I will say it again, being nose heavy is not all the issue with this jet and the problems guys are having with the bouncy bouncy, its the timing of the flare, coming in to hot and letting this jet settle onto the runway without any elevator input until its too late is the issue, I have flown mine with stock gear on pavement well over 100 flights and nose heavy, you have to slow this jet down on your downwind leg, let those big flaps do their job, once on final and holding a little up elevator and throttle to keep the descent rate nice and slow and I do agree with you Phantom on this, find your spot where your going to land, if you fly nose heavy like I do, hold the flare until the speed bleeds off and it will settle nice and slow with no energy left to bounce and if you do get a bounce, it is more like a hop with no damage, I know that the CG farther back may help some but I tried CG aft and forward and it still needs the same approach and flare, I even do no power landings, not recommended of course, I think what most guys are skipping on the jet is, to go out and fly with full flaps down and gear down, practice it's slow flight, be surprised how slow it will fly, not being a know it all here but telling every hog pilot that comes along that its the CG problem is not really helping much to me, next time they go out it will be the same thing, landing on the nose gear is a no no, we all know that, flaring to late and not holding the flare is a no no, being extreme nose heavy could be a problem, Yes true but the stock gear holds up very well, even after well over 100 flights, not one part was replaced on mine, so my opinion is a little different on this jet I know but the CG thing is maybe a part of what guys are having trouble with it, the real problem is flying a heavy jet this size and not flying it to the runway, a forced landing with this one will get you a hog bounce and bacon.
