  • Xtraflyr
    • 96
    • Morris County NJ
    Noticed my nose art is pealing off. Wondering if I did something wrong?
    • Pete Lane
      Turbine lover
      • 290
      • Los Gatos Cally
      Did you use the decal setting solution ?
      • bill34207
        Jet Junkie
        • 455
        • Bradenton, Florida
        Shot this video of my buddy Steve's A-10 today. It's been edited to eliminate the bad "ridem' cowboy" landing. (Steve didn't want it uploaded to YouTube) Luckily it didn't do much to the plane and he few again. So I shot the landing from his 2nd flight and put it in place on this video
        • dahawk
          Augermeister
          • Jun 2013
          • 1006
          • Keller,Texas
          Nice vid. I like how he kept her close where we can see it.
          • Pogo
            • 452
            • Waterford, Ontario, Canada
            For those of you going with the "shocks on the main gear" mod on RCG I just posted over there on my take on it:
            Originally Posted by mattmanraptor
            The shocks are 85mm long, body is 12mm diameter, Pictured: TrackStar Aluminum Shock Absorber Set 85mm (2) S160085 HK
            The silicone oil used(3 weights),,,, Shock oil 100wt, Diff oil 500,00cSt and 1,000,000cSt
            some 4mm and 5mm brass tubing
            Bolts: a 3x14mm button head and a 4x16mm hex head
            a 3mm tap
            I've expanded on Matt's brilliant idea a bit in order to improve the geometry of the shock and hence it's function. The triangle created by the bracket allows full stroke of the shock and no spacers were needed for the install as it's more in line this way. The bracket is from 1.4mm aluminum I had on hand, mounted with 3mm machine screws. Not too much foam and retract mount plastic needs removing with this configuration. I used the same shocks Matt sourced (thanks again man!) and they're filled with the 5000 diff oil- the dampening action feels good but as I've yet to fly this mod we shall see. I've only 5 flights on my Hog, all good landings, but a slight trough in our grass field is launching it on the take off run prematurely, ass high, into the air and I'm hoping this will reduce that. Not to mention the inevitable bounced landing that will happen at some point....
            Tom
            • ryramZ
              Pilot Ryan
              • Dec 2012
              • 814
              That's cool! Is the stock spring still in there?
              • Xtraflyr
                • 96
                • Morris County NJ
                nope just straight up water.
                • Pogo
                  • 452
                  Hi Ryan- yes, the spring remains.
                  Tom
                  • Xtraflyr
                    • 96
                    • Morris County NJ
                    Anyone do any mods to get the hot air away from the battery compartment? My batts are warmer then I like after my flight.
                    • Pete Lane
                      Turbine lover
                      • 290
                      • Los Gatos Cally
                      What bounce !
                        I took the nose gear door off and that really helped.
                          I noticed the same thing. I went into the "refuel port" at a downward angle with a sharpened 1/2" copper pipe, twisting slowly as you go. Then painted the inside with dark gray paint. Then I opened up the exit ports on the underside with a sharpened 3/4" copper pipe. Dropped battery temp by about 20 deg.
                          • MikeT
                            Here......Hold my beer.
                            • 1060
                            I found that stuff to be a great help in my decal application. I recommend using both Solvaset and Microsol.
                            Mike
                            • t33jetman
                              • 515
                              Air intake in the front and an exit hole on the left rear side of the plane for coolong.
                              Click image for larger version  Name:	Screenshot_2017-08-06-14-02-22.png Views:	2 Size:	579.6 KB ID:	93502Click image for larger version  Name:	Screenshot_2017-08-06-14-04-07.png Views:	2 Size:	471.9 KB ID:	93503
                              • Sniper93
                                • 3
                                if anyone finds a perfect match for the gray paint on the A-10 please let me know where you got it and if there a code. I tried Lowe"s but they couldn't match it close enough for me to use it. too dark
                                • dahawk
                                  Augermeister
                                  • Jun 2013
                                  • 1006
                                  • Keller,Texas
                                  I went to Home Depot and the match was okay but slightly too light. Go figure. Someone here posted the codes with a pic. Said it was perfect. Might have to sift through the thread.
                                    • 2137
                                    • On planet earth....right
                                    I posted the paint match I got at Home Depot a few pages back. They are a very very close match in my opinion. :Cool:
                                    Try it out and see what you think. It's nice that the paint is very cheap for how much you get, so it's worth checking it out.
                                    Here are the pictures I posted before:
                                    Light Gray:
                                    Dark Gray:
                                      • 2137
                                      My Freewing A-10 90mm (using Freewing 12-blade fans with 1550kv outrunner motors) EDF jet is almost ready to go. I have to solder up the Freewing 130A ESC's and finish some small things here and there. Below are some pictures of the painting and weathering. I wasn't sure the weathering would look good. Right after its new paint job and shinny clean surface, it looked too much like a toy. The weathering toned it down well and looks more realistic now. The bottom of the jet is still gray on purpose for a little color contrast in hopes of improving orientation, although it doesn't necessarily need it in my opinion.
                                        • 2137
                                        a 3mm tap
                                        Tom
                                        Great engineering Tom and Matt! Looks awesome.
                                        • HellHathNoFury
                                          • 247
                                          Great job T-Cat.. Now onwards with your favourite part.. Soldering..:)LOL
