    Impressive! Please send to me when it's complete. I assume A is for Alpha, right? Oh, it's not? :)
    • t33jetman
      • 515
      This was supposed to be simple sport plane. After seeing others cockpits, now I have to unglue and paint up the seats and add so.e trim to dress it up. You guys are killing me. The scoops are functional feeding the fan unit.
      • Shirty
        Hobby Squawk Water Boy
        • 1067
        • Perth, Australia
        Niiiicccee. That's awesome mate, well done.
        • F16Jeff
          Experienced builder and flyer
          • 17
          • Simi Valley, CA
          Originally posted by t33jetman
          Ok I couldn't wait any longer, so took my heat gun out and unwrapped her, Oooooo
          Very nice! it is nice to see a different color than yellow.
          • t33jetman
            • 515
            Got some paint on the wings , and still waiting on my graphics from Callie.
            • Woodcock
              Old Returning Pilot
              • Apr 2018
              • 830
              • SoCal
              Looks awesome Jetman. I really like the colors a lot.
              Woodcock
              • Topdogzrc
                MiG Driver
                • 77
                Evening all, by any chance, does anyone know of a good vectored thrust nozzle I could add to this bird?
                I've enjoyed doing pop-tops, crankshafts, and basic hovers with it, but the lack of vectored thrust results in ~15 second hovers before it falls out of them.
                Thanks!
                  • 8789
                  Thanks!
                  I know of only 2 planes with vector thrust nozzles close to the size you need and you are holding one of them in your avatar - the SebArt Mig 29. It so happens that those are the same nozzles (except for cosmetic edging) that come on the Freewing SU-3. However, you are using the nozzle from a 70mm plane to an 80mm plane. Can't say how much this will affect thrust.
                  • Topdogzrc
                    MiG Driver
                    • 77
                    My worry is those would choke the thrust badly on an 80mm EDF. Maybe a 3D printed one could work, but I wonder how precise you'd need the printer to be to prevent binding
                    • hotrod23t
                      jim jets
                      • Nov 2017
                      • 312
                      • EUSTIS FL.
Name:
ID:	134152 just thought i would post my invisible wing fences for you too see..lol made from plexiglass for those who dont like the look of wing fences:pop:Cool:
                      • hotrod23t
                        jim jets
                        • Nov 2017
                        • 312
                        • EUSTIS FL.
Name:
ID:	134904 ok its finished ..a3 gyro.... freewing 12 blade inrunner 6s..... front gear modded .. put rubber band on front gear spring......invisable wing fences......1/16 inch pinstripe to make the lines pop 3 coats high gloss polycrylic now for the maidian
                        • Checkmate
                          • 11
                          When you guys apply polycrylic, do you just use a foam brush? What's the preferred application process?
                          • hotrod23t
                            jim jets
                            • Nov 2017
                            • 312
                            • EUSTIS FL.
                            i like a foam brush better than spray or brush bristle type dont use the dollar store quality thay have a good one at lowes the foam is finer
                              • 7352
                              A foam or a soft wide, flat brush works well too, three or four coats, allowing them to set up for 6+ hours works great. I've found that if you're going for the glossiest finish, a brush gives the best results, for a duller finish, a spray gun works best.
                              Grossman55
                              • t33jetman
                                • 515
ID:	135530Click image for larger version
ID:	135531Click image for larger version  Name:	20180603_025450.jpg Views:	1 Size:	107.7 KB ID:	135509 It's been slow going, and here is the left side done. I'm getting there some day.
                                At least I won't get mixed up with someone else's plane at the field.
                                I was in the first group to get this plane when it came out, but , I hated it when it arrived. same size as my original Habu. but after a year seeing it sit in the corner, I decided to give it five minutes of my time. I think I love it now.
                                Click image for larger version  Name:	20180603_024818.jpg Views:	1 Size:	104.2 KB ID:	135508
                                  Very cool! Love the chrome silver...:Cool:
                                  • Woodcock
                                    Old Returning Pilot
                                    • Apr 2018
                                    • 830
                                    • SoCal
                                    Like wise. Silver and red, really nice color combo.
                                    Woody
                                    • mr.frankenjet
                                      Eat, sleep, FLY FLY FLY !
                                      • 448
                                      • Virginia, USA
                                      sweeet:Cool:
                                      rc flyin addict
                                      • Topshot19
                                        Pilot
                                        • 189
                                        • logan utah
                                          • 7352
                                          WOW, that's some great paint job t33!!
                                          I love the paint off mine, but only in a different way, new fuse and vertical stab and she's back in the air. Can't wait for Muncie with all that runway just to ease her in...……..:Sleepy:
