  • Dirty Dee
    • 768
    • Northern Illinois
    Here is the AN/ALQ-119 ECM pod I just finished.
    https://www.thingiverse.com/thing:2852911
    • janmb
      Slow and low
      • 729
      Awesome work as always.
      Finally getting into some modelling and printing myself - but mainly doing practical stuff like mounts and tools for the time being - unsure if there is enough of an artist in me to ever do cosmetics half as good as you
      • Errick
        Pilot in Training
        • Apr 2018
        • 5
        • The TARHEEL State
        So, I finally get home from a working trip since ordering my A-10. Super excited to get back and start the build. I get all the way to where I need to install the receiver (AR9030T...it came with my Ix-12 controller) but all the wires coming off the aircraft board will not fit into the receiver because they (the wires) are all rectangular shaped ends, where as the receiver only takes a half-tapered plug.:Angry:. Has anyone else run into this....and what was the fix?
        • john2kx
          • 112
          • North Augusta, SC
          You can trim the corners of connector with xacto blade or file to allow proper fit to rx.
          Freewing A10, F4, F22, Sebart Avanti S mini
          • MikeT
            Here......Hold my beer.
            • 1060
            I find sandpaper works great.
            Mike
            • janmb
              Slow and low
              • 729
              As others have said, carefully file/trim the correct corners on your servo connectors.
              I use a dremel with a fine grinding tool for such mods, but lots of ways to approach that.
              • MikeT
                • 1060
                I get to aggressive with power tools on small projects like, this must be my age.
                Mike
                • janmb
                  Slow and low
                  • 729
                  Mike
                  Sounds familiar lol
                  Trick is to use a sufficiently fine grinding tool so things don't happen too fast
                  • Dirty Dee
                    • 768
                    • Northern Illinois
                    Very cool, and thanks.
                    Ive been at this for over 10 years so I have picked up a few tricks along the way. Thankfully most ordinance is fairly simple shapes and nothing too complex, so its not too bad. Start with the general outline, then slowly start adding the details.
                    • downwindleg
                      • 1279
                      • Friday Harbor, Washington
                      Just be sure you have the correct orientation on the plug before sanding/trimming;)
                      • Errick
                        Pilot in Training
                        • Apr 2018
                        • 5
                        • The TARHEEL State
                        Tried to trim with an exacto blade but ended up cutting thru...
                        • Errick
                          Pilot in Training
                          • Apr 2018
                          • 5
                          • The TARHEEL State
                          Thanks for everyone's input. It was greatly appreciated. I ended up pulling out the dremel as a last resort, but all plugs now fit. Thanks again everyone.
                          • purduephigam
                            Jet degenerate
                            • 352
                            • Plainfield, Illinois
                            My apologies for me being the mayor of amateurville, but I have a question on the ESC throttle calibration versus the calibration of the ESCs. I reviewed the video MRC posted on the B-24, but the sounds are different so I ended up just syncing the ESCs to factory default settings. The fans seem to be synced up per the instructions in the video, but there is no option to calibrate the throttle with the A-10 manual. Additionally, it seems that the instructions for calibrating the throttle range and calibrating the ESCs are the same. That being said, when I set up for throttle range calibration, it enters programming mode. I'd imagine things are fine as is, but I just want to make sure I get this right as it seems to be much easier with my single fan jets.
                            • RCAV8R
                              Certified Plane Nut
                              • 355
                              • Medford, Oregon
                              To calibrate the throttle range, you have to unplug one of the throttle inputs to the circuit board in order to isolate one motor. Then you put your throttle all the way up, plug in the battery that has the BEC connection on it, and when you hear two beeps, you drop your throttle. At that point I believe you are in the programming mode if you want to do more. To isolate the other motor, you swap the leads into the circuit board. I just got through doing this and I had to try several times to isolate each motor...so I know I'm probably missing a step in here somewhere. RCJetdude has this down cold! Rob
                              • purduephigam
                                Jet degenerate
                                • 352
                                Yes, we're playing a little message tag as he wants to walk me through things over the phone. This was just my attempt at figuring things out without him having to dedicate weekend time for a dummy like me. In Steve we trust :)
                                  I always tie my battery leads together to sync both at the same time.
                                    • 8835
                                    I also prefer to sync them at the same time. For me, I hold the 2 ESC connectors in the same hand, have both battery connectors close and handy and plug them in really fast. If you fumble, just disconnect and try again. Or you do what Ryan said in his video for another twin. You disconnect the throttle lead from the receiver, plug both batteries in, then plug the throttle lead back in. Both ESCs initialize and start their beeping at the same time.
                                      Looking for a Warthog owner that has an LAU Rocket Pod in any shape/condition that they are not using and would sell at a reasonable price.
                                      I revitalized the damaged one from my destroyed Hog to be repurposed on my 80" span O-2 Skymaster project and requires a second rocket pod.
                                      Please PM me if anyone would like to help me out here.
                                        Hey Charlie,
                                        Your PM box is full. I have a spare rocket pod I could send you. $10 should cover it with shipping. Send me a PayPal at crxmanpat@gmail.com, then PM me your mailing address and I'll get it out to you tomorrow.
                                        • Sky Wolf
                                          Flying Ant
                                          • Sep 2013
                                          • 731
                                          • Irving, Texas
                                          I didn’t have much issue getting the leads to fit, just a little trimming. My issue with the AR9030 was getting to to work in the A-10 period. I, along with a few others, found it difficult to get it to sync with the ESC’s.
                                          Switched to the AR8010 and had no issue. Never could figure out what the problem was.
                                          If you have or eventually do get yours to bind correctly please let me know what steps you took.
