  • AkumaZeto
    Achtung Stormtrooper
    • 907
    When it bounced I would have retracted the lg and let it slide in on tanks.
    AMA 1102566
    • Helmsman52
      • 247
      • Saint Paul, MN
      Originally posted by fhhuber
      Small power increase (maybe 15% to 20% for a second) and use that to stop the "pogo" and complete the landing... Scuff some paint. Fly it again after replacing/recharging batteries.
      Definitely do not apply full power and pitch up for a near vertical climb in an attempt to save the paint.
      I have to agree as it happened a few times with me.
      • e4dragongunner
        Living the dream!
        • 876
        • Arlington Heights Il.
        Been there , I am sorry for your loss. " You fly jets long enough things like this are bound to happen"
        • e4dragongunner
          Living the dream!
          • 876
          Originally posted by fieldofdreamsflyer
          Get them here , he makes the best scale looking ones
          http://thercgeek.com/3d-printed-products-services/
          Just WOW!!!!
          • Flybeast
            Hobby Squawk
            • Nov 2017
            • 5
            • Brownsburg,IN
            Originally posted by bbaumer
            hey, I know the guy who took that picture! ;)
            We’ll have 3 up at our club’s Warbird this weekend, all in different SEA schemes, hopefully we’ll get a couple up at once for some sweet pics!
            Count me in!
              Just WOW!!!!
              I have these on mine, detail is insane.
              • bbaumer
                • Jun 2017
                • 152
                • Indiana
                Here are my versions, I’ve printed a couple sets, I lose a few of the points but it’s very hard to tell
                • Torkrollin
                  Lower
                  • Mar 2018
                  • 37
                  • Meridian, MS
                  Got a chance to fly a couple of batteries today here is one of my flights
                  Meridian Aeromodelers
                  • dahawk
                    Augermeister
                    • Jun 2013
                    • 1006
                    • Keller,Texas
                    Tork,
                    That's some great flying. You have obstructions everywhere. Trees , light poles . Great landing
                    • Torkrollin
                      Lower
                      • Mar 2018
                      • 37
                      • Meridian, MS
                      Thanks Dahawk!
                      I haven't flown there in a few years. I'm so use to the phantom that it makes it easy to fly there.
                        • 8218
                        Great flight and landing fellow obstruction flyer! :Cool:
                          Excellent flight!
                          • Torkrollin
                            Lower
                            • Mar 2018
                            • 37
                            • Meridian, MS
                            Thanks guys!
                            • dahawk
                              Augermeister
                              • Jun 2013
                              • 1006
                              • Keller,Texas
                                • 8218
                                Just got my 3D nozzles...Love 'em!
                                Next up...The RC Geek's Center Burner!
                                Click image for larger version  Name:	nozzels1.jpg Views:	1 Size:	100.9 KB ID:	140561
                                Click image for larger version  Name:	nozzles2.jpg Views:	1 Size:	89.5 KB ID:	140562
                                • Torkrollin
                                  Lower
                                  • Mar 2018
                                  • 37
                                  • Meridian, MS
                                  Those look great Aros!
                                  Where did you get them?
                                  • GMB
                                    EDF's are fun
                                    • 22
                                    Has anyone had a problem with the nose gear door not closing. I have the ARF+ and just finished putting it together. The only problem I encountered was with the landing gear. Radio is Futaba T16SZ, travel at 135 and limit at 100 ( radio default setting). Opening sequence is nose gear door opens, one to two seconds later nose gear and main gear deploys. Nose gear light comes on. That all seems normal. Problem is retracting gear. Retract sequence is all three gears close BUT nose gear door stays open and won't close.. I tried changing travel and limits with no success. I disconnected the nose gear servo and reinserted it to the control board to insure a good connection but no change there (orientation correct). I can close the nose gear door with hand pressure on the door so I don't think the servo gears are stuck.
                                    Any ideas?
                                    Thanks
                                    GMB
                                      I believe the sequencing for the door is handled through the connector board. Might need to replace it.
                                      • GMB
                                        EDF's are fun
                                        • 22
                                        I am thinking it is either a bad servo or as you say, the connector board. I have sent an email to the support team at MRC asking what to do. I will report back what they say.
                                          If you have a servo tester you can easily verify if the servo is working or not. If not, isolate it on a separate spare channel and test it that way.
