Originally posted by Aros
View Post
, but now I get the #7 on the tail, but then whose counting.
I agree. Best, LB
not that we don't believe you, but seeing is believing
and there's nothing worse than "premature congratulations"!
And yes pictures don't do it justice. I gloss everything I have. Protects the thin paint layer and I do notice less bug strikes chip the paint on the wing edges. Plus in the sunshine man does it pop.... Enjoy number #7
with the recently installed 12 blade 1835 Kv inrunner. I absolutely love that fan in this bird, now I can't image how I even flew it with the original 9 blade 1750 Kv outrunner. It's now blazing fast (at least for me), climbs spectacularly, takes off in half the distance (but the old fan was barely acceptable) and the woooooosh of a 12 blade is sweet. The only fan I will put in any 90 mm from now on (now have 4 of these apparently gold plated motors
, judging on what MRC charges for it-but a must have). Flew it balanced at 100-102 mm, which is as far back as I can get the battery (due to the extra 150 g of weight in the 3D cockpit), even with the circuit board removed and the battery jammed as far aft as possible. Flies very well there but still a bit nose heavy, high alpha's OK, but could be further back, as per
Best, LB
More important than any other mod!
If I ever get around to the video, you'll see! Of course my real problem was created by
