I'm picking up what you're laying down. As for the nose gear door, I know on the full scale A-10, that door stays open until the retract cycle. What I might try to do is use the FW F-16 circuit board for the nose gear and door. I have a spare. Also the A-10's no longer have the pod on the right side hanging down. I'll be cutting that off. Then again, kit bashing is fun.
No need to hack that off........Cap'n Mike in his build video attaches it to the fuse with a 6mm screw ;)
I'm picking up what you're laying down. As for the nose gear door, I know on the full scale A-10, that door stays open until the retract cycle. What I might try to do is use the FW F-16 circuit board for the nose gear and door. I have a spare. Also the A-10's no longer have the pod on the right side hanging down. I'll be cutting that off. Then again, kit bashing is fun.Warbird Charlie
I meant the pod, not the whole thing. The A-10C no longer uses the Pod. My latest FMS build and graphics for the 107th FS Selfridge which I'll use on the FW when it gets here. This is the Brig. Generals B1RD.1 PhotoComment
Hey Aros,
Is there any way to find out the FS # of the color gray used in the production of the Hog? I'd like to start looking at the shades around it to think about how to highlight panel lines, etc.. Can't wait for the build video by Alpha on how he recommends doing it on a production plane, as opposed to the prototype (white). RobComment
Just ran across this hat ! Gotta have this for when mine comes in.
Our A-10 Warthog Cap is a must have for fans of military aviation. The Cap features the A-10 “shark teeth” nose art stitched along the visor and the front view of an A-10 embroidered across the front. On the back, “Brrrrt”, the sound commonly associated wwww.TSHobbies.com
Hobby Paint racks and acrylic display stands for collectibles.Comment
Since it's getting close to the A-10 arrival can someone share some tips and pointers for water slide decals? I know the nose decal is two pieces (a right and left) so I'm looking for advice on getting them on and in the right place.
I think I've seen posts somewhere that say to soak them in soapy water (instead of clean water) but I don't know why.Comment
A quick goggle search nets a ton of info on this. Taking your time is key.Since it's getting close to the A-10 arrival can someone share some tips and pointers for water slide decals? I know the nose decal is two pieces (a right and left) so I'm looking for advice on getting them on and in the right place.
Mike\"When Inverted Down Is Up And Up Is Expensive\"Comment
I found a bunch of stuff but it seems more geared toward plastic models. If it's the same with a foam plane then cool, just wanted to be sure there aren't any gotchas with the foam.
This video seems pretty good, I've watched it a few times now.
Hobby Lobby's Mike Hines goes through the process to apply water slide decals to model airplanes.Comment
Unless I missed something in the video the only water slide decals that video shows are the two NO STEP decals on the canopy. The water used looks clear and I didn't see any use of a decal setting solution. I assume the water temperature doesn't matter, I figure room temperature is what I'll use.
This probably seems like a simple thing but for those of use that haven't done it we don't want to screw up on a $549 model. :)Comment
RCAV8R, let me see if I can find out on the color for you....Brad, that was not a real t-shirt, just one I mocked up for fun at the peak of our pre-pre-sale exuberance. ;)My YouTube RC videos:
