Yeah,
I get lazy sometimes and forget to do these things. A Phantom flying like a Hobbyzone Cub ? Was not fun to fly or even watch it fly.Currently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
I Want: 80mm A-4, twin 80mm F4J PhantomComment
Great to see some sister company livery ! Nicely done !Currently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
I have numerous MRC EDFs, twin and single prop driven warbirds, and have never calibrated an ESC. All these were plug and play models if that makes a difference. Maybe I have been extremely lucky, I don't know. I thought I read in a post somewhere, that one of the Motion guys said that the calibration of the ESC was done at the factory and was unnecessary to redo...
Is the calibration procedure in the planes manual, or with your transmitter manual? I don't remember seeing any info during the build in the manual.
I am not having any problems, but sure would like to know I am getting all I can out of my motors...
Thanks...
Tom
No, that's not the case, your escs have to be calibrated to your radio system. Otherwise it wont know where the start point or end point on your specific system is. That cant be done at the factory for obvious reasons.Comment
When I hear calibrate I think throttle up, plug in battery, throttle down. Setting or changing the timing requires the ESC manual, tho plug and play shouldn’t require a change to the timing as that is set at the factory. Do I have that right?:Confused:Comment
By calibrating you are not entering the programming menu but letting the ESC understand what full throttle is on your radio. Sometimes it may not seem like it matters but it should be done and I have taken off only to feel like the plane is sluggish, then after calibrating the ESC have it come to life.Comment
So all there is to calibrate an ESC is, on all radios, turn on Xmittter, put throttle to WOT, plug in battery on plane, and I am assuming you wait for ESC to initialize at which time I will get a throttle high warning on my DX8, then move throttle to lowest setting???Comment
Alright, thanks!!!
Got a mission today...
Get off work in 20 minutes, go home sleep for 5 hours, then calibrate 14 planes ESC's...lol...
Seems I remember doing this a couple years ago on planes I ordered and put in the motor and esc in myself...
All other planes have been Plug and Play Aircraft from MRC...Comment
Just make sure you turn on the Tx first, then raise your throttle stick all the way up, then plug in the battery to the plane. After the initial tone(s) drop the throttle. Your radio should not give you a high throttle warning. That would happen it you raised the throttle and then turned the TX on.. sounds like you have your work cut out for you. :)Comment
Yes,
Just make sure to flip the stick to zero throttle before the esc goes into programming mode.
On most pnp’s, it’s not necessary but I do it anyway. When changing esc and motor combos like I did on the Arf+ , absolutely necessary.Currently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
