Hi SmokeNgun, welcome to Hobby Squawk! Alpha explained why there's play in the nose gear. In years past, the rigidity of gear created problems under load so often times the retracts could break under stress from, say, a very hard landing. The play you see is intentional and in fact helps the gear under load and stress. Hope that helps.
Originally posted by Shirty View PostGrats on the successful maidens boys. Hopefully do mine tomorrow. Can't wait. :)
Hhnf, Bill, can you post me a quick of your battery position in the tray? Cheers mate.1 Photo
Originally posted by xviper2 View PostI've installed trailing links on my Stinger 90 and it really does improve the landings immensely. However, my Avanti should arrive tomorrow. I'll reserve judgement till I fly it and compare. I've loved my S90 but I'm not averse to putting it in Kijiji if the Avanti is that much better. Or even keeping both if both are just as good but "different".
Good luck Shirty, although I doubt you will need it! She's just THAT good! LOLMy YouTube RC videos:
Originally posted by Shirty View PostThanks bill, thanks tcat too for the battery pics. I've got some zippy compacts at just over 800 grams, and the new graphenes are over 900, so was looking for a rough starting point for each. Weather forecast looks good (only 15mph winds), so tomorrows the day. Woohoo! :)
Avoid high rates on the ailerons.
Originally posted by Ron lake View Post
What trailing links did you use xviper? I ordered Avanti ones and I plan to put the Stingers wheels on them, seems like it'll work with a little finagling.
Mine is all ready to go. Maiden flight later today. Thanks to everyone for the advice and tips. I promised some photos in my previous post so here they are. My setup is as follows: Converted the power connector to Deans (to match everything else I have). Spektrum AR9350 receiver (2 satellites) with AS3X gyros and telemetry. I am running motor battery voltage, temperature, and RX battery volts right now on telemetry. I pushed the red wire out of the throttle channel from the ESC and capped it with heat shrink. I am running a separate 1300 mah LiFe RX battery through a switch for the radio. Based on past experience with most ARF's I have set my high rates to about 85% of the values in the manual. I have set my low rates to the suggested percentages of high rate in the manual. I have also set up a third rate that is the same as low rate but has some guesses at expo values I want to try. For the gyros, I started with three settings, none, 25% rate/0% heading and then 25% rate/25% heading. I can turn the heading gain up or down in flight so I will experiment with it and report back.3 Photos
Originally posted by Aros.MotionRC View PostHi SmokeNgun, welcome to Hobby Squawk! Alpha explained why there's play in the nose gear. In years past, the rigidity of gear created problems under load so often times the retracts could break under stress from, say, a very hard landing. The play you see is intentional and in fact helps the gear under load and stress. Hope that helps.
Will have to see..
Shirty - Lookin' gooooood! :Cool:
SmokeNGun - This jet tracks better than any jet I have ever had. How's that for "slop endorsement"? LOL
rpellicciotti - That is the Mobius 2 Action Camera 1080P 60FPS. Sweet camera!My YouTube RC videos:
Four more flights today bring mine to 21. Had a strange experience with it today too. Made a take off on my last flight and climbed out before rolling over into a split S to come back down the runway when all of a sudden it made a right hand turn all by itself. Not sure of why, it's almost like it snap rolled to the right. Luckily I was at enough altitude to fly out of it but now it has me concerned. It did something very similar yesterday while putting it through a loop. As it was coming down the back side it just suddenly changed directions on me, again at enough altitude to recover from it with no issues. Maybe too much throw in the elevator? :Confused: I was flying on my mid rate for elevator which is the same as the manuals low rate.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
Originally posted by sam51401 View PostI cant find the reference searching back about the 6s balance plug adapter that is placed on the wing connectors to take the strain from the wiring when disconnecting the wings. I have the ones i picked up from BuddyRC and those dont fit.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
Second flight on her today, had an audience this time. Figured out what I was doing wrong on landing. Being a tail dragger guy, I forgot to pull the nose up as the last second to flare. She started into her bounce again, and I pulled back elevator and she immediately settled in. AH HA thinks I,:Cool: Now I know !!;)
Again, the plastic base of the front gear came loose, so she's back in traction, hopefully I've got her right this time.
But what a great flying bird !
Afterwards I took her over to the rougher grassed section of the field and demonstrated her 'off road' capabilities to the crowd as they stood there gob smacked.
Very impressive plane.
