I know some have used carbon tubes (round and square) to strengthen the nose area in the empty channels, especially if you are using heavy batteries and extensive mods. However, I needed something soon, and didn't want to wait to order some carbon. The local hobby shop only had aluminum tubing left. I purchased some 6mm diameter aluminum tubing. Carbon is likely much stronger, but with two of these (one on each side channel), I would imagine it's plenty strong. If I bent these flying, something else is massively wrong, ha-ha. The inner diameter is thick enough. I can still bend them a bit, but requires quite a bit of pressure and it's likely much more than would be applied during flight.
With that said, has anyone done testing with RF differences between using carbon tubes versus aluminum tubing? It makes me curious if I'm making things worse with receiver signal by using aluminum versus carbon. I would have to look up the difference in potential inference though, as I've never researched this.
