  • t33jetman
    • 515
    Click image for larger version  Name:	 Views:	1 Size:	93.1 KB ID:	134291 One year old and still going strong with original equipment. I love this plane.
      • 8835
      Flew mine for the first time this season, with the newly added trailing link front strut. Landed it the same way I've always done BUT today, there was NO BOUNCE. This is the way I should have modded it from the very beginning. Great flying plane. Now a great landing plane.
      • RCAV8R
        Certified Plane Nut
        • 355
        • Medford, Oregon
        I remember when you first got her finished after the release...it's a classic look and really nicely done! Rob
        • Woodcock
          Old Returning Pilot
          • Apr 2018
          • 830
          • SoCal
          Very Nice!
          Woody
          PS, I just received my 64mm A-10 today. Looking forward to putting it together, and flying. Figured if I like it, I'll go for the bigger one.
          • Shirty
            Hobby Squawk Water Boy
            • 1067
            • Perth, Australia
            Yeah that's an awesome scheme t33, I also remember when you first posted it ages ago, and it still looks sweet. Really nice mate
            • t33jetman
              • 515
              Thanks shorty and Woody.
              I'm busy with the new FW F-4 paint job now can't wait to finish this one.
                Heck yeah man very cool!
                • janmb
                  Slow and low
                  • 729
                  Awesome scheme!
                  • brrzee
                    • Aug 2017
                    • 48
                    Has anyone put small carbon fibre rods inside the fuse for extra support? Thought i have read something about that with this jet
                      Howdy brrzee! The A-10 has channels molded into the sides of the fuselage. They are just the right size for some carbon fiber tubes or squares to be glued in for extra support. I used square tubing on my first A-10, but carbon fiber arrow shafts will fit tighter and give better support. That is what I am going to do to A-10 #2!!!
                        Also, welcome to Hobby Squawk!!!! Glad you are here!!! Have a very blessed Memorial Day.
                        • RCAV8R
                          Certified Plane Nut
                          • 355
                          • Medford, Oregon
                          I put them in brrzee...I got the square rods. I have had a couple of hard bounces, one that cracked the NG retract, but have had no damage to the fuse. I can't say if it helped or not, but it certainly hasn't hurt! Rob
                          • brrzee
                            • Aug 2017
                            • 48
                            Sorry about last post..thx for the info..will pick some small carbon fibre tubes up this week..cheers everyone...happy flying
                              If you have a post that's unintentional, you can always hit the edit button and from there under the text box theres a delete button. Just an FYI
                              • MikeT
                                Here......Hold my beer.
                                • 1060
                                I did the same not sure if it needed it but figured what the heck.
                                Mike
                                • Helmsman52
                                  • 247
                                  • Saint Paul, MN
                                  Ok this was my fourth flight and I have the trailing link gear and my question is, why does the front gear collapse and stay collapsed? Watch 3-4 sec into take off it drops and stays! It did the same on my first flight but not as long.
                                  I am thinking that a compression spring is going to have be inserted on the strut or a piece of fuel line so it doesn’t bottom out?
                                  • Helmsman52
                                    • 247
                                    • Saint Paul, MN
                                    Beautiful!!
                                      • 8835
                                      It shouldn't do that. It should be able to full collapse and spring right back, even with the weight of the plane on it. There should already be a spring inside the cylinder. Check to see if there is one in there. When you compress it by hand, does it feel "sticky"? Something is binding it. I suggest you use a drop or two of machine oil or 3in1 oil and work it into the sliding plunger part. Also put some oil on those links that need to rotate on the pins. Also check to make sure there is no screw on the side of the cylinder that might be screwed in too much and it's touching the piston that goes in and out. I don't have mine handy to know if there is a screw or not. I'm guessing based on another trailing link suspension where there is a screw that goes into the side of the cylinder. Once loosened a bit, the piston goes in and out freely. If there is a screw, put it back in with some FoamTac on the threads so it won't fall out.
                                      • Shirty
                                        • 1067
                                        • Perth, Australia
                                        I'm also guessing going from zero to wot with the resistance on grass might be helping push it down. (Though I'd expect that to come up after it gained speed). Try also easing up the throttle.
                                        • Helmsman52
                                          • 247
                                          • Saint Paul, MN
                                          I was thinking the same Shirty at first. My first flight I didn’t film but on the take off roll out it nosed halfway through once applying more throttle.
                                          Now this clip is the second flight take off and landing. I full throttled it to see a difference and there was no prob lol.
