for 3:45 to 3.8v per cell. Hobby Star 5200 50C for 4 minutes and Hobby Star 8000 100C for 6 minutes but it usually comes down at 3.75V per cell.
    • fhhuber
      • Aug 2015
      • 1476
      Have a question for the collective knowledge base out there. My F22 is 6 cell and I have 2 batteries to choose from in my inventory. Roaring Top 6250 35C; Gens Ace 6200 60C. The 6200 Gens Ace is heavier but would like to run the 6250 Roaring Top due to weight and flight times but worried about the "C" rating.
      Your suggestions?
      I ran a 12S 5000+ watt (melted down AstroFlight 12S 100 amp wattmeter) on 5000 mah 25C packs for years.
      Higher C would have given a marginal power increase.
      For a long time, 25C was the best you could get.
      If you do the math on the high C ratings vs the current rating of the wires on the packs, a lot of the wires would act as fuses before you hit the current the battery is "rated" to deliver. 35C for a 6250 mah pack means they say it can deliver 218 amps... If they mean it it should have # 2/0 Gauge wires. (Heavier than common arc welding cable)
      • JETGREASER
        Hobby Squawk Pilot
        • 10
        Originally posted by JETGREASER
        Avanti 80mm - Nose Gear
        F-16 90mm - Main Wheel
        F-16 90mm - Landing Light
        You will have to open the fork just a little for the F-16 wheel to fit on the Avanti Nose Gear.
        You will have to cut the F-16 Landing Light Clip right up to the Light Mounting Post so it will clear inside when retracted. Both are very easy to do
        CORRECTION:
        ​​​​​​F-15 90mm - Landing Light
        • Pheonix
          • Aug 2013
          • 670
          e4dragongunner. I have this CG machine. Did you use to balance your plane? I am at this point now. Thanks.
            What kind of flight times were you getting with the 6250 packs Pat? I picked up some RT 3S 3300mah packs for a bird and got no better flight times than I did with 3S Tgy 2650mh packs. I was a bit underwhelmed, so am reluctant to try RT 6S 6250 if flight times are not better than Admiral 5000mah packs.
            I was getting 3:30 with about 25% left afterwards, enough for a go-around or two if needed.
            • wolpertinger
              Pilot ??
              • 313
              • Earth
              Thanks for the information on the battery packs. After reading some posts looks like the BEC needs replacing.
                :Drinks::Party:
                Originally posted by purduephigam
                Great question. This didn't even cross my mind. Oh well, easy mini project if I ever find myself twiddling my thumbs. Might actually spray the main gear lights a little to dampen the amount of light output.
                I just used Tamiya XF-12 and some post it notes and a soft brush... Took 5 minutes start to finish... :Cool:
                • urrl
                  • Oct 2013
                  • 508
                  Morning F-22 flight with HRB 6000 mAh
                  • Pogo
                    • 452
                    • Waterford, Ontario, Canada
                    Wow Tom, you've knocked it out of the park once again. Looks like allot of work. Looking forward to the video.
                    Brad
                    Thanks Brad- I don't know about the park thing but they work (on the bench) so that's good- we'll see how the flying part goes in the spring! I shall, however, be doing extensive wind-tunnel testing, as I did with the A-10 canopy. (Let 'er have it with my 200 mph leaf bower! :Cool:)
                    Have a good New Years!
                    Tom
                      Your suggestions?
                      The RT 6250 35C does great unless you fly wide open all the time:Cool:
                      • ursli75
                        • Jan 2019
                        • 30
                        • Luetisburg Switzerland
                        Now I have ordered a f22 and will make the setup with kolibri :-) turbine
                        • wolpertinger
                          Pilot ??
                          • 313
                          • Earth
                          Ursl175,
                          Interesting, are you going to do a build thread on this?
                          • Dual Prop Dave
                            Just another Prop Nut!
                            • 144
                            • Sunbury,Pa
                            Welcome to the Squawk ursli75!
                            Can't wait to see how this mod comes out!
                            Like wolpertinger, We all would like to see a build thread on this.:Cool:
                              Welcome to Hobby Squawk! Can't wait to see it with the turbine :)
                                Welcome and Happy New Year!!!! :Party::Drinks: Good luck with the turbine!!! :Cool: Jerry
                                  • 4869
                                  Ursli75, Welcome to the "Squawk" and happy New Year to you, sir. Good luck with the modifications. Looking forward to seeing your progress. Best, LB
                                  • yf22raptor
                                    Love to fly
                                    • 75
                                    Will also be doing a conversion with the k-30 as well
                                    here is a mock up with a Cad being done by Hab
                                    Still figuring out how to do the pipe .center or bifurcated
                                    • Quickstop
                                      • 275
                                      The esc and bec are the same on my phantom. I never liked the looks of the skinny wires coming from the bec and 5amps didn't sound like much. Since I had to resolder the backwards positive lead on the esc I replaced the bec with an 8 amp ZTW esc.
                                      picture of the backwards lead
                                      • urrl
                                        • Oct 2013
                                        • 508
                                        This maiden flight looked too easy.
                                          If you went with an 8A ZTW BEC what is the input rating on it?
