Thrust to weight: 1+ @ 12S
Aloha,
I am crossposting this from RCG: Here is a video from one of the first 12S Tests. The batteries were already quite empty during the video recording (at the end with 20% remaining capacity, Voltage was at 43V and less), but the machine can still hold itself in the air. With full batteries it goes up without any problems.
It is of course unclear whether this will also be the case with the vector nozzles. The additional weight shouldn't be the problem, but the vortex losses in the "balls", i.e. the transitions between the thrust tubes and the movable nozzle, will certainly eat up a lot of power.
A lot of smaller optimizations have not been done yet. E.g. there are no additional air feeds / cheater holes, the electrical wiring has two contact points which it wouldn't strictly need and so on.
Cheers,
Henrik
PS: Ceterum censeo that we have to enable this MiG to go straight up. Hehehe...
Aloha,
- AUW: 5,715g
- Maximum current in this video, to be confirmed: ~120+ Ampere at 43-44V, ~5.25+kW
- Maximum current with full batteries, not in this video, T/W > 1: ~134A, ~6.5kW
- 22° Celsius, 550 AMSL
- Batteries and wires and plugs became a bit more than handwarm, but not hot
Cheers,
Henrik
