"Hacksaw the glue? I used foam tac and some gorilla glue. It really wasn’t gonna come off in a hurry."
Cut 1/2" on the far side of the tail with a sharp blade or fine saw as far as the carbon tube but don't cut into the tube. Then, painstakingly remove every bit of foam and glue using any tool that works. Gorilla glue cuts and sands, never used foam tac so can't help with that! Clean the protruding carbon rod ready to insert in the new fuse. If the surface your left with is very pitted use two or three short carbon rods or even round lollipop sticks to secure it. Try to maintain a clean all round edge for cosmetics !! You'll get there .........good luck!!
I'm definitely getting me some of those, never knew what they were for before but I guess you can always teach an old dog new tricks. All joking aside, are you saying that these should at least be installed around the + & - leads coming out of the ESC heading toward the battery and also bound with the throttle servo wire (all 3 inside one choke, or one for each or just on the power leads) as close to the ESC as possible? And also if possible on the 3 motor wires coming from the ESC to the EDF bound together in 1 choke? Is your HAM radio guy saying the interference is generated from the ESC and transferred along the power cables and throttle servo wire, and that the receiver may not necessarily get interference from just the electricity that these wires carry but is something more? Also did he comment on those small metal "life saver" things wound around the wires coming from a UBEC (or from an ESC that has an internal BEC), are they also some form of limitation on interference? Sorry for all the questions, just want to understand it better. Anyway, I am going to give it a go, can never be too careful when it comes to the radio signal.
