    Nice! I have the 1900HP in mine on an Admiral 6S 6000 and I don't think I am even sniffing 110.
    • JLambCWU
      • 267
      It’s noticeably slower on even the Admiral HDs, 4000 and 6000
      • Mizer67
        • 374
        Mine will do 155 mph, briefly.....pointed straight down in a dive from 800 ft. at full power.
        More realistically, on a smoking good battery I've done 113 - 114 mph on 6S consistently with the 1900kv motor at 60 ft. above sea level.
        • fredmdbud
          • 451
          Originally posted by Modelhead
          Here is the approach and landing. It was longer than typical.. There’s another additional 50 feet beyond where she stopped before hitting a rock wall. There are no go arounds. Thoughts on landing the F18 here please. Thanks!
          Flaps and 80mm like in one of the MRC YouTube videos could work.
          Definitely flaps on takeoff.
          • The43rdHammer
            Smithy
            • Aug 2019
            • 118
            • South East England
            Congratulations on your article Hugh Wiedman one for a frame on the wall of the workshop!
            • The43rdHammer
              Smithy
              • Aug 2019
              • 118
              Originally posted by JLambCWU
              Speed DEMON
              F-18 with the 90mm 1835 inrunner on a Roaring Top 70C 5500 🔥 142mph over the ground 😎😎
              Nice looking bird, backdrop looks like Fallon AFB Nevada
              • Polyphren
                • Dec 2020
                • 37
                Hi together,
                my plane is nearly ready for the first take-off. I applied redundancy for the power supply. The electronics and the second battery are mounted on a board to bring them as close as possible towards the COG. However it‘s still difficult to achieve the COG Airguardien recommended.
                since I‘ve no afterburner flashlight, I‘m thinking about calibration weights inside the fans. 2 stripes in longitudinal direction or some weights less in orthogonal direction help a lot.
                what do you think? Is it a good or bad idea?
                Best,
                Eric
                Click image for larger version  Name:	D0413C52-67F9-4119-A2DB-0EACBABF48F2.jpeg Views:	0 Size:	69.5 KB ID:	306448
                • Griffon Wings
                  • Mar 2020
                  • 155
                  Hugh Wiedman !! Congratulations on the f-18 , i just saw it yesterday wile reading the magazine!
                  GREAT JOB Sir !! Admiring you jet 👏🏼👏🏼👏🏼
                  very happy for you , congratulations again Hugh !!
                  • The43rdHammer
                    Smithy
                    • Aug 2019
                    • 118
                    Originally posted by Polyphren
                    ...my plane is nearly ready for the first take-off....
                    Hi Eric, was your F-18 the Stingers digital camouflage scheme in the March Mayhem competition ... if it was, it was wonderful?
                    I'm just getting my F-18 ready now, first flight in a couple of weeks so not in a position to help.
                    I have fitted an Eagle A3 Super 3 gyro.
                    Andy
                    • Polyphren
                      • Dec 2020
                      • 37
                      Hi Andy,
                      yeah, that‘s my baby.
                      • Polyphren
                        • Dec 2020
                        • 37
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1687
                          • Catalonia
                          Whoa!
                          I mean, first of all, I take my hat off, that landing was amazing!
                          This said, I don't think you will land the Hornet there.
                          I don't imply that you aren't perfectly capable of the feat, just that it looks like a terrible idea as it's very difficult that you nail it everytime and this jet is super-picky and tricky.
                          It stalls badly and suddenly, it doesn't tolerate high alpha and it doesn't like to fly slow. If at least you had space for a go around... but you have a tree in the way!
                          The LED afterburner really helps out in that regard.
                          Still, have you already pushed the battery as far aft as possible?
                          I mean, burying the blue-box and clearing the battery compartment allows for a very-rearward placement of the batt:
                          Here are a few pics of mine (and here the battery wasn't even pushed full-aft!).
                          You can use elastic foam pieces to limit how aft the battery sits (I ended up taking them all out but the option is there to make battery placement extra easy), and you can use a foam wedge to lock the battery in place. If you use velcro on the battery tray + the foam wedge, you don't even need to use a strap, battery won't go anywhere :)
                          Click image for larger version  Name:	P1111397.JPG Views:	0 Size:	64.3 KB ID:	306464Click image for larger version  Name:	P1111398.JPG Views:	0 Size:	91.6 KB ID:	306465Click image for larger version  Name:	P1111421.JPG Views:	0 Size:	54.7 KB ID:	306466Click image for larger version
                            Added polyurethane gloss coats to Lucky #7 last weekend...I was really impressed with how smooth it dries! (I've noticed photos don't do these gloss coats justice). Unfortunately this latest ARF+ had a little bit more gatoring than my others so it did highlight those areas a bit but not too bad at all.
                            • Polyphren
                              • Dec 2020
                              • 37
                              @Airguardian:
                              Wow . I took the position of the blue-box as god given. My battery is still below the cockpit. I have to try, how I can replace the blue-box.
                              How did. you achieve to work in this narrow space?
                                • 2137
                                • On planet earth....right
                                Yeahhhhhhh buddy! There’s nothing like a glossed up Blue Angel. As an added bonus, the gloss layer helps seal the decals and reduces paint chipping, from my experience.
                                  Yeah I noticed it definitely gave it a nice thin but hard protective surface...Now if only I can afford one of those gorgeous Jet Power BA's! Maybe in my next life. LOL
                                    • 2137
                                    Click image for larger version  Name:	maxresdefault.jpg Views:	0 Size:	185.9 KB ID:	306523
                                    At least you own a jet that’s less of a hassle and less expensive to operate and maintain. The glass half full effect. Ha-ha
                                    • Airguardian
                                      Post Stall Svengali
                                      • Aug 2020
                                      • 1687
                                      • Catalonia
                                      @Airguardian:
                                      Just unscrew it from the wooden battery tray, unscrew the tray itself and you will see that there is quite some space underneath it.
                                      Once all the wires are properly routed, you screw the tray back in! :)
                                      Here are some pics of this:
ID:	306537Click image for larger version
                                      Some more pics of how the battery totally disappears in the fuselage with my current CG:
ID:	306533Click image for larger version
ID:	306534Click image for larger version
                                      And totally unrelated, but here is my antenna placement... inside the nose gear compartment!
                                      • The43rdHammer
                                        Smithy
                                        • Aug 2019
                                        • 118
                                        Jandro, what CG are you using, is it the same as the manual? I just did mine on my Xicoy CG computer and my battery wasn’t pushes back that far.
                                        Do I need to set the CG further to the rear?
                                        • The43rdHammer
                                          Smithy
                                          • Aug 2019
                                          • 118
                                          Cancel that, I see it at 100mm 👍
