  • ColtPilot
    Hobby Squawk Advanced Pilot
    • Jun 2015
    • 538
    • Saint Clair Shores, Mi
    Originally posted by bill34207
    The missing main doors were covered early on. Not sure if it was here on RCG but they were omitted to avoid having them hit by the wheels with the trailing link struts. Not to mention getting torn off on grass field ops.
    I'll take the great suspension and live without the doors myself. Once the gear is retracted you don't really notice their absence.
    I'm picking up what you're laying down. As for the nose gear door, I know on the full scale A-10, that door stays open until the retract cycle. What I might try to do is use the FW F-16 circuit board for the nose gear and door. I have a spare. Also the A-10's no longer have the pod on the right side hanging down. I'll be cutting that off. Then again, kit bashing is fun.
    • dkalwishky
      Warbird Lover
      • Sep 2015
      • 1382
      • Des Moines, IA
      Yea, I know it's unicom frequency. I was seeing if anyone was paying attention.
      I noticed but didn't say anything. Ground is generally 121.#
        No need to hack that off........Cap'n Mike in his build video attaches it to the fuse with a 6mm screw ;)
        • ColtPilot
          • Jun 2015
          • 538
          I meant the pod, not the whole thing. The A-10C no longer uses the Pod. My latest FMS build and graphics for the 107th FS Selfridge which I'll use on the FW when it gets here. This is the Brig. Generals B1RD.
          • RCAV8R
            Certified Plane Nut
            • 355
            • Medford, Oregon
            Hey Aros,
            Is there any way to find out the FS # of the color gray used in the production of the Hog? I'd like to start looking at the shades around it to think about how to highlight panel lines, etc.. Can't wait for the build video by Alpha on how he recommends doing it on a production plane, as opposed to the prototype (white). Rob
            • Shirty
              Hobby Squawk Water Boy
              • 1067
              • Perth, Australia
              Just say down to have tea (dinner for you yanks), to watch last weeks nascar and look what I see. Must be a sign that mines close. :bluetongue
              Sorry bad pic, it's off my tv.
              • Dewey H Lee
                WARBIRD JUNKIE
                • Apr 2015
                • 919
                • Fayetteville NC. US
                Yep thats an Omenov10f:ov10.
                Dewey l
                • TSHobbies
                  Hobby Squawk Warbird Pilot
                  • Nov 2015
                  • 671
                  • Cartersville GA
                  Just ran across this hat ! Gotta have this for when mine comes in.
                  Our A-10 Warthog Cap is a must have for fans of military aviation. The Cap features the A-10 “shark teeth” nose art stitched along the visor and the front view of an A-10 embroidered across the front. On the back, “Brrrrt”, the sound commonly associated w
                  www.TSHobbies.com
                  • dkalwishky
                    Warbird Lover
                    • Sep 2015
                    • 1382
                    • Des Moines, IA
                    Here is another A-10 cap they sell.
                    <h2>Superbly Embroidered</h2> Featuring high quality embroidery, Cap features a A-10 Warthog on the front and the description A-10 Warthog on the right and U.S. Air Force left side of the bill. Adjustable strap ensures one size fits most. Made of 100% co
                      • 2816
                      • Arlington, TX
                      Historic Aviation - The Enthusiast's Choice for Aviation Models & Kits, Collectibles and Much More
                      • dkalwishky
                        Warbird Lover
                        • Sep 2015
                        • 1382
                        • Des Moines, IA
                        Since it's getting close to the A-10 arrival can someone share some tips and pointers for water slide decals? I know the nose decal is two pieces (a right and left) so I'm looking for advice on getting them on and in the right place.
                        I think I've seen posts somewhere that say to soak them in soapy water (instead of clean water) but I don't know why.
                        • MikeT
                          Here......Hold my beer.
                          • 1060
                          A quick goggle search nets a ton of info on this. Taking your time is key.
                          Mike
                          • dkalwishky
                            Warbird Lover
                            • Sep 2015
                            • 1382
                            • Des Moines, IA
                            I found a bunch of stuff but it seems more geared toward plastic models. If it's the same with a foam plane then cool, just wanted to be sure there aren't any gotchas with the foam.
                            This video seems pretty good, I've watched it a few times now.
                              • 2137
                              • On planet earth....right
                              Alpha made a good video of the FlightLine P-38 build, and in there is covers some details about water slide decals and application.
                                I have used a Model Masters decal setting solution that worked well but they are not that hard to apply.
                                • dkalwishky
                                  Warbird Lover
                                  • Sep 2015
                                  • 1382
                                  • Des Moines, IA
                                  Unless I missed something in the video the only water slide decals that video shows are the two NO STEP decals on the canopy. The water used looks clear and I didn't see any use of a decal setting solution. I assume the water temperature doesn't matter, I figure room temperature is what I'll use.
                                  This probably seems like a simple thing but for those of use that haven't done it we don't want to screw up on a $549 model. :)
                                  • downwindleg
                                    • 1279
                                    • Friday Harbor, Washington
                                    Whatever happened to those cool shirts that Aros put up? Always wanted an A-10 version of the B-52 ripping through the shirt. Hey Aros, what was the source on that? Brad
                                      • 8202
                                      RCAV8R, let me see if I can find out on the color for you....Brad, that was not a real t-shirt, just one I mocked up for fun at the peak of our pre-pre-sale exuberance. ;)
                                        Well it sure got some peoples interest up.
                                        • TSHobbies
                                          • Nov 2015
                                          • 671
                                          • Cartersville GA
                                          dam...got interrupted when I was going to order that hat, now its on BO! grrrr just my luck
                                          www.TSHobbies.com
