  • themudduck
    -TMD- Foaming at the Mouth!
    • 1041
    • Burton OH (near Cleveland)
    He came in hot with no flaps and slammed it in. In slow motion, no less! When this model is brought in with full flaps, it slows down to a crawl and lands like a baby, Well sure, if you drive it in with a carrier landing of course its going to bounce and you'll be lucky not to tear the gear clean off!
      Yup flaps are your friend. I use them all the time.
      • Grady.c
        Warbird Fan
        • Apr 2018
        • 178
        • Colorado
        Looks good to me.....:a10:pop
        • Dirty Dee
          • 768
          • Northern Illinois
          Pushing to have my cockpit mod finished by Friday and the Hog back in the air for Saturday. Most of the hard stuff is now behind me so I might have everything ready to close up by tomorrow night
            Very nice DD!
              • 4857
              Thingiverse: "[T]he other one maintains 100% FSA, but uses an inner nozzle to look more scale."
              DirtyDee, Are you using the exhaust nozzle that looks more scale for your A-10? I'd like to know if you noticed any thrust differences, using your scale design. Best. LB
              • Dirty Dee
                • 768
                • Northern Illinois
                Hey LB, I have them installed on mine but will be flying with them for the first time this weekend. Several Users on RCGroups have flown with the scale nozzles and have commented that they flew fine. For some that have experienced a pitching with thrust applies have mentioned that these nozzles have tamed the pitching.
                here is a picture "bettsmums" posted on RCG with these nozzles:
                  • 4857
                  DD, Outstanding. Would you post your thoughts after the weekend A-10 sorties? Best, LB
                  • Dirty Dee
                    • 768
                    • Northern Illinois
                    Will do. Full disclosure: I have only had 1 flight on the A-10 since owning it, and the past few years I haven't been able to go flying as frequently in general. I only have 4x5000mAH packs so not sure how many flights I'll get in, but majority of the time might just be getting re-familiarized with dirty flight and landing approaches. Either way I'll give my thoughts.
                    Also my plane is fitted with oleos all around so I'll try to give feedback on the bucking bronco with landing on a runway. Hoping to get some flight video as well with the Mobius.
                      • 4857
                      Roger that.
                      • Dirty Dee
                        • 768
                        • Northern Illinois
                        Originally posted by janmb
                        Wheels conflict with the foam when retracted (and I even have slightly narrower and smaller wheels than stock)
                        Will have to do some minor grinding for my part
                        I operated my gear today with the new struts installed. I didn't experience any issues, and cycled a few times without binding. Though I believe the wheel wells will need to be deepened a bit, as the retracts sounded like they were working harder at the last moment before stopping.
                        I'm guessing since the oleos are straight now vs the TLs having a slight rearward offset, the wheels are diggin into the wells a small amount.
                          That was one thing I wondered about with the different setup
                            Do the wheels rotate in the up position?
                            • Dirty Dee
                              • 768
                              • Northern Illinois
                              Freely? No. A fair bit of resistance. I'm going to cut a strip of sandpaper the width of the wheel, wrap the wheel in it, and turn the wheel back and forth to enlarge the space. Might take a few iterations operating the gears, but should work
                              • RCAV8R
                                Certified Plane Nut
                                • 355
                                • Medford, Oregon
                                So I have the upgraded mains and my wheels do not turn. What do you think Steve...is that putting too much pressure on the retract? Rob
                                  • 4857
                                  Ahhh, a blank canvas. Should I go Picasso or Rembrandt? Me thinks a personalized Peanut with DD/TI/RCJD nuances. Best, Elbee
                                    Possibly so Rob. Might want to relieve that just to be on the safe side.
                                      Where did you get the unpainted airframe from?
                                        He didn't..............it's a stripped airframe that he commented about on post#7987
                                          • 4857
                                          I could tell you, but then...:Bomb:
                                          RCJD, It was a matter of chemical incompatibility, i.e., acetone vs latex and approximately 10 hrs of application and removal. :Dizzy: Best, LB
