Impressive! Please send to me when it's complete. I assume A is for Alpha, right? Oh, it's not? :)
Camp my Instagram @Alpha.Makes -
This was supposed to be simple sport plane. After seeing others cockpits, now I have to unglue and paint up the seats and add so.e trim to dress it up. You guys are killing me. The scoops are functional feeding the fan unit.2 PhotosBVM Bandit, EFlite Carbon Z T-28, EFlite Carbon Z Cub, EFlite Promethus, FW Avanti S, FW A-10 ThunderBolt, FW P-51 Mustang, EFlite Convergance, EFlite Carbon Z Cessna 150, EFlite Habu, EFlite Styker Q-F27, HSD Navy Super ViperComment
Evening all, by any chance, does anyone know of a good vectored thrust nozzle I could add to this bird?
I've enjoyed doing pop-tops, crankshafts, and basic hovers with it, but the lack of vectored thrust results in ~15 second hovers before it falls out of them.
Thanks!Comment
I know of only 2 planes with vector thrust nozzles close to the size you need and you are holding one of them in your avatar - the SebArt Mig 29. It so happens that those are the same nozzles (except for cosmetic edging) that come on the Freewing SU-3. However, you are using the nozzle from a 70mm plane to an 80mm plane. Can't say how much this will affect thrust.Evening all, by any chance, does anyone know of a good vectored thrust nozzle I could add to this bird?
Thanks!Comment
My worry is those would choke the thrust badly on an 80mm EDF. Maybe a 3D printed one could work, but I wonder how precise you'd need the printer to be to prevent bindingI know of only 2 planes with vector thrust nozzles close to the size you need and you are holding one of them in your avatar - the SebArt Mig 29. It so happens that those are the same nozzles (except for cosmetic edging) that come on the Freewing SU-3. However, you are using the nozzle from a 70mm plane to an 80mm plane. Can't say how much this will affect thrust.Comment
A foam or a soft wide, flat brush works well too, three or four coats, allowing them to set up for 6+ hours works great. I've found that if you're going for the glossiest finish, a brush gives the best results, for a duller finish, a spray gun works best.
Grossman55Team Gross!Comment
It's been slow going, and here is the left side done. I'm getting there some day.
At least I won't get mixed up with someone else's plane at the field.
I was in the first group to get this plane when it came out, but , I hated it when it arrived. same size as my original Habu. but after a year seeing it sit in the corner, I decided to give it five minutes of my time. I think I love it now.
WOW, that's some great paint job t33!!
I love the paint off mine, but only in a different way, new fuse and vertical stab and she's back in the air. Can't wait for Muncie with all that runway just to ease her in...……..:Sleepy:
Grossman56Team Gross!Comment
