Its okay, ask all the questions you want, it doesn't bother some of us if the questions been asked 50 times but others get all bent out of shape for some reason, use the CG in the book and front leading edge of the elevator 7mm down from the fuselage seam, real easy, so you wind up with a little up elevator like this pic. Works great for a maiden flight, then you can play with the CG to your flying style, some like nose heavy like me, others neutral, some a little tail heavy, and the arguement will go on and on.
So here's an interesting tidbit. I went to put the nose steering on a separate channel tonight, and found that the rudders and nose steering were not hooked into the MCB-E, they were on a pair of Y's instead.PatComment
Out of the box. This was the one they sent me as a warranty replacement for the first one that crashed. The second Y had the rudder label on it, so I know it came from Freewing like that.PatComment
Strange, I did it too, and I unplugged the nose steering from the MCBE.Comment
Okay, sorry for the bad pics but the sun was not in the right spot at the time, got a flight in before work this morning, didn't fly with the centerline tank yet but did fly it with everthing else in the pic, flew great, small trim change and it actaully landed better, wasn't so floaty with full flaps, just right actually and it looks awesome in the air when you turn and show the belly, not scale ordinace but close enough for me.
Just in case someone wants to know this info, I used the attachment points from the FW 90mm F-16, if you look in the spare parts you find that they sell them seperate, the drop tanks and centerline tank are from the FW Intruder, and the pylons and sidewinders missles are from the FW 90mm F-16 and the other missles are from the FW F-15. My CG remained the same, I did move the battery forward just in case but I ended up in the same spot as without ordinace or drop tanks, so that was a good thing, she flew great loaded up, I know I won't be flying it clean anymore, looks just awesome in the air.Comment
Is this what you used to hang the F16 stuff under the wing of the F18? I too got the F16 ordinance but have only been able to fit the wing tip sindwindersOkay, sorry for the bad pics but the sun was not in the right spot at the time, got a flight in before work this morning, didn't fly with the centerline tank yet but did fly it with everthing else in the pic, flew great, small trim change and it actaully landed better, wasn't so floaty with full flaps, just right actually and it looks awesome in the air when you turn and show the belly, not scale ordinace but close enough for me.
YesPlanes
-FMS: Bae Hawk Motion: 1.6m Corsair, 850mm Mustang, 1.6m Spitfire Freewing: 1.7m A-10, F-22,Comment
Yes, those are the right ones, get more than one pkg because you will find more uses for them on other projects.
https://www.motionrc.eu/products/fre...hment-hardwareComment
[QUOTE=Carlbrainiac;n210625]Awesome thanks. Any modification needed or just slot and glue in?[/QUOTE
Just make sure you use a sharp xacto knife for the job but be careful you don't go through the top of the wing.
I do drill small holes in the tab that goes into the wing, this helps give the glue something to grab onto or you could rough up the tab with sandpaper, you get the idea.
So this evening I checked the connections on everything again. Now my retracts all work just fine. So that's good news. But glad I ordered the better servos but I one is still dead and the other one is very juddery through its motion. Not nice at all. Doesnt even feel nice when you power it down and move it by hand.
Such a shame. Would've loved to have flown her tomorrow but with dodgy elevator servos and missing two 80mm push rods I'm grounded ☹Comment
Also what are these blue bits for...
And have many people glued the 2.5mm carbon rod into the slot of the nose gear strut to give it some reinforcement? I read somewhere that someone had done it. Thought it might be a good idea though I am aware adding strength in one location usually just means the weakness gets moved further back...Comment
