Here is where mine lines up. Pretty much in line with the dimples on the back of the fuse.Originally posted by afjetmech View PostAnyone have a picture of the so called "correct elevator position" called out in the manual? Maybe a measurement up from the bottom of the rudder or something.
That's where I'm at too...."The Dimple Line"Originally posted by RCjetdude View PostLon
Did you use and type of decal solution to attach the nose art?Originally posted by bill34207 View Post
Just warm tap water. But, who knows what kind of chemicals are in it these days.Originally posted by hellcat716 View Post
Did you use and type of decal solution to attach the nose art?My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
I'm not sure who may have said the Hobbyking wing bags don't fit, but I just opened the box with the A-10, inspected the parts, and immediately tried the 76cm wing bags. The 76cm Hobbyking wing bags fit these wings flawlessly and still allows the bag to be zippered shut and Velcro straps used. Now, yes, one wing fits in each wing bag, not both wings in one bag. However, we already knew that with the depth of the wheel wells, etc. Also, I haven't tried it with ordnance installed, but I never ordered these to fit the ordnance attached to the wings, they would be carried separately, kept at home, or in the car and used when necessary. So, overall it's money well spent on these excellent bags:Cool:. I don't think we could have found a more inexpensive choice that works.
I ordered the 90cm wing bag and both fit in one bag with room to spare https://hobbyking.com/en_us/hobbykin...-61-x-7cm.htmlOriginally posted by T-CAT View PostI'm not sure who may have said the Hobbyking wing bags don't fit, but I just opened the box with the A-10, inspected the parts, and immediately tried the 76cm wing bags. The 76cm Hobbyking wing bags fit these wings flawlessly and still allows the bag to be zippered shut and Velcro straps used. Now, yes, one wing fits in each wing bag, not both wings in one bag. However, we already knew that with the depth of the wheel wells, etc. Also, I haven't tried it with ordnance installed, but I never ordered these to fit the ordnance attached to the wings, they would be carried separately, kept at home, or in the car and used when necessary. So, overall it's money well spent on these excellent bags:Cool:. I don't think we could have found a more inexpensive choice that works.
I have the 76cm and it's a tight squeeze. No weapons and took the pylons off. Am I missing something ?
14cm :)Originally posted by dahawk View PostI have the 76cm and it's a tight squeeze. No weapons and took the pylons off. Am I missing something ?
I see many comments about the water slide decals being applied...one thing I do know from many years of scale model building is water slides like a gloss surface to lay on ...Future Floor wax works great..or is it called something else now? but anyway... after the gloss (let it dry) then apply the decal, use some solvent to soften it up ...after its dry and settled ,apply another coat of gloss over it, dry ,and then a dull coat... this will keep it from silvering,and/or peeling off . If you just apply the decal by itself , most likely it will begin to lift after a while and flake off.www.TSHobbies.com
