  • ochoaoctavio89@icloud.com
    Octane209
    • Jul 2020
    • 15
    What receiver are you guys planing on using (spektrum)?
      I use Graupner, so I put a GR-18L (9-ch) in mine. I put the gyro on Ch 7 and I'd like to pull the nose steering off the board and put it on Ch 8 so I can adjust the steering without having to adjust the rudders. I'll do that after the maiden tomorrow.
      • Mud Duck
        • Feb 2022
        • 46
        Mud, go to the link for the print at Squadron Prints. The text is included below the print example.
        https://www.squadronprints.com/item/...2A-Spirit.html
        Thank-you crxmanpat! That worked even better. 🙏
        • kallend
          • 1877
          AR8020T
          Has built-in altitude and flight pack voltage telemetry but no gyro. About $90
          • Mud Duck
            • Feb 2022
            • 46
            I plan on using this Spektrum AR9020 with satellite receivers. Trying to stay away from AS3X since the B-2 already has the gyro Click image for larger version
            • Mud Duck
              • Feb 2022
              • 46
              Perhaps it is overkill and the instructions don’t call for it, but since I will likely be removing the outer wing panels often for transportation, I have installed wire harness connector protectors on the wing wiring harnesses using the protectors designed for a 4S Li-Po battery pack; I don’t like pulling directly on the wires. (see photos). Click image for larger version  Name:	7E151D80-02A9-4DE8-A094-FD8CC79AF7BF.jpeg Views:	0 Size:	155.8 KB ID:	342194Click image for larger version  Name:	2ED36A9E-21FB-4DB0-BC44-E7CE8E0BB6EF.jpeg Views:	0 Size:	75.6 KB ID:	342195
              • Gilatrout
                RC Pilot Addict
                • 806
                • Albuquerque NM
                Out for delivery \o/
                I'm going with a sepktrum telemetry receiver and an srxl2 remote.
                Those protectors look like a great idea all around.
                • fordster39
                  • Aug 2018
                  • 10
                  • Alabama
                  I received my B-2 yesterday, I have not started setting it up yet but I do have a question. Maybe it’s been answered before and if it has I am sorry for asking again. Is the gyro setup to accept S-BUS out of the box, or will it require the programming card to enable it ?
                  • Flying Dutchman
                    • 26
                    • Near Amsterdam, The Netherlands
                    I may have a factory wiring issue….please look at yours.
                    The photo shows the A, E, R connections for the RX.
                    Shouldn’t ELEVATOR red go to the center pin?
                    When I plug it up and bind the RX, it starts out with normally open clam shells. But, when the gyro locks up… the left clams go fully open and right clams go fully closed.
                    If I disconnect A, E, R from RX, the clams stay normally partially open after the gyro locks up.
                    Gyro light is blinking blue with A, E, R not connected to RX which makes sense
                    Thanks!
                    Edit: I had a spare connector. Wired the plane’s elevator to the new connected red wire. Now the clams stay normal when the gyro locks up, but I have no E, R, or A function. Gyro stays blue flashing.
                    I only have 6 RX function slots and a 7th for connecting the BEC to RX. So, I have the plane’s MODE connector open.
                    Click image for larger version Name:	558FC379-B8E2-40F3-9A2B-16A6142CC8A6.jpeg Views:	0 Size:	58.9 KB ID:	342139
                    @GG,
                    Additional to your earlier solution of the problems above:
                    please connect your ‘MODE’ connector to a free slot in the receiver, and have this channel on a 2- or 3-way switch.
                    The gyro should show a continuous RED led (basic gain mode ‘on’).
                    It seems that your gyro is not in the correct mode, with it’s blinking blue led!
                      • 8814
                      Originally posted by Mud Duck
                      Thanks XViper, yes, what a great reason to use the control board to do the reversing instead, you’re exactly right, but I failed to mention that the gyro is moving in the correct direction with the radio-reversed servos as well. 🙏
                      I take it that you saw my post about ignoring the colors of those single wire leads and treated them as they are "signal" leads? That being the case and it all checks out, I think that part of it is good. If you're still having problems with some bits not working or not working right, I suggest you go to the "board" and the gyro, yank each connector off and vigorously wiggle them back on. If there is a poor contact, this should "freshen" it up. I've done this in the past and it has resolved some of the problems. Since these boards tend to use common ground circuits, a totally unrelated plug may have influence on the ones that don't work.
                      • Jax Quad
                        Seriously addicted to RC for over 15 years
                        • Jan 2019
                        • 11
                        • Jacksonville, FL
                        Here is a quick demonstration of the gyro/stabilization settings. We are all set up and ready for many flights tomorrow. We'll have the camera crew out as well.
                        • MeyerVW
                          crash test pilot
                          • 288
                          • Dude who likes flying.
                          I also hate pulling these. Where did you get the protectors?
                            • 8814
                            Originally posted by Flying Dutchman
                            @GG,
                            Good point. A switch must be assigned to that channel (port) via "channel assign" menu or the gyro won't get any "commands".
                              • 5401
                              Standard PPM. You need a programmer to change it, see pg9 of the E52 instruction manual.
                              • Jax Quad
                                • Jan 2019
                                • 11
                                • Jacksonville, FL
                                Does anyone know if the drag brakes should be perfectly even with the wing when fully closed? Ours are not. Everything else is set up properly but our closed drag brake is pointing down.
                                  • 5401
                                  Yes...
                                  Edit.. let me add that if both are down you are adding wash IN which is unstable. Both UP is wash OUT which is a little more stable. One up one down and you are adding roll... Make them even.
                                    • 5401
                                    Not sure where you like to shop but there are many places. I don't use them so I have a bunch I took off batteries.
                                    Amazon.com: RuiLing 5pcs 6S JST-XH AB Clip Buckle Balance Lead Wire Head Connector Protector Plug Savers for RC Battery Cable : Toys & Games
                                      • 8814
                                      https://www.youtube.com/watch?v=zyqecRPjtps
                                      Very nice demo. Can you remind us again please ....................... what is "attitude hold"? I think James told us in the video but I forget and his video is long. "Basic gain" is "like" AS3X in Spektrum and "trainer mode" is "like" SAFE but a bit different.
                                      • radfordc
                                        • 375
                                        • Lansing, KS
                                        Did you watch the MRC weekly live show yesterday? They made a very strong point that the drag rudders must line up with the wing TE.
                                        • Flying Dutchman
                                          • 26
                                          See p.5 of the gyro manual for all of the different modes:
                                          https://cdn.shopify.com/s/files/1/10...ion_Manual.pdf
                                          Attitude lock mode:
                                          During the Attitude Lock Mode, the red LED flashes slowly. In this mode, the gyro will make continuous corrections to the rotation of each axis. Moving the stick will make the aircraft rotate at a certain speed around the corresponding axis of rotation, and once the stick is released, the aircraft will be locked at the current position immediately. This Mode is useful for certain types of multi-rotors, and 3D acrobatic fixed wing aircraft.
