    Originally posted by T-CAT
    The new camo paint scheme on the A-10 is underway, as well as the custom decals (mixed with some of the stock waterslide decals). It should be done by the end of the week. This one will have 90mm EDF's.
    That nose art looks real familiar;). Looks good T-Cat!
      • 2137
      • On planet earth....right
      Yeahhhhhh buddy! The nose art is one of my favorites. I would have loved to see that released on the full scale hog one time. Your paint scheme looks absolutely phenomenal.
      • ColtPilot
        Hobby Squawk Advanced Pilot
        • Jun 2015
        • 538
        • Saint Clair Shores, Mi
        I like it to. :Cool:
        • Xtraflyr
          • 96
          • Morris County NJ
          IMG_1121.JPG Just love the looks of this bird!
          Click image for larger version  Name:	IMG_1119.JPG Views:	2 Size:	214.7 KB ID:	91521Click image for larger version  Name:	IMG_1120.JPG Views:	1 Size:	291.7 KB ID:	91520
          I'll get the balls up to add the nose art this week!
            It was a toss-up between that one and this one.
              • 2137
              Another great one for sure!
              • Shirty
                Hobby Squawk Water Boy
                • 1067
                • Perth, Australia
                Figures mate. Only from the land down under. :)
                Lol, you don't know how right you are....the vid definitely has a bit of an Aussie theme. ;)
                • porkpilot
                  Banned
                  • Aug 2017
                  • 7
                  maidened mine yesterday. it's a lovely big chunk of foam. i had no bounce problem but i realy think it was daft putting the oleo nose gear with the trailing link mains. i will be putting on a trailing link nose gear as the oleo will screw up just from being rollled fast across a grass field. i flew all factory setting and need zero trim for hands off flight. best chunk of foam to date from freewing.
                  • Shirty
                    • 1067
                    • Perth, Australia
                    Grats porky. :)
                    • ColtPilot
                      • Jun 2015
                      • 538
                      Way to go. Congrats. Gotta have pics to be official, so I've been told. :Cool:
                      • downwindleg
                        • 1279
                        • Friday Harbor, Washington
                        Very cool, looks like something from Transformers.
                          • 2137
                          Ha-ha, thanks. That's very true. It's basically a robot hog. Maybe we should call it Hoggle Bee or Hogtimus Prime LOL.
                          • downwindleg
                            • 1279
                            OK, here are how my Mavericks and Pave Penny turned out with the 7/8" and 1" domes.
                            So Steve, just wondering what you used to cut the 7/8" and 1" domes down to get the right shape. Brad
                            • porkpilot
                              Banned
                              • Aug 2017
                              • 7
                              thank you gentlemen.don't know if anybody shot pics while i was flying. my flying buddy did pile his however into one of the flight stations, fixable damage. i know one of the gang got pics of that so when he puts them up i'll post them here.
                                Mine's nicknamed the Iron Hog
                                  I have one of those bench top belt sanders with the side disk sander as well. I just set them on the tray next to the disk sander and kept sanding down the edges and having to break off the burr on the bottom edge of the dome until I got the diameter down to about a 1/32" larger than the inside edge of the dome. Something like this. obviously with the Pave Penny you only want to take it down to the OD of the foam which left about a 1/8" flat edge all the way around the 7/8" dome.
                                  Click image for larger version  Name:	Maverick dome cross section.jpg Views:	1 Size:	16.7 KB ID:	91644
                                  • bcrc
                                    Pilot
                                    • Jun 2017
                                    • 33
                                    Forgive me if this has come up before.
                                    I have a suggestion for Freewing or for Motion RC:
                                    The airplane should come with a paper copy of the ESC programming manual.
                                    Thank you.
                                      Or you could just download it directly from the MRC site:
                                      • bcrc
                                        Pilot
                                        • Jun 2017
                                        • 33
                                        INEXPENSIVE BALANCING STAND FOR YOUR FREEWING A-10
                                        I made this stand with parts I had around the house: a piece of 2X4, some 1/2" pvc, a couple of "T"s, and some "Non-Stick" tool box liner.
                                        The only thing I had to buy was the liner - and now I can line my tool boxes with the leftover!
                                        It is self-explanatory. Glue the tool box liner to the top of the "T"s. The center-to-center distance between the uprights is 10". The uprights should be at least 10" long. I drilled out the 2X4 with a 7/8" bit, which is a little sloppy, but I put a couple of laps of orange duct tape around it so they fit tight.
                                        As long as you are close to the CG, the liner will keep it from slipping and you can move the airplane around until it balances perfectly.
ID:	91656Click image for larger version
ID:	91652Click image for larger version
ID:	91657Click image for larger version
                                        • bcrc
                                          Pilot
                                          • Jun 2017
                                          • 33
                                          https://cdn.shopify.com/s/files/1/10...iles/fwesc.pdf
                                          ...which is what I did, but a copy should come with the airplane. I'm just making a suggestion to the manufacturer. It is important that the buyer's know that they need to set their ESCs to their radio throttles. This is never mentioned in the instructions that come with it. Actually, there also should be literature about the fans and motors included.
