  • jetfool
    • Nov 2022
    • 1327
    • Crawfordsville, Indiana
    Looks great, Elbee. So much charactor to these birds the more detail and weathering I do. Can't wait to see your next addition.
    Cleaned off the chalk where my stars go and can't believe how much weathering chalk came off in those areas. A muddy mess .LOL Now I will go back and add the weathering over this.
    Rex
    • jetfool
      • Nov 2022
      • 1327
      Sunshine shining thru the shop window this morning. Started weathering the bottom today. Lots of coral dust on the bottom, oil seepage on bottom, oil/grease stains from flap hinges, ect. Exhaust shrouds need to be imbedded in the foam. Exhaust shrouds are the original paint that the bottom started out as, sure has changed. Will spray the exhaust stain last. May tone down the weathering tomorrow after sleeping on it.
      Installed the leather strut cover they used on the original. Retracts work fine with this added and the cover looks like my photos
      Still need to add the mud splatters on lower fuselage.
      Best Regards, Rex
      You can see the leather covers on landing cover
        • 4848
        Originally posted by jetfool
        Sunshine shining thru the shop window...Best Regards, Rex
        Rex, really great work, Sir. Best, LB
          • Nov 2013
          • 2748
          • Cody, WY
          Best Regards, Rex
          very nice, Rex! I like that you added little details on the bottom like the shell casing ejection chutes . I think you'll find while owning and flying it, that you'll find just a little touch you want to do here or there from time to time, per your liking. I just made and attached small fairings on the forward part of the exhaust stacks. Meant to do that earlier, but when I had it upside down in the shop working on the scissors struts, I figured that was a good time to do it.
          After all, the mantra: "you're never REALLY done when you have a warbird, is quite true! Nice work!
          Davegee
          • jetfool
            • Nov 2022
            • 1327
            Thank you, Dave
            . I value your complement. .
            Rex
              • 7371
              Man that looks good Rex, now all you need is a tropical background and you'd swear it was real!
              I can't say enough about the quality of work your creating.
                • 8223
                Excellent work! No warbird looks better dirty than a Corsair. Well done!
                • jetfool
                  • Nov 2022
                  • 1327
ID:	372754 Thank you Grossman56 and Aros. Means a lot
                  Identification lights
                  More pics of the details
                  Landing light. Made with alum tape and a plastic lens. RC 56 glue still drying, takes a few days for it to go clear
                  Landing gear cover from leather.
                  Landing gear cover in the down position
                  • jetfool
                    • Nov 2022
                    • 1327
                    Installed the shrouds around the scale exhaust. Will need a little filler and sanding then I can weather this. Thank you Elbee for the scale accessories. Rex
                      • Nov 2013
                      • 2748
                      • Cody, WY
                      Click image for larger version  Name:	IMG_2917.jpg Views:	0 Size:	88.5 KB ID:	372790
                      Click image for larger version  Name:	IMG_2918.jpg Views:	0 Size:	88.0 KB ID:	372791
                      That really looks great, Rex! I really like the mottled look as part of the weathering scheme, very close to what the real ones looked like under those conditions.
                      The only thing I would correct (and probably very few people would even know) but the proper sequence of the identification lights from front to back is RED, GREEN, and Amber at the very back. But who would know? Looks very sharp!
                      Click image for larger version  Name:	completed1.webp Views:	0 Size:	17.2 KB ID:	372802
                      • Coconut
                        • Apr 2019
                        • 212
                        She looks awesome, Rex. I remember not too long ago you couldn't wait for Christmas Day to open the box. Now, we're in March and watch how much you accomplish already.
                        • jetfool
                          • Nov 2022
                          • 1327
                          Thank you, Coconut This has been an enjoyable journey. My favorite airplane and FL has produced a quality Corsair that has unlimited possibilities. Stock or modified it is very impressing.
                          Retired so I spend 4-8 hrs a day working on it and looking at all the other Corsairs on the net. Everyone is impressive!
                          Still need to finish cockpit and more details as I find them. Spring is coming and impatiently waiting to do taxi tests, system check, engine synchronization, C/G. Also need to fly some practice planes before the maiden.
                          Yes X-MAS morning was exciting this year!
                          Davegee, Thanks for pointing that out to me. I had it layed out correctly but had a BRAIN PHART. I have since corrected. Also noticed from your picture I had not filled the lower aileron seams or added the hinge covers. Tomorrow I will remove the weathering and start over. I have added the gun camera too.
                          Nice to have a senior flight officer point out I need to use my check list.
                          Thanks everyone for checking my 6, Rex
ID:	372844Click image for larger version
                            • Nov 2013
                            • 2748
                            • Cody, WY
                            Not at all, Rex! I suppose some put me in the dreaded category of being a "rivet counter" but the contests I used to do years ago like Top Gun and Scale Masters, the judges usually knew every square inch of your airplane, and would see and mark off for very minor infractions like that (the recognition lights)! If there was anything out of the usual, you had to have it detailed and noted in a scale book that you presented one of the three judges so that they could account for anything unexpected, yet scale to your particular aircraft that you are showing. It was always fun to "zing" one of the judges (rarely) when he missed something or counted off, until you pointed out "page 25 of your scale and detail book" he had in his hands!
                            In any event, Splendid work on your beautiful model, Rex. With this first foray into super scale, you'll carry what you learned on this airplane, good and bad, to your next project!
                            Can't wait to see pics of it flying this Spring!😍😍😍
                            Cheers
                            Davegee
                              • Nov 2013
                              • 2748
                              • Cody, WY
                              Cheers
                              Davegee
                              BTW, really like the gun camera and the simulated camera lens inside! The gun strips look great. The armorers did different patterns to show everyone that these guns were now LIVE and ready to fire!
                              davegee
                                • 7371
                                Dave, either you're going to have to put out a video on using those chalks or we're going to have to get together!
                                BTW, are you going to the Swap Meet on March 25th?
                                • jetfool
                                  • Nov 2022
                                  • 1327
                                  Guys I started to install the cockpit today and I also decided to redo the aileron seams on the bottom. First cleaned the weathering off, then added filler. Will sand, add polyurethane clear to harden the filler and repaint. Then re-weather it again. Funny how dirty the original paint gets after weathering.
                                  Best Regards, Rex
                                  • jetfool
                                    • Nov 2022
                                    • 1327
                                    Grossman56,
                                    Just jump in with the chalk weathering. I wasn't sure at first but as you can see if it isn't what you want just clean off with wet paper towel and start over. Davegee has been a great inspiration to me. Rex
                                    • jetfool
                                      • Nov 2022
                                      • 1327
                                      Been a few days but I have filled the seams, sanded them out. Applied 3 clear coats of polyacrylic and added the hinge covers. I applied new paint and will weather this area again, Getting down to the final weathering Sprayed the exhaust stains on bottom of fuselage. Best Regards, Rex Click image for larger version
                                        • Nov 2013
                                        • 2748
                                        • Cody, WY
                                        Looks awesome, Rex!! Really like that you redid the tape on the wingtips. I never liked that on the model.
                                        Cheers
                                        davegee
                                        • jetfool
                                          • Nov 2022
                                          • 1327
                                          Thanks, Davegee. I forgot to remove the tape and fill the seams when I bagan. It looks a lot better now. Thought the exhaust would have more gray smoke but most photos show mostly black.
                                          I fly Futaba but could you tell me your Expo, D/r and settings for the controls. Thought I would start to set up the controls. Do you use a balance tool or by finger to check the C/G. 100mm is what most are setting their c/g at with gear up, upside down. Or should I start with the manual settings. I'm hoping to get a gentle flying set-up.
                                          Best Regards, Rex
