  • Kferros
    edf jockey
    • 40
    • Eustis Fl
    I don't see a problem since she seems to come in nice and slow. I have V2 f16 6s no flaps mix in and can land little hot. FW 16 mixed in flaps for takeoff but helps with landings.
      Originally posted by Kferros
      Thought I could with DX8 but could not find flap settings. Am I missing something.
      Not sure whether your DX8 is Gen1 or Gen2. In my DX9 G2: Under "Function List" scroll down to "Flap System".
      Flap Elev
      Pos 0 -100% 0%
      Pos 1 -29% 9%
      Pos 2 29% 17%
      Switch D
      Speed: 2.0s
      These values put the flaps and elev mix at the measurements called for in the manual. Depending on how your servo arms are positioned at assembly, your measurements may be a bit different.
      Also, under the Set Up menu you have to set the wing to 1 Aileron and 1 Flap before you can go to Function List.
      Hope this helps
      • bill34207
        Jet Junkie
        • 455
        • Bradenton, Florida
        Not sure if it's the same with a 8 and 9, but with the DX18 you have to activate the flaps under the Aircraft Type (system setup) section to even get the flap system to show up. Under the wing setting tell it that it has 1 Aileron and 1 Flap (since we are in essence running them on a Y) Once that is done you should be able to find the Flap system under normal setup.
        • Bcool831
          Don't Tell My Wife How Many I Have.
          • 19
          Flap Elev
          Pos 0 -100% 0%
          Pos 1 -29% 9%
          Pos 2 29% 17%
          Switch D
          Speed: 2.0s
          Hope this helps
          Thanks twowing. That actually helped me out splendidly.
          • urrl
            • Oct 2013
            • 505
            Mod will probably slow the jet down. We'll see on the Maiden flight if it is worth it.
            • urrl
              • Oct 2013
              • 505
              Originally posted by cableguy351
              Awesome flight!
              • Felixs10
                Felix S.
                • 113
                • Bergen county, NJ
                you need to make the wing type in programming to one aireron one flap servo . Once that is done , from the main program program screen on the dx8 enter flap condition .. from there you can assign takeoff flaps , landing flaps , and all other parameters .. I also suggest changing the flap speed to 2s speed ...
                • urrl
                  • Oct 2013
                  • 505
                  First impression: a really smooth flier and although I did not expect jaw dropping speed with the three Nerf Vortex Aero Howler whistles it's still pretty fast.
                  I'll have to see how much faster Doug's Avanti is before deciding to keep the whistles or extract a few.
                    • 8228
                    Nice maiden and video! Love those owls! :)
                      Are the whistles from the disk or football?
                      • Ron lake
                        • 68
                        • North East Kansas
                        urrl,
                        ​​ Great job with the videos as always!
                        • bill34207
                          Jet Junkie
                          • 455
                          Four more flights on mine this morning.I moved the battery back about 3/16" to get it closer to the aft CG and have to say I like it there. Holds a line while inverted better and let me change the up trim I had in it before back to 0.
                          Also noticed the tendency to climb slightly with flaps deployed so went back and added a little flap/down elevator mix like the manual suggested. Worked well with 2% at half flap and 4% at full on my DX-18
                          It's a keeper barring any unfortunate radio or other electronic failures.
                          • urrl
                            • Oct 2013
                            • 505
                            The football.
                            • urrl
                              • Oct 2013
                              • 505
                              Any chance I can get the actual adjusted CG? I would like to see if the jet can wheelie and mine seems nose heavy at the moment.
                              • bill34207
                                Jet Junkie
                                • 455
                                Balancing on my fingertips so it's hard to be exact, I'm just barely ahead of the rearmost recommended setting. Could probably go back ever further but I'm tweaking it a little at a time.
                                  Mine is at 108mm, upside down, and gear down(nose gear weight shifted back). Elev trim is at zero. And only needs the lightest touch of down elev while inverted.
                                  • Bajora
                                    AA6JB
                                    • 462
                                    • Sonoma County, California
                                    I was excited to see my first Freewing 80mm Avanti this AM. A clubmate (Michael Troy) had his up for a couple flights and I was able to get a few quick shots of it in, in between a couple of first flights on a new Freewing 8S 90mm Yak 130!
                                    What a fantastic looking, sounding and performing sport jet!
                                    • urrl
                                      • Oct 2013
                                      • 505
                                      Great shots Bajora :)
                                      Save
                                      • HellHathNoFury
                                        • 247
                                        Hey Alpha.. It must have been after a hard night with the boys when you touched up the Avanti with the Tamiya Flat Yellow..LOL.. It needed a touch of Deep Yellow to be 'near perfect'..To quote you..:)
                                          • 7385
                                          Finally got mine together and have 'Buzz' the pilot in her. Painted my dashboard a light nutmeg brown, just to be able to tell it from all the other Avantis that will be at Nefi !
                                          HH, it looks like it needs just a touch of red, and I mean a touch as red is a very overpowering color ! Try it on some paper first before the airplane. You should be able to match it that way.
                                          Here's Buzz, and ex Airforce pilot in the cockpit of his new Avanti...
ID:	77737Click image for larger version
ID:	77738Click image for larger version
